5th Gen Steering Wheel Shake: SOLUTIONS ONLY
Discussion in '5th Gen 4Runners (2010-2024)' started by James P, May 18, 2022.
  1. Sep 18, 2023 at 2:21 PM
    #211
    Unstopable4X4runner
    Unstopable4X4runner New Member
    Have a 2021 SR5 with blackout package and TRD Pro Black wheels. Got some new Nitto Recon Grapplers, love the tires, about as noisy as snow tires or less, handle great. Ryan at Plymouth MN Discount Tire was super helpful in fixing the 60-70mph shake on the brand new Recons. He said, after the first balance was off, that Black wheels can "trick" tire balancing equipment cameras. All four tires were off after 1st balance, but Road Force balance on the 2nd attempt, eliminated about 95% of the high speed shake.Beware of black wheels, it might throw off balancing equip is the lesson learned today.
    kojak likes this.
  2. Sep 24, 2023 at 2:05 PM
    #212
    MelloMan
    MelloMan New Member
    Absolutely spot on, JQ! There is no fix. Years and years of posts about this issue and they keep coming in droves to this very day. If there were an actual known fix that worked 100% of the time then a 2023 would not be rolling off the assembly line with the exact same problem on mile 1. Nobody has “truly” found the fix for this problem. And a “fix” is not doing 3, 4, or 5 different things at once and it may or may not get better. That’s called rolling the dice. Accept it, or don’t. But it sucks.
  3. Sep 28, 2023 at 4:45 AM
    #213
    mal10015
    mal10015 New Member
    Connecticut
    2023 Lunar Rock Great Value TRD Pro aka TRD ORP
    I'll chime in.
    2023 ORP, truck came with the matte black TRD SEMA wheels and factory Dunlops. Had the steering wheel shake almost immediately after taking delivery. Luckily I had already purchased a set of new gen TRD Pro wheels and new ATs to throw on prior to buying our truck since we were actually supposed to take delivery on a different vehicle that never showed up. Got the new set up mounted and balanced, the shake had decreased immensely and now 2200 miles later it's pretty much completely gone.
    Was it the tires? Was it the wheels? Was it incorrectly balancing? Who knows, but from the research I'd done it could be any of the three or the combination of all.
    And for those curious here's my current setup:
    OEM TRD Pro Wheels P/N PTR56-89210-F2
    265/70/17 Yokohama Geolandar G015 AT
    Truck is bone stock otherwise
    The thing I found the weirdest was that our 4runner is not the first we've driven. I've rented a 2018 OR and a 2022 OR before on long extended road trips. We've also test driven a 2019 ORP when considering to buy CPO, and also a 2022 SR5P. None of the other 4 trucks we've driven had the vibrations.
    Bixby101 and kolter45 like this.
  4. Sep 28, 2023 at 1:57 PM
    #214
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    I reported above in this thread that I had started to get a slight shimmy at 55mph - 60mph.
    Truck is lifted 2" and runs 265/70-17 KO2s which I religiously rotate front to rear every 5K. Truck tracks fine, so did not expect alignment issue.
    Tires have 36,000 miles on them and are at 8/32nds tread depth all around. No uneven wear conditions.
    Took in today for rebalance and sure enough they had worn into an out-of-balance condition. Four wheel balance took 30min drop in visit and no cost since I bought the tires there.
    Problem solved.
    Disclaimer: Just posting anecdotal data point for consideration. Not claiming this is the answer to all problems.
    Jason
  5. Oct 6, 2023 at 8:53 AM
    #215
    K20K54R
    K20K54R New Member
    Two weeks ago I took delivery of a new 2023 40th anniv model and it had steering wheel shake from the moment it left the dealership principally around 63 MPH. The dealership was able to correct this with a road force balance. FWIW I'd periodically experience the same with my 08 4R on OE FJ wheels and BFG ATs - balance always corrected this.
    nimby likes this.
  6. Oct 6, 2023 at 9:06 AM
    #216
    MWinkTRD
    MWinkTRD Basically Stock
    Max
    Southeast Alabama
    2023 MGM TRD ORP
    Whenever I exercise the four wheel drive system I notice the shake/shimmy goes away for awhile which makes me believe it might be the needle bearing. Mine has done it randomly since I bought it new last November between 55-60 mph. Doesn't really bother me though since I used to drive a Silverado lifted 9" on 37s, steering wheel/passenger seat constantly vibrated in that thing lol
    Bixby101, Guppy1301 and kolter45 like this.
  7. Oct 6, 2023 at 10:37 AM
    #217
    kojak
    kojak New Member
    21 SR5P 4x4
    Not a solution: are we starting to think the matte black wheels are more prone to getting a bad balance?
  8. Oct 14, 2023 at 6:01 AM
    #218
    kojak
    kojak New Member
    21 SR5P 4x4
    New Wildpeaks and the vibration is gone (for now).
    backpacker and kolter45 like this.
  9. Oct 14, 2023 at 7:31 AM
    #219
    kolter45
    Denver
    Inferno Pro & BRM Sport
    If it goes away in 4x4 then it’s def the needle bearing & you need to order from ECGS for the replacement. Buy the gasket when you order it too
  10. Nov 7, 2023 at 3:33 PM
    #220
    4run4by
    4run4by New Member
    I’ve owned a 2020 4runner for a few years now. Started getting slight steering wheel vibration at 17,000 miles. I took it in and was told one of the tires was damaged, out of balance, and was the culprit. I decided the time was right to install a 3inch lift with new methods and 33” toyo AT3’s. Following install and fresh balance/alignment, however, the shake was worse. Mainly between 55-65 mph. I tried rebalancing, realigning, road force balancing the new wheels and tires at numerous shops and had no luck. After reading as many forums as I could find I decided to just deal with it. I did so for the next 30k miles until my tires were ruined from the constant vibrating which got worse over time. Finally, I took it to a local off road shop. The owner recommended new Toyos since the current ones were thrashed, and Total Chaos UCAs. Before signing for these recommendations I did a quick inspection and discovered my driver side outer tie rod end was also shot (not sure if it was a cause or a symptom of the front end vibration). I went ahead w the new tires, UCAs, and replaced both outer tie rod ends. Fresh balance and alignment and the steering wheel shake was completely gone. It’s been about 1k miles and it still drives better than new. Hope this helps someone else dealing with this annoying issue.
  11. Nov 7, 2023 at 4:17 PM
    #221
    kolter45
    Denver
    I wish I had bought TC UCA over SPC!! That sounds like a nice suspension! :transformer:
  12. Nov 7, 2023 at 4:32 PM
    #222
    kolter45
    Denver
    My grey SEMAs,on my taco, had no problems with wildpeaks. My black SEMAs, on my 4Runner, do seem worse but their older. I have an older pair of duratracs on the 4Runner too & they fucking suck ass. Loud & shit ride, probably only 30k miles
  13. Nov 9, 2023 at 11:46 AM
    #223
    What's wrong with the SPC's?
    kolter45[QUOTED] likes this.
  14. Nov 9, 2023 at 12:14 PM
    #224
    kolter45
    Denver
    I bought them when they had a bad batch of bushing & it was like pulling teeth for them to own up & replace them
    nimby[QUOTED] likes this.
  15. Nov 15, 2023 at 2:36 PM
    #225
    Jelliottjr_2K22_SR5
    Jelliottjr_2K22_SR5 New Member
    I had this issue with my 2022 SR5. Bought it used and the dealership replaced the factory tires with GeoDrive brand. Took it back three times and the fix was a new set of Michelin Defender LTX. Made a world of difference. Not sure if one or more of the tires were defective or just that low quality.
  16. Feb 10, 2024 at 2:14 PM
    #226
    124runner
    124runner New Member
  17. Apr 5, 2024 at 9:56 AM
    #227
    El4Gunner
    El4Gunner New Member
    Les
    2018 4Runner
    Wheels
    I finally found the answer , if you have aftermarket wheels ,get the hub centric rings .60 bucks at your local tire shop . They ordered the parts for me , I got a wheel rotation and balance . Shake is gone. I had this problem for 2 years and couldn’t figure it out . Hope this helps anyone that is really annoyed with it .
  18. Aug 30, 2024 at 8:18 PM
    #228
    scottyrunner
    scottyrunner New Member
    scott
    I wonder if that "heat" is not actually the tires but the needle bearing heating up and thus expanding causing smaller tolerance and less play.
    ualfltdispatch and Bixby101 like this.
  19. Sep 20, 2024 at 9:31 AM
    #229
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Mine comes and goes with varying road surfaces, always @64mph +/-3mph.
    ualfltdispatch likes this.
  20. Sep 20, 2024 at 1:07 PM
    #230
    kojak
    kojak New Member
    21 SR5P 4x4
    Vibration in the wheel gradually came back around 50-60, was trivial until I put the (full size, balanced) spare on the front then was pretty noticable. Went away completely again with a balance.
    It's just really sensitive to wheel balance.
    nimby likes this.
  21. Sep 20, 2024 at 1:12 PM
    #231
    j4unner
    j4unner shootz brah..
    j4runner
    nCal
    21 SR5P
    thanks for sharing..
    specific brand or a size if needed you went with..? link? i'm getting new tires put on monday stock size but AT tires.
  22. Sep 20, 2024 at 1:15 PM
    #232
    Shnook718
    Shnook718 New Member
    shaun
    4runner
    here is my solution I have SPC upper control arms and the bushings were bad. SPC warrantied them for me and put them in. Shakes were gone. Im on coilovers with SPC UCA's and on 305's. That was June 20th of this 2024
    It is 9/20 and the shakes are back but mild. I need to recheck everything and make sure they are still ok.
  23. Sep 20, 2024 at 2:03 PM
    #233
    TrailSpecial22 New Member
    PA
    I must be lucky but my 2011 SR5 with 169k and 2022 Trail special with 285/70/17 Falken WP AT3s have no shake.
    having the right tire and right balancing solves 99% of that problem imo
    nimby and Lc200 like this.
  24. Sep 21, 2024 at 2:47 PM
    #234
    cantdrive55
    cantdrive55 New Member
    I'll add my own experiences in hopes that somebody finds it useful.
    When I took delivery of my 4runner last October, I didn't notice any issues. After my 5k service, the techs rotated the tires and I immediately had some pretty noticeable steering-wheel shaking around 60mph. I figured the back tires were just never properly balanced and had my local Discount Tire rebalance all the tires. However, that rebalance did not fix the issue.
    I took the truck back in a week ago for its 10k service and the techs rotated tires again as part of that service. With the vehicle tires back (or at least closer) to their original configuration, the shaking was gone. However, I took it back in today to have them have a look at the back tires. They ended up road force balancing all the wheels. They also told me the tire with the worst balance was on the front, which did not make sense to me given that I'd not experienced the wobble all week.
    Driving back from the dealership, I'm still shake free. However, what's left to be seen is what happens when the tires are rotated again.
    So is the issue a "balance" problem? My data is inconclusive. But the problem does appear to be related to something about a tire and/or wheel detail, and not so much the truck itself.
    j4unner and TrailSpecial22 like this.
  25. Sep 21, 2024 at 2:56 PM
    #235
    Matt83
    Matt83 New Member
    Northeast
    Anything Michelin, balanced with finger plates seems to solve the problem.
  26. Nov 6, 2024 at 5:06 PM
    #236
    MrsBeck
    MrsBeck New Member
    2014 sr5 premium runner
    Cbi bumpers, maf sensor, pedal commander, cold air intake, 1.5” level kit, rear airbags with on dash compressor
    Since this post has already derailed big time, I figured I’d add more to it
    I agree that balance is super important in these. I wonder if there is something about the Toyota setup that is causing it to come out of balance…?? Like it is perfectly balanced and it’s the vehicle causing it to become imbalanced??
    It seems to be a general consensus that replacing the needle bearing with the ECG bearing helps some, but doesn’t actually fix the problem.
    Lexus GX was having the same shimmy issues as us, their fix was to change out the pressure spring in the steering rack to a stiffer one… has anyone researched, or tried this?
    Charlievee likes this.
  27. Nov 6, 2024 at 5:19 PM
    #237
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    I remember something about the pressure spring in the steering rack on the FJ forums a few years back. Not sure where it went from there. But good point to bring up!
  28. Nov 6, 2024 at 5:28 PM
    #238
    MrsBeck
    MrsBeck New Member
    I think it’s about 15 hours of shop time…so I doubt very many have tried it
    McSpazatron likes this.
  29. Nov 17, 2024 at 10:38 AM
    #239
    4Person
    4Person New Member
    I skimmed through most of these responses. It seems like nearly everyone is feeling the shake while driving at 55-60 mph. I have a lift and 285s on my limited. I’ve had them for a few years now, no problems. However, it started steering wheel shaking recently when braking from 60mph (ie exiting the highway or coming to a higher speed stop at a light). Happens to my wife also and she brakes much more gently than I do. I had my brakes checked and they are fine. Maybe the tires have become an issue, but the driving is still fine.
  30. Nov 17, 2024 at 11:17 AM
    #240
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Cereous, are the tires E load?
    As for the breaking shake, i had that one time after sitting parked in a humid area for a few days. The shake from breaking was very aggressive. But after 100mi or so it went away.
