5th Gen Steering Wheel Shake: SOLUTIONS ONLY
Discussion in '5th Gen 4Runners (2010-2024)' started by James P, May 18, 2022.
  1. Nov 17, 2024 at 11:49 AM
    #241
    Could be rotors starting to pulse if it only happens under braking.
    nimby likes this.
  2. Nov 17, 2024 at 1:24 PM
    #242
    RUNNER4DAN
    Daniel
    Doesn't need any
    And were did you get that information, Fux News?
  3. Nov 17, 2024 at 1:53 PM
    #243
    4Person
    4Person New Member
    nope SL
    Ripper238[QUOTED] likes this.
  4. Nov 17, 2024 at 6:25 PM
    #244
    TRoosevelt
    TRoosevelt New Member
    Ty
    2022 Lunar Rock 4Runner
    1.5 Inch Lift 33’s
    I had the gray trd wheels and had no shake. I switched to the black trd wheels and now have a shake. I have had 3 sets of different brand of tires and have had them balanced 5 times with road force and still have a shake. Two brands wouldn’t balance but the falkens are all under 2. It still shakes
  5. Nov 17, 2024 at 7:32 PM
    #245
    4runningMan
    4runningMan New Member
    New Mexico
    Anecdotally...
    My friend had the new style TRD black wheels on his old truck (2022?). No shake.
    He then moved the same set of wheels/tires to his new 2024 truck. Shake. Tried new tires. Still shake.
    Don't think it's the black wheels. But it could be lol.
  6. Nov 17, 2024 at 7:41 PM
    #246
    TRoosevelt
    Ty
    1.5 Inch Lift 33’s
    It is annoying. I am surprised after all this time no one has found a definitive solution
  7. Nov 18, 2024 at 8:01 AM
    #247
    wildgoose
    wildgoose New Member
    2020 4Runner TRD Offroad
    I had a steering wheel shake for a while that felt like a tire was out of balance but sort of intermittent. I went around in circles the biggest change was installing the ECGS bushing, i also cleaned all of the mating surfaces on the rims and that helped a good deal but what finally completely fixed it was an alignment at a 4x4 shop. They spent 3 hours with the truck and it drives like butter now. I couldn't believe and just never knew that a bad alignment could cause what felt like an out of balance tire. Shop said it was common to get a shake from a bad alignment. Never knew.
    TRoosevelt likes this.
  8. Nov 18, 2024 at 8:15 AM
    #248
    TRoosevelt
    Ty
    1.5 Inch Lift 33’s
    My camber is off because I have a seized lca. It is barely out of spec. Does anyone know if that can contribute to the shake?
  9. Nov 18, 2024 at 8:35 AM
    #249
    AR1978
    AR1978 New Member
    2015 4Runner Trail Premium
    I had a steering wheel shake, researched it, and the 95% solution was to have Discount Tire do a road force balance. I've not read all 9 pages of this thread so I hope this helps.
  10. Nov 18, 2024 at 8:54 AM
    #250
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I ask when i can and so far it seems E load have more shake issues than SL. So that makes sense.
  11. Nov 18, 2024 at 9:59 AM
    #251
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Can you post your measurements?
  12. Dec 27, 2024 at 10:47 AM
    #252
    SouthBoy
    SouthBoy New Member
    2019 Toyota 4Runner TRD Off Road Premium w/ KDSS
    Full blackout; Bilstein 5100s (0.85" front); aftermarket wheels/tires
    Hello! My first post here; I'm a new member. Found my solution to this dilemma. Significant shimmy/shake in my steering wheel at highway speeds. Took the vehicle to a Toyota dealer to have the wheels road force balanced. I had suspension work a few months prior, including a new alignment, so I already knew an alignment issue wasn't the case. Toyota was able to road force balance three of my four wheels, and found the other to have excessive wheel runout. That wheel was on the front of the vehicle. Swapped it to the back and tested the vehicle for about a week following. The problem was gone. In process of putting a brand new set of wheels on my vehicle now. Can't live with a faulty wheel on my awesome rig moving ahead. I'm certain the new wheels will be great, too (Method Race Wheels). The set I had, including the faulty one, was KMC. My $0.02 on solving this problem...
    9000feet and nimby like this.
  13. Feb 1, 2025 at 8:48 PM
    #253
    CarlP
    CarlP New Member
    Carl
    Phoenix, AZ
    2018 Off Road with KDSS
    I suggest that wheel installation is often to blame, especially when ham fisted techs just zap the lug nuts with impact wrenches. Without extra care, it is very easy to install the wheels incorrectly seated at the hub. My 2018 with new KO2's drove super smooth. Then I knocked some weights off the wheels power washing mud off the bottom, and of course it shook. Four complete road force wheel balances later it was still shaking at various speeds over 60. I recently rotated the tires myself, and paid close attention to how the (hub centric) wheels were installed. That includes synthetic steel wool cleanup of all wheel and hub mating surfaces, and very gradual tightening of the lug nuts to final torque. ALL the vibration is gone!
  14. Feb 1, 2025 at 9:02 PM
    #254
    SouthBoy
    SouthBoy New Member
    Following up on my first post right above… Been riding the new wheel set for a month or so now. They’re incredible! Zero shimmy/shake now, at any speed. Problem completely solved. I’m thoroughly tickled… :)
    Rocko9999, gkellys, ATX14 and 2 others like this.
