4Runners Live
Discussion in 'Off-Topic Discussion' started by Bob, Apr 5, 2014.
  1. Aug 22, 2014 at 9:28 AM
    #991
    brutalguyracing
    brutalguyracing New Member
    NY
    2003 V8 Runner Limited
    And yet i come home yesterday and still no lift installed
    Whats the deal
  2. Aug 22, 2014 at 9:30 AM
    #992
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    well i live in CT, don't know where you live, and am moving in 2 days
  3. Aug 22, 2014 at 2:31 PM
    #993
    brutalguyracing
    NY
    so you dont want the job then
    should have said that in the first place
  4. Aug 22, 2014 at 2:45 PM
    #994
    brutalguyracing
    NY
    Decisions decisions
  5. Aug 22, 2014 at 2:49 PM
    #995
    Emelianenkov
    Emelianenkov New Member Vendor
    Alex
    Andover, MA
    2005 V6 Sport Salsa Red Pearl
    I'll do the whole lift and everything for the kings :p
    But honestly, I'd do the install for some gas money and spending money
  6. Aug 22, 2014 at 3:59 PM
    #996
    brutalguyracing
    NY
  7. Aug 22, 2014 at 4:33 PM
    #997
    brutalguyracing
    NY
    I like it
    Except i tried clear in this one before i figured out krylon clear sucks azz
  8. Aug 22, 2014 at 4:34 PM
    #998
    brutalguyracing
    NY
    This side much better cause no clear
  9. Aug 22, 2014 at 5:05 PM
    #999
    brutalguyracing
    NY
  10. Aug 22, 2014 at 5:39 PM
    #1000
    Emelianenkov
    Alex
    Andover, MA
    I dunno, the rangers sticker looks bad on the truck
  11. Aug 22, 2014 at 6:19 PM
    #1001
    iambeckygoat
    iambeckygoat New Member
    Becky
    Methuen, MA
    2014 Super White SR5 4Runner
    I was thinking the exact same thing…
    Emelianenkov[QUOTED] likes this.
  12. Aug 22, 2014 at 6:28 PM
    #1002
    THatfield
    THatfield I like Toyota's
    Taylor
    Columbus, OH
    1999 Toyota 4Runner SR5 Highlander
    Someone must be pulling a sick prank on BGR. Poor guy.
    Emelianenkov and iambeckygoat like this.
  13. Aug 22, 2014 at 8:05 PM
    #1003
    wnelax04sr5
    Ethan
    CT
    put on toytecs, send kings to me
  14. Aug 22, 2014 at 8:13 PM
    #1004
    wnelax04sr5
    Ethan
    CT
    but really whichever ones you don't install ill buy
  15. Aug 22, 2014 at 8:59 PM
    #1005
    LTDSC
    Northern California
    Why would you not choose the kings
  16. Aug 22, 2014 at 10:54 PM
    #1006
    Emelianenkov
    Alex
    Andover, MA
    Because BGR
  17. Aug 23, 2014 at 8:01 AM
    #1007
    LTDSC
    Northern California
    I probably spelled my post too good. He will be so confused.
  18. Aug 23, 2014 at 8:50 AM
    #1008
    Emelianenkov
    Alex
    Andover, MA
    Down another 1.5 lbs and it ain't even Monday yet!
  19. Aug 23, 2014 at 4:24 PM
    #1009
    brutalguyracing
    NY
    Well holy hell
    I am getting to old for this chit
    Feels like i been on of them fatal fights
    Did not get near as much completed as i wanted to
    Rain moved in and back going out
    I manages to completely remove the xreas like a gentleman
    It was not too bad just time consuming
    Bye bye
    I removed the running boards
    Installed the kings
    But had to zip-tie the resi's
    As i can not find the weld on mounts i ordered months ago
    Ih well
    Then i installed the icon overland springs
    I did not remove any brake lines, panhead bar
    I did use a spring compressor tho
    No real issues there
    A second hand would have been awesome tho
    Then installed the icon shocks
    Dam why did they put the pinch weld so dam close
    I cut that chit back
    It made accessing the nut for xreas removal and shock install easier as well
    Then i installed the skyjacker ext sway bar links
    Just a fyi these come out
    They were in there pretty well
    But once i determined they had to go i made quick work of it with a bfh
    Found out my driver side front diff oil seal is leaking
    Thats just great i love gear oil and the pos seals
    Up front i Still need to do my inner and outer tre's
    Swap in my new lca's and bj's and greaseable cams
    And order new resi mounts
    Then for the rear i need to do the ext brake lines and rear rotors, pads, f ing stupid parking brake everything
    Also gotta love toyo and there placement of my ac drain on my frame rail
    Thats getting fixed
    Also found my center diff actuator vent line just hanging
    Weight reduction mod
    Need an alignment
    But have to finish suspension
    Then get my new tire balances and one put on the wheel
    Springs were not that much taller at all
  20. Aug 23, 2014 at 4:35 PM
    #1010
    Kelvin
    Kelvin New Member
    Keep those 2.0 Icon's well lubricated. Mine squeak like no other with any kind of slight shaft movement.
  21. Aug 23, 2014 at 4:38 PM
    #1011
    brutalguyracing
    NY
    Whata u using
    Tri lube
  22. Aug 23, 2014 at 4:47 PM
    #1012
    Kelvin
    Kelvin New Member
    I used triflow due to the recommendation from others but I'm sure any dry spray would work.
  23. Aug 23, 2014 at 7:15 PM
    #1013
    wnelax04sr5
    Ethan
    CT
    im so happy for bgr
    now what about those toytec ultimates?
  24. Aug 23, 2014 at 7:16 PM
    #1014
    brutalguyracing
    NY
    so happy?
    hell i have about 5 more days of freakin work to finish this
    errrrrr
  25. Aug 23, 2014 at 7:25 PM
    #1015
    wnelax04sr5
    Ethan
    CT
    so happy. sell me toytec ultimates sans 5100s
  26. Aug 23, 2014 at 7:52 PM
    #1016
    LTDSC
    Northern California
    The icon coil over do too. It's annoying but quick squirts of oil fixes for a little
  27. Aug 23, 2014 at 10:44 PM
    #1017
    Kelvin
    Kelvin New Member
    Ha...the rears were much worse. After awhile they both squeak simultaneously and get loud enough to be heard driving down the street with the windows up.
  28. Aug 24, 2014 at 4:58 AM
    #1018
    brutalguyracing
    NY
    Wonderful ^^^^^
  29. Aug 24, 2014 at 5:18 AM
    #1019
    brutalguyracing
    NY
  30. Aug 24, 2014 at 7:43 AM
    #1020
    Emelianenkov
    Alex
    Andover, MA
