5100s and lift
Discussion in 'Suspension' started by TexasMofo, Jan 17, 2017.
  1. Oct 16, 2017 at 4:57 PM
    Led4x4
    Led4x4 New Member
    2017 white 4Runner
    Thanks that answers my question perfectly
  2. Oct 17, 2017 at 2:23 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
  3. Dec 15, 2017 at 7:31 PM
    r0nnierae
    r0nnierae New Member
    Raezor
    San Jose, CA
    2016 Magnetic Gray Toyota 4Runner SR5 Premium w/3rd row
    2016 SR5 Magnetic Gray Premium 3rd Row, Tints, LED internal, LED backup light, amber marker lights - grill, amber fog lights, black out kit - emblems, night shade - tail lights, smoked front marker lights, hitch step, plastidip roof rack, N-Fab nerf bars 3inch, AVS external visor, AVS hood protector, Bilstein 5100's shocks all around, Old Man Emu Springs 3/2, JBAOffroad UCA's
    -bilstein 5100
    -old man emu springs 3/2
    -jbaoffroad upper control arms
    Stock wheels and tires
  4. Dec 16, 2017 at 11:01 AM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    Turned out great!
    erfer1 likes this.
  5. Dec 19, 2017 at 7:34 PM
    r0nnierae
    Raezor
    San Jose, CA
    Just comparing my truck to a stock truck.....
  6. Jun 5, 2018 at 6:49 PM
    Gordo71
    Gordo71 New Member
    2016 SR5 stock
    NFAB bars
    what settings did you finally go with? and tire size? looks great !
  7. Jan 1, 2020 at 11:07 AM
    SKT_07
    SKT_07 New Member
    Very sharp looking 4Runner!
    Any more pics?
  8. Jan 1, 2020 at 1:25 PM
    Bgdv1
    Bgdv1 New Member
    Dave
    Butler
    2014 SR5P
    [/QUOTE]
    Cooper at3 has a C rated 275 70 17 all terrain. I have them on my SR5P
  9. Jan 1, 2020 at 6:40 PM
    upperleftadventureguy
    upperleftadventureguy 2016 SR5. PNW
    Shawn
    Oregon
    2016 Black SR5
    I like the look of this! What was your total lift height? I am going to be in the market for a lift soon and I'm going back and forth with this, dobinsons, and eibach. Only thing ill be doing is throwing a RTT on top
  10. Jan 6, 2020 at 9:40 AM
    4runningyeti
    4runningyeti New Member
    PA
    2020 BRM TRD ORP
    This seems like a good place for this question without starting a new thread. Is there such thing as stiffer than OEM coils for front that DON'T provide any lift, such that the only front lift you are getting is from the billstein shock? Or does that defy the laws of physics ?
    plan now is BS 51 or 61 set at 1.75 and rear 1.5/2” springs- I actually like rake- guess that makes me a weirdo. ‍♂️
  11. Jan 6, 2020 at 9:46 AM
    WallyT4R
    WallyT4R New Member
    I think Dobinsons would have something for that application. I like rake also but I use mine. I carry quite a bit of weight and tow often.
    Eibach PRO front coil overs
    OME 8295 rear springs with Eibach PRO shocks
    Trim spacers front and rear on the drivers side
    JBA upper control arms
    Durobumps front and rear
    It rides like a truck, just the way it should IMO.
  12. Jan 6, 2020 at 9:46 AM
    Yes, you can get front coils that are stiffer than stock and don't provide any lift. There are 650lb and 700lb coils available, but those are only advised if you are constantly running more weight in front (bumper/winch/ect...).
    Why do you want to do the lifting with the 5100's? It's probably a better strategy for most to lift with the coils and set the shock on the lowest (0") setting.
    WallyT4R likes this.
  13. Jan 6, 2020 at 12:07 PM
    4runningyeti
    PA
    2020 BRM TRD ORP
    That’s not a bad thought either, just seemed like a 5100 x4 and a set of rear springs was a nice neat (and value added) way of doing 1.75 front, 1.5-2 rear. Then I read some say the front is still a touch soft, which made think doing front springs, but then I saw that most who do front springs get extra lift and I don’t want to be above 2” max in front. However I suppose what you said would work just fine as well.
  14. Jan 6, 2020 at 1:05 PM
    I would advise not to go out and buy heavier springs because other people say the front end is too soft. The stock spring rate is fine for our trucks weight. If you constantly carry more weight in your truck than the stock weight, then yes, a heavier spring is appropriate.
    When people complain about how soft or squishy the stock suspension on our tucks feel, they are actually complaining about the soft valving of the stock shocks. Just by replacing the shocks, you can significantly firm up the ride (if that's what you're after). Bilstein 5100's provide a fairly firm ride while Eibachs provide a firmer ride than stock, but not as firm as Bilstein 5100's.
    So if you want to keep it on the cheap and don't actually need heavier springs, Bilstein 5100's or Eibach adjustable shocks with the stock coils will be just fine for your application.
    If you actually need heavier coils because you have more weight you're carrying constantly, then check out Dobinsons as Wally mentioned. They have lots of coil options for our vehicles and are very well rated among those that have them. I'm certain they have a front and rear coils that will provide you with the appropriate lift height and spring rate you're looking for.
  15. Jan 6, 2020 at 1:16 PM
    4runningyeti
    PA
    2020 BRM TRD ORP
    great summary! Now just need to decide which rear springs!
    nimby[QUOTED] likes this.
  16. Jan 6, 2020 at 1:20 PM
    Do you plan to constantly carry extra weight in the back or are you just looking for lift coils?
    4runningyeti[QUOTED] likes this.
  17. Jan 6, 2020 at 1:24 PM
    4runningyeti
    PA
    2020 BRM TRD ORP
    Not much weight, maybe build a cheap wood sleeping platform, and a 1up bike rack (130 if loaded with 3 bikesJ although not sure how weight on the hitch effects things given it’s position
    which is to say I don’t consider that much weight, but maybe it is?
    Anyways opting for lift springs over say daystar spacers for better function. That’s where I’m at, billstein 1.75 up and 1.5-2” lift rear, although figuring out what rear springs actually lift you vs what they advertise is also an interesting challenge.
  18. Jan 6, 2020 at 1:50 PM
    That's probably not enough weight to warrant a heavier rear spring rate. That being the case, you'll have to make a decision on whether to go the spacer route or the taller coil route. If you're really on a budget, the spacer will work. If you decide to go with a lift coil, I'd be willing to bet either a Dobinson C59-505 (1.5-1.75" lift) or a C59-325 (2-2.25" lift) rear coil will do the job. Both of those utilize the stock rear spring rate but with different lift heights. With the weight you plan on carrying, you'll probably be closer to 1.5" with the C59-505 and closer to 2" with the C59-325, but would double check with Dobinsons beforehand.
    Yota209 and 4runningyeti[QUOTED] like this.
  19. Jan 6, 2020 at 1:54 PM
    #49
    4runningyeti
    PA
    2020 BRM TRD ORP
    Yup agreed, not worth it for heavier spring load. On a budget but not so much so that I would opt for spacer over coil.
    having said all that I do have one question getting back to front discussion. When you use an adjustable shoock and stock springs, as you lift using the shock aren’t you changing the preload/or something? on the spring thus changing the ride? Whereas using a fixed shock and longer spring to lift the same height but the spring is uncompressed? Just thinking out loud. Or does that amount of preload not make a difference . (All of this purely in terms of ride quality and feel)
  20. Jan 6, 2020 at 2:18 PM
    #50
    cmtaz
    cmtaz New Member
    If you a looking at 5100s and aftermarket springs, you might want to look at the Eibach Pro Truck Lift Kit. Eibach's adjustable shocks (thier version of 5100s') and Eibach springs. The kit provides 2.75" front lift 1" rear lift. I was also worried about reverse rake but too me the look is just perfect.
    There is a 92 page thread on this in "another 4Runner fourm".
    SKT_07, WallyT4R and nimby like this.
  21. Jan 6, 2020 at 5:11 PM
    #51
    "Preload" is a bit of a misnomer. As you move the bottom spring perch up on a Bilstein 5100 or Eibach adjustable shock, you're not preloading the spring any more than you normally would.........your spring is simply sitting higher on your shock and that's what's lifting your truck. However, as you move the bottom spring perch higher, you extending the shaft of your front shocks which has an impact on travel dynamics and the travel zone in which your suspension utilizes most often. So by extending the shaft of the shock at ride height, you will have less down travel (but more up travel). That could be beneficial to the way some people off-road, but a hinderance to others. It can also change the optimal travel performance of the shock for daily driving by putting you in a shock travel zone that is a bit stiffer.
    All of these nuances are probably not noticed by most people, however. You can put 5100's on the highest setting and be perfectly happy with the ride......it just depends on you. But if you're looking for the best way to utilize your suspensions travel, it's with lift coils and properly sized (and valved) shocks because it gets you closer to having an equal amount of up and down travel.
  22. Jan 6, 2020 at 7:05 PM
    #52
    4runningyeti
    PA
    2020 BRM TRD ORP
    Thanks man, great stuff again!
  23. Jan 21, 2020 at 10:33 AM
    #53
    gotjeepomaha
    gotjeepomaha New Member
    2017 Silver 4Runner SR5
    does the lift get rid of the nose dive when braking? Both my 2015 and 2017's do this, both are/were SR5 Premiums.
  24. Jan 21, 2020 at 1:50 PM
    #54
    Oey12
    Oey12 New Member
    Joey`
    2017 SR5
    Eibach Pro Sport leveling shocks, Firestone airbags, and Baja Design fog lights...
    ...for the most part yes. There still will be some dive but in my opinion it’s a night and day difference over SR5 shocks. I have the Eibach which are valved differently but I have ridden and drove a 4Runner with the 5100’s.
  25. Feb 21, 2020 at 3:18 PM
    #55
    ACM0302
    ACM0302 New Member
    ‘19 TRD Off Road 4RUNNER
    None
    I have Bilstein 5100s all around and the front is set at .85. The ride is excellent.
  26. Feb 22, 2020 at 4:34 AM
    #56
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    Looks great Adam. Great choice on .85.
  27. Feb 22, 2020 at 8:58 AM
    #57
    Barcelona Trail
    Barcelona Trail New Member
    Colorado in Winter - SoCal in Summer
    '16 TEP w/ KDSS
    Bilstein 6112 & 5100 - Built Right UCAs - AFE Intake, TBS, & Exhaust - Pedal Cmndr - Icon Rebound - 285 BFG KO2
    I went with 6112 in the front & 5100s paired with Bilstein B12 Springs in the rear along w Built Right UCAs... installed at The Truck Shop in SD CA. I achieved a 3/2 lift that sits level (w KDSS)
    WallyT4R, travelinscout and ACM0302 like this.
  28. Feb 24, 2020 at 11:26 AM
    #58
    I think I've seen enough photos of 4Rs with .85 front setting to just about settle the question. Looks like just the thing for me, or is at least a great starting point. New shocks, F&R (Eibach in my case, though) I can see being enough of a change to keep me and the wife happy. Stock sized C-load rated A/T tires will be the next decision.
    Thanks to everyone who contributed those photos - very much appreciated!
    ACM0302[QUOTED] and nimby like this.
  29. Feb 24, 2020 at 12:34 PM
    #59
    Motorjock721
    Motorjock721 New Member
    a
    2020 Gray SR5 4runner
    Food for thought? 5100'S all around. Front set at 1.75'' and one inch rear cornfed spacer. These are my beefy factory Duratracs 265/70/17. I am glad I went this route rather than .85 up front-no rear spacer. The ride is much better than stock.lift 2.jpg
    cpr81, Kfish, mcs040 and 1 other person like this.
  30. Feb 26, 2020 at 6:32 AM
    #60
    Damn you! Had my mind made up and you have to throw that in...:cool:
    JK, I'm pretty set on my decision. I think.
    Motorjock721[QUOTED] likes this.
