5th Gen Armor
Discussion in '5th Gen 4Runners (2010-2024)' started by SixthSnail, Feb 24, 2016.
  1. Aug 25, 2022 at 2:32 PM
    #271
    DuckDiggler
    DuckDiggler New Member
    Will
    2020 Limited 4Runner
    Stock…for now…
    very good info here.
  2. Aug 25, 2022 at 2:32 PM
    #272
    DuckDiggler
    Will
    Stock…for now…
  3. Nov 4, 2022 at 5:11 PM
    #273
    Does anyone known of a good skid front skid plate option that gives some frontal protection to the lower control arm mounts?
    I was up on a rock the other day and the front driver tire slipped off it and the front tab of the control arm mount came down right on the rock. No bending (that would have sucked), because I came straight down on it. But if that hit carried any forward speed, I can imagine potential to bent that mount, and bind up the control arm.
    The other reason I like the front skid plate to shield the LCA mount is just to help keep the salt off of it in winter. Pretty much all the ones I’ve seen leave the LCA mount wide open.
    The only one that seems to have coverage is maybe the the 4x innovation plate, which is super nice. But they use 1/4 in plate, That is the definition of heavy, which be a real pain when it comes to my maintainance and post-mud washdowns routines. So if anybody knows of other options out there, I’d love to hear about them.
    LCA skidplates are an option, but, Id like something that puts forces on the frame, not on the LCA and bushings. Although that’s better than leaving it open.
    semprenissart likes this.
  4. Nov 8, 2022 at 6:28 AM
    #274
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    @McSpazatron
    did you end up doing anything or not yet?
    I just ordered some shock skids from fjtoyman that I’ll be installing this weekend
    http://fjtoymanoffroad.com/shockskidsking/
    Then I thought about LCA skids and was wondering if I need to get some or not. I saw that cali raised has some discounted for Black Friday. Anyone has them and has feedback? Or for those who has a LCA skid plate, which one do you have and why?
    https://caliraisedled.com/products/2014-4runner-lower-control-arm-skid-plate
  5. Nov 8, 2022 at 7:31 AM
    #275
    No not yet. I really like the 4X innovations plate system, since it seems to cover those LCA tabs on the frame. I’ve also seen these plates in person @Stoney Ranger, and they turn the vehicle into the closest thing to a MRAP the side of the army. Not only that but they look really nice.
    But the more I think about maintenance, the more I realize how much of a trade-off armor is. I put a lot of miles on my 4runner, so semi-regular jobs like greasing the driveshafts, or transfer case/differential oil changes become a bigger deal with the 4X plates.
    Thanks for reminding me about the shock skid plates. I need to get a set of those, let me know how you like them. I I have to get a Diff skid plate as well. Lol, I think I’ve managed to whack just about everything this summer. Not very hard, but enough to let me know it’s time to step up my armor game.
    Regarding the LCA skid plates, I kind of consider LC A’s as somewhat expendable in the big scheme of things. So armor just to protect the underside of plate steel seems redundant unless it offers some thing more. The Cali raised ones don’t even cover the bolts or the frame mount area. So I’m not seeing the draw in those. I think I’d rather just keep my ground clearance.
  6. Nov 11, 2022 at 12:37 PM
    #276
    semprenissart
    semprenissart Mèfi
    Super easy install, very beefy, nice welds and good quality overall. I'm very happy!
    Dabigono and djwantke like this.
  7. Nov 11, 2022 at 4:49 PM
    #277
    Thanks for the pictures. Did you have to remove the shock bolt to install, or does it slip over it?
  8. Nov 11, 2022 at 5:48 PM
    #278
    semprenissart
    semprenissart Mèfi
    yes I had to remove the shock bolt, insert the skid then put the stock bolt back as well as another one that came with the skid to hold it firm.
    Wheel doesn’t need to be removed as long as you don’t mind crawling under the truck. I removed to make it easier and because I’m lazy and also I like using the impact wrench. Turned out to be better as there was a lot of sand everywhere so I cleaned everything as well.
    without the cleaning it took about 5 min per side
    McSpazatron likes this.
  9. Dec 4, 2022 at 9:15 AM
    #279
    WTW15
    WTW15 New Member
    Denise
    Wondervu, Co
    2016 T4R Blue Trail Premium
    TRD black wheels, leveling kit, NFab nerf bars with steps, garage life at 9,000'.
    so you are saying if I am being pulled out, use the factory recovery points underneath on the frame - got it
  10. Dec 4, 2022 at 9:57 AM
    #280
    If you're referring to the oem loops on the front of a stock 4R, those are not generally considered recovery points, IIRC.
  11. Dec 8, 2022 at 6:41 AM
    #281
    MAXIM
    MAXIM New Member
    That is correct because cross member those attached to is thin mild steel and will distort given any serious recovery stress. Those hoops mostly for tow truck winch getting this rig rolling up the flat bed.
  12. Feb 14, 2023 at 4:37 PM
    #282
    Envy4R_808
    Envy4R_808 New Member
    Sean
    2022 Army Green ORP
    Locked OffRoad external rezy front and rear - ICON 2” rear springs - RSG flat kickout top plate DOM sliders/BMC plates - SPC UCA - Treaty rear KDSS spacers - SCS BR6 17x8.5 -10 - 295/70r17 Toyo M/T - DR.KDSS front KDSS spacers/front and rear KDSS clamps/pan hard correction bolt on/one touch KDSS on/off switch and harness - Midland MXT275 - C4 3 piece skid plates - all powdercoating by @kaitayapowder - all welding services by @wreckless_fabrications
    RSG Metalworks sliders since they weren’t in the OP
  13. Feb 15, 2023 at 12:10 PM
    #283
    MusashiSushi
    MusashiSushi New Member
    Colorado Springs, CO
    2023 4Runner SR5 Premium Black/Black
    Elka 2.5 DC 3" lift, SPC UCA's, Toytech rear springs, ARB Diff Breather, RSG Rock Sliders & front Skid. C4 front bumper with High Clearance sides and Warn Winch.
    I like the color matching of your sliders to the body. I just had RSG install my sliders and front skid 2 weeks ago and love em'!
    Envy4R_808 likes this.
  14. Mar 2, 2023 at 6:37 AM
    #284
    jth
    jth trdle
    Saint Paul, MN
    2020 Army Green 4Runner TRD Pro
    Is this true for the TRD Pro as well? Good to know if I ever decide to help someone out of a snowbank here in MN.
  15. Mar 4, 2023 at 6:20 AM
    #285
    Envy4R_808
    Sean
    2022 Army Green ORP
    I have had issues finding the actual spring rate for these as the icon website and multiple dealers don’t list it. In my opinion they are stiffer than stock as I have considerable weight added on my T4R. Might be good to try a spacer at 0.5” just to see if that height and ride is suitable and go from there.
  16. Mar 4, 2023 at 11:18 AM
    #286
    All 4runners have the same tow loops in the front. While I wouldnt say they are welded onto thin mild steel (I’m sure it’s the same kind of steel as the frame, and just as thick), the problem is that it isnt the frame rails proper. The manual states those loops are sufficient for getting towed (like on flat roads). But using them to yank someone out isn’t a good idea.
  17. Mar 5, 2023 at 11:41 AM
    #287
    bigdaddy2021
    bigdaddy2021 New Member
    Brian
    So-Cal
    2019 4runner - TRD Off-Road
    Armored, Dobinson's lift, 33's, MC TacoBox, Frontrunner rack, light overland mods, M8000 winch.
    We run a crap-tonne of armor and we love all of it. :D
    From front to back:
    Front bumper: Warn semi-hidden winch mount
    • Love this bumper. Cheaper than other options and mostly in stock via Amazon or other places. Stout recovery points and great winch access. We did an impression of a lawn-dart in Moab and landed right on the lower edge of this bumper with the full weight of the truck. Just slightly dented the front edge. VERY stout for recovery, too. We've used the heck out of it and love the low-profile look.
    Belly skids: 4xInnovations full skid set (notched for KDSS and our Tacobox)
    • Wanted full-width, heavy-duty steel skids and these did the trick. Oil changes are easy with the two inspection plates that can be removed.
    Sliders: 4xinnovations
    • Beefy, easy install and great for roof access steps.
    Lower Link frame mount sliders/reinforcement: RCI
    • Had to trim the 4xInnovation slider mounts a bit to fit these, but they're solid and an easy install otherwise.
    Gas tank: OEM for now
    • We'll see how she does on tougher trails.
    Rear Diff: Going with the C4 fab KDSS model with locker cover (pending)
    • Folks either want these or they don't and C4 fabs mounting solution seems to be better than other options. I think peace of mind that you're hitting the skid and not the diff or driveshaft is worth the 1" or so of lost clearance. Also, our rear driveshaft is a brand-new, custom shaft due to our Tacobox install, so It's worth it to me to protect it.
    Lower rear shocks: RCI
    • No brainer, easy install - lowest part of the truck - makes sense to us to protect it. the powdercoat got sandblasted in Anza-Borrego, but is holding up well.
    Rear bumper: Victory4x4 Strike bumper (with swingaways - off at the moment )
    • One of our favorite mods. Gained clearance, protection, 2 recovery points and with about 20 fasteners, we retained a valid towing point that's probably stronger than stock. It's a great rear step to get up to the roofrack, and honestly it creates a very useful 8" deep x 30-40" wide table surface at the back of the truck. Great for setting out snacks, sitting, prepping simple meals/drinks, etc.
    • I also love that you can order this without single/dual swing-aways and just order them later, if you want. We did the bumper and one swing-away, although, since we use our truck for other things, it's really nice having the carriers off for quick hatch access.
  18. Mar 6, 2023 at 8:42 PM
    #288
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    New hardware and spacers on ARB KDSS full skid plate kit (not including rear end) + hitch skid
    Hawxfan and Dabigono like this.
  19. Mar 6, 2023 at 8:45 PM
    #289
    Rear bumper armour paint, just because
  20. Apr 3, 2023 at 2:11 PM
    #290
    trip
    trip New Member
    Trip
    2013 Limited, 2022 TRD Pro
    Bailstein Lift
    These are amazing
  21. Apr 18, 2023 at 3:47 PM
    #291
    OC4X4
    OC4X4 New Member
    Souther California
    Demello was my favorite one!!
  22. Jun 16, 2023 at 12:33 PM
    #292
    FiremanRon
    FiremanRon New Member
    2017 4Runner
    Rack, Bumper, Winch, ARB Air
    CBI Front Bumper
  23. Jun 25, 2023 at 7:30 PM
    #293
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    My old Victory4x4:
    New SSO:
    Dabigono and TrailSpecial22 like this.
  24. Jun 25, 2023 at 8:41 PM
    #294
    Cis915
    Cis915 New Member
    Donovan
    Las Vegas
    '18 Nautical Blue TRDOR
    Eibach Pro Lift; 255/80 Open Country R/T Trails; Motegi Trailite; LFD 7/8; BMC/Pinch Welds; All-Pro Sliders; Custom Drawers; T10 v3; DD SS18 Light Bar; Baja Squadron Pro Ditch Lights; Auxbeam Switch; Alpharex Headlights; Spyder Taillights
    What made you decide to switch from Victory to SSO?
  25. Jun 25, 2023 at 9:13 PM
    #295
    Doglover2003
    '18 ORP w/KDSS
    Fit and finish. Better design. Thought I could save $200 thinking they are all built the same.... I was wrong.
  26. Jun 25, 2023 at 9:17 PM
    #296
    Cis915
    Cis915 New Member
    Donovan
    Las Vegas
    Ahh, ye old "Buy once, cry once." I'm still learning this lesson myself, good to know about the fit/finish of the SSO though. Thanks!
    Doglover2003[QUOTED] likes this.
  27. Jun 26, 2023 at 7:02 AM
    #297
    dgrenier15
    dgrenier15 New Member
    Dayne
    Oklahoma
    2022 AG TRD ORP
    Wasn't sure if this was the right thread to ask this, but I figure it would be better than starting a one off.
    I just picked up some used Shrockworks Rock Sliders. They aren't in bad condition - just a few minor rust spots around the screw holes. I was wondering if I could strip them and do a coat of bed liner or is it even worth it?
    Shrockworks Rock Sliders.jpg (not my grass - only picture I had)
    Pavementprincess24 and Dabigono like this.
  28. Jun 26, 2023 at 9:43 AM
    #298
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    How much salt is laid down in the winter? If you lived where salt is spread twice a week from Dec to March yeah, I'd address the little bit of rust. But you're in OK. I'd mount 'em and forget it.
    dgrenier15[QUOTED] likes this.
  29. Jun 29, 2023 at 10:46 PM
    #299
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I've never seen rock sliders with such few bolts or small and few mounting points. Looks like it would bend if you needed it.
    Old Tanker likes this.
  30. Jul 7, 2023 at 7:23 PM
    #300
    Idayota
    Idayota New Member
    2023 OR - Lunar Rock
    Suspension: Dobinsons IMS Struts + Springs. 2.5" front and 2.0" rear Tires: 255/80/17 Toyo Open Country A/T3 E Load
    Just got my rock sliders sliders in. Man, these things are huge seeing them in person, pictures don’t really do them justice.
    It sounds like there are often issues with installing both rock sliders and lower link skids, where they run into each other at the same point on the frame. Has anyone else ran into this? I held off on installing my lower link skids so I could do it all at the same time. From what I’ve read, I may have to cut part of the mounting plate on the sliders.
