5th Gen Armor
Discussion in '5th Gen 4Runners (2010-2024)' started by SixthSnail, Feb 24, 2016.
  1. Jul 7, 2023 at 7:45 PM
    #301
    Henry J
    Sacramento Ca
    Seriously! My Budbuilt took 10 bolts on each side
    Thacrow[QUOTED] likes this.
  2. Jul 8, 2023 at 7:44 AM
    #302
    wingo
    wingo *****
    2020 Venture
    Add CBI for sliders, Orangeboxx Fabricators for Molle panels and bumpers, Expedition One for Bumpers, Rago, and RCI for skid plates to your list.
  3. Jul 8, 2023 at 2:44 PM
    #303
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Taking armor off for POR15 :rockband:
    Forever, Dabigono and Doglover2003 like this.
  4. Jul 8, 2023 at 2:56 PM
    #304
    Austin26
    Austin26 New Member
    Austin
    5th gen ORP
    Don't see my bumper on here.
    CBI Adventure bumper 2014-2019 fitted to a 2022 ORP with MTM. DIY TSS relocation, still need to find solution for front camera (currently angled up / blocked somewhat).
    RSG engine skid. Love it too.
  5. Jul 9, 2023 at 9:25 AM
    #305
    love my SSO
  6. Jul 9, 2023 at 9:46 AM
    #306
    wingo
    wingo *****
    2020 Venture
    I should have went with the high hoop like yours to clear the TSS sensor. Since I went with the low hoop I had to relocate the TSS sensor down to clear the hoop so it can function correctly.
    Austin26 likes this.
  7. Jul 9, 2023 at 11:23 AM
    #307
    ahh, bummer! No issues with your sensor now?
  8. Jul 11, 2023 at 8:05 AM
    #308
    Harringbr99
    Harringbr99 New Member
    Brian
    Kentucky
    2021 Barcelona Red Limited
    If you're planning to "use" the sliders I'd skip the "bed liner" and get the rust stripped and sanded then hit them with Rustoleum in flat black rattle can.
    Each time after you hit the trails you can use a cardboard shield and touch them up with more Rustoleum in under 5 minutes.
    The Bedliner will get just as torn up on anything real as rattle can black, and it'll be more trouble to repair.
    TRDTyler and dgrenier15[QUOTED] like this.
  9. Jul 11, 2023 at 8:41 AM
    #309
    dgrenier15
    dgrenier15 New Member
    Dayne
    Oklahoma
    2022 AG TRD ORP
    I think that is the route I have determined to go. I wanted the bedliner for some texture for when my wife uses them as steps but I will probably just add some skateboard decking to the top as just a little added texture.
  10. Jul 13, 2023 at 12:45 PM
    #310
    Good point. Comparison to RSG:
  11. Jul 14, 2023 at 8:30 PM
    #311
    CRasch505
    CRasch505 New Member
    Chris
    Rio Rancho NM
    5th Gen 4Runner ORP
    Trail edition wheels, Falken AT4W 255/80, Eibach stage 1, Super Pro UCAs, OEM rock rails, roof rack delete, no-scoop hood, ceramic tint on all glass.
    How do you like the ARB setup? I have been looking at their full skid package but can't find a ton of feedback in either direction. Feel free to shoot me a PM if it's easier. Thanks!
    glwood54 and djwantke[QUOTED] like this.
  12. Jul 15, 2023 at 10:13 PM
    #312
    Doglover2003 likes this.
  13. Jul 20, 2023 at 9:54 AM
    #313
    Mowantstogo
    Mowantstogo New Member
    Mo
    2020 4runner TRD Pro
    +2 LT up front. Kings adjustable, Dobinsons coils in the rear. Backwoods Adventure Mods bumpers and roof rack. Riding on 315/70/17 Toyo's
    I didn't see any Backwoods Adventure Mods bumpers so I thought I would add a pic of mine.
    Garlic, MEski4x4, MTB Chris and 11 others like this.
  14. Aug 2, 2023 at 12:09 PM
    #314
    Metal_Head
    Metal_Head New Member
    Eric
    St. John’s, FL
    2017 ORP
    Dobinsons MRR, FN 17x8.5 Wheels, EIM Keith PCK, Metal Tech Sliders, Custom made rear lower links with Duroflex Joints, GOBI-no-rise roof rack, C4 overland front & rear bumpers, Smittybilt 10K X20 winch, LASFIT H11 LED low beams, C4 full skid plate package, custom machined ARB compressor, safety hub mounts and battery hold down.
    Artec Venture. I like it but I'm going bigger and have the C4 overland series plate bumper on order to replace it.
    Ignore the headlights, that was a comparison of Lasfit LED's to stock.
    [​IMG]IMG_0073 by EricT4R, on Flickr
  15. Aug 2, 2023 at 12:21 PM
    #315
    Metal_Head
    Eric
    St. John’s, FL
    2017 ORP
  16. Aug 2, 2023 at 12:27 PM
    #316
    Metal_Head
    Eric
    St. John’s, FL
    2017 ORP
    Metal Tech sliders P/N: MT-4R5G-22100. This is an old pic. They have taken a beating on the rocks and are holding up well.
    [​IMG]IMG_1116 by EricT4R, on Flickr
    Dabigono and TrailSpecial22 like this.
  17. Aug 2, 2023 at 1:45 PM
    #317
    bad ass!!
    Mowantstogo[QUOTED] likes this.
  18. Aug 2, 2023 at 1:46 PM
    #318
    Mowantstogo likes this.
  19. Aug 3, 2023 at 8:44 AM
    #319
    Metal_Head
    Eric
    St. John’s, FL
    2017 ORP
    I'd imagine that would be a problem lol. That was the day I did the install. I didn't have the tag or camera relocate done yet. Here is the only picture I have handy of it completed.
    [​IMG]IPIF9445 by EricT4R, on Flickr
  20. Aug 3, 2023 at 10:48 AM
    #320
    ah, got it! Thx looks good!!
  21. Aug 18, 2023 at 6:32 PM
    #321
    I keep on forgetting about this thread. I figured I’d post my 4x Innovations skid plate set since you don’t see much on them. The price I think is very nice for what you get. It’s 1/4in thick for the front and mid skids, and 3/16 for the transmission and transfer case skid.
    B5A1B748-7A27-4F75-9154-DF906A5EF8DA.jpg 3D602550-B3EC-42FC-BD0D-3B88D699D492.jpg 9FE825F3-47B8-47DA-A01C-8CC4F50AE191.jpg E471D033-123B-49E1-863E-01D312476D69.jpg E82D5DF7-D015-4E07-A58A-EA2A4A1B4B0D.jpg
    The mounting method on these seem pretty good. It uses 6 bolts to the frame for the front skid. The engine skid uses two bolts to the frame (the rear mounting locations for the factory engine skid, and it also mounts to the front skid itself in a jigsaw fashion with 5 more bolts. The transmission skid mounts with two bolts to the frame (where the tubular support mounts to the crossmember), along with 5 bolts to tie it in to the engine skid. And finally, the TC skid mounts with three bolts to the inside of the frame rails, along with 5 bolts to the transmission skid in front of it.
    This mounting scheme basically results in a structurally unitized whole belly pan. In all likelihood, these would survive a roadside IED…no joke. The main reason I went with these is because they essentially completely protect the lower control arm mounts on the frame itself. I saw no other skid plate options that provide this. The exception being maybe the LFD plates, but those only mount with 4 bolts total to the frame for a single piece covering the front and engine area.
    Drawbacks? Weight! The builder said about 176lbs if I recall. I’d say…at least that much. This is not something you would want to install without a suspension/springs that takes this weight into account!
    The other drawback is maintanance. You can access the zerks for the rear driveshaft just fine, but servicing the front driveshaft or the transfercase, and transmission will require removal of the two rear plates. (Maybe I can get away with removing just the trans skid for front shaft greasing, but not sure since the tolerance are so tight). Not a big deal as long as you realize that a jack will be needed to lift/drop each plate. In my case, I had bought a cheap transmission jack from HF that worked perfectly to maneuver and lift these into place.
    I’ve already changed the oil and filter once, and the access doors made it easy.
    All hardware is stainless button head bolts, with allen heads. Many are exposed, so there’s potential that you’ll have to drill them to extract them should they get ground up. But the allen heads at least should serve as a good pilot hole lol.
    They are as tight to the frame as possible, although the front skid angle is sharper than factory front plate, so technically it might eat a smidge into approach angle.
    Coverage is excellent…almost too good. To the point that it might get mighty hot down there in slow traffic in hot climates. I did notice an increase in transmission temps in slow off-road situations. Big reason might be because the transmission skid wrap up to the bottom of the frame. All the heat from the cats has to fight to get out.
    The fit-up is amazingly tight, and the interlocking mounting method really seems stout to the max!
  22. Oct 20, 2023 at 11:50 AM
    #322
    Metal_Head
    Eric
    St. John’s, FL
    2017 ORP
    Those 4X skid plates look nice, I bought the C4 full set but I'd probably have saved the cash and got those if I'd have seen them first.
    I got a new C4 overland front bumper and put it to use along with my sliders going up the Daniel trail @ Uhwarrie.
    [​IMG]IMG_2452 by EricT4R, on Flickr
  23. Oct 30, 2023 at 6:27 PM
    #323
    Chef4Runners
    Chef4Runners New Member
    2012 4Runner Limited
    TRD Cold Intake, TRD Cat Back Exhaust
    Harringbr99 likes this.
  24. Dec 4, 2023 at 12:14 PM
    #324
    ualfltdispatch
    ualfltdispatch New Member
    2023 TRD Off Road Premium
    Link for the hood protector? Gorgeous gal.
  25. Dec 4, 2023 at 2:06 PM
    #325
    its a weathertech and thank you!!
  26. Jan 8, 2024 at 5:37 PM
    #326
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Victory Blitz aluminum front bumper. Built more for overlanding that rock crawling so much less weight. I've got the Warn winch but haven't installed it yet.IMG_1865 Large.jpg IMG_2555 Large.jpg
  27. Jan 25, 2024 at 1:13 AM
    #327
    Sixstring
    Sixstring New Member
    Barry
    2020 4runner off road premium
    Led headlights fog lights smoke taillights trd pro wheels Falken wildpeak tires emblem blackout kit black front valence startx remote start
    Good looking 4runner I really like the light's that's next on my list
  28. Feb 5, 2024 at 7:07 AM
    #328
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    Talons Garage full skid on my '24 TRD OR...
  29. Mar 30, 2024 at 9:57 AM
    #329
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    That looks dangerous af.. if you fall on a rock hard enough, it will dent your frame for sure
  30. May 19, 2024 at 3:35 PM
    #330
    Kyle11863
    Kyle11863 King of the BS
    Big Bear California
    1990 Toyota 4Runner SR5 V6 5 Speed Manual
    Doug Thorley long tube headers and lots of mud
    Coastal Offroad has some great armer products for you guys. They currently offer front and rear bumpers, single/dual swing outs that use a modular attachment system so you can change things out, sliders, and even weld on link sliders (its under the 3rd gen section but its universal)
    They are also working on some skid plate for you as well, should be available by the end of the year I'm prediciting.
    For anyone interested use code "SOCALTOYOTAS" for 5% off your order 238506192_903826033550892_1437593629144741790_n.jpg 152726514_809814276285402_6138635516872463094_n.jpg Sliders_003.jpg B-2-of-8-1.jpg 125312002_749883978945099_7061047952621805438_n.jpg 20210713_200700.jpg 405269096_7107072279379950_3601271156737939771_n.jpg 242046542_921202638479898_2660765036902707862_n.jpg IMG_1782-3.jpg
