4Runners.com Decals
Discussion in 'News and Announcements' started by Bob, Jul 7, 2015.
  1. Aug 12, 2021 at 11:21 PM
    #151
    rhussa
    rhussa New Member
    2010 Silver SR5 4Runner
    PM Sent!
    Bob[OP] likes this.
  2. Sep 5, 2021 at 2:46 PM
    #152
    erfer1
    erfer1 New Member
    Eric
    SW NM
    2019 Limited
    Received mine Friday. Thank you, Bob!
    Bob[OP] likes this.
  3. Sep 21, 2022 at 4:49 AM
    #153
    jsucraig
    jsucraig New Member
    Craig
    Lynchburg, VA
    2022 4Runner TRD OR/Premium - Nautical Blue
    Garmin Dashcam Mini2, FJ Shift Knob, Meso Customs Map Lights, LED Int/Ext Lights, Salex Organizers, Mudflap Delete, Uni Filter Mod, Amp Research Power Steps, Ceramic Tint
    Spare Parts and Bob[OP] like this.
  4. Jun 14, 2023 at 1:33 PM
    #154
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    Still available??
    Thanks!
  5. Jun 14, 2023 at 3:07 PM
    #155
    Bob
    Bob [OP] Member Staff Member
    Bob
    Yes!
  6. Jun 14, 2023 at 5:15 PM
    #156
    johnparjr
    johnparjr New Member
    New Caney, TX
    2023 4Runner Off Road Premium
    Message sent thank you
  7. Jun 9, 2024 at 6:21 PM
    #157
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    anyone else proud to run the 4Runners.com decal.
    for me, they’ve earned it!
  8. Jun 9, 2024 at 7:23 PM
    #158
    AsianAnts
    AsianAnts New Member
    '18 TRD Offroad Prem. BLK
    Too many to list.
  9. Jun 9, 2024 at 7:24 PM
    #159
    I took mine off because Im scared someone will recognize me and my posts. When in fact my neighbors burn something for mosquitoes or oil changes with stale gas and i cant take it my wife does not effect her?
    Acesandeights likes this.
  10. Jun 24, 2024 at 1:10 PM
    #160
    Valmet
    Valmet Some Might Say.
    Richmond, Virginia
    2016 Trail
    I need one of those…
  11. Jun 24, 2024 at 5:27 PM
    #161
    @Valmet
    I think the man the myth the legend @Bob can help
    Valmet likes this.
  12. Jul 11, 2024 at 10:10 AM
    #162
    4Rs .com decals in black finally arrived :cookiemonster:
    Bob[OP] likes this.
  13. Jul 11, 2024 at 10:53 AM
    #163
    steelevo
    Utah
    These in orange to match the solar octane color would look great
    djwantke and RusPro17 like this.
  14. Jul 11, 2024 at 11:16 AM
    #164
    Acesandeights
    Acesandeights #34
    2024 ORP
    I think this was one of the best posts I've read all day. Would have been even better without the period between sentences.
    Bob[OP] likes this.
  15. Jul 11, 2024 at 4:21 PM
    #165
    Bob
    Bob
    doable
    djwantke likes this.
  16. Jul 21, 2024 at 9:08 PM
    #166
    added a black one
    Bob[OP] likes this.
  17. Jul 24, 2024 at 4:46 PM
    #167
    Shredder
    Shredder New Member
    Galaxy 47
    23 OR
    Tires, shocks
    Take an edible, it makes sense then.
  18. Jul 25, 2024 at 6:20 AM
    #168
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    My runner is naked with out one, I’d like to fix that
    Maximumdarkside and djwantke like this.
  19. Aug 30, 2024 at 11:23 AM
    #169
    VMCOR3
    VMCOR3 New Member
    2006 Black 4Runner
    3 Inch old man emu lift kit ARB front Bumper 33x12 AT tires Engine tune
    PM sent! stocked bout the designs!
    Bob[OP] likes this.
  20. Oct 6, 2024 at 5:21 PM
    #170
  21. Jan 7, 2025 at 6:10 PM
    #171
    Mass4runner
    Mass4runner New Member
    2023 TRD ORP
    Anyone receive a decal recently? Been waiting about a year for mine:)
  22. Jan 7, 2025 at 6:23 PM
    #172
    Just nudge Bob bet he’ll hook you up
    Mass4runner[QUOTED] likes this.
  23. Jan 7, 2025 at 6:44 PM
    #173
    Spare Parts
    Southern Maine
    22 LR ORP
    Nope, even had a PM sent to me asking for my mailing address a while back.
  24. Jan 7, 2025 at 8:46 PM
    #174
    Mass4runner
    2023 TRD ORP
    I won't take it personally then.
    Spare Parts[QUOTED] likes this.
  25. Jan 8, 2025 at 4:43 AM
    #175
    Spare Parts
    Southern Maine
    22 LR ORP
    I haven't
    YET.
  26. Jan 8, 2025 at 6:58 AM
    #176
    Bob
    Bob
    Good :amen:
  27. Jan 8, 2025 at 4:49 PM
    #177
    the almighty Bob is a busy man
    don’t bite the hand that feeds !
    he even kindly sent white, and black, decals to America’s evil top hat for me
  28. Jan 8, 2025 at 5:15 PM
    #178
    vthoky New Member
    :D
  29. Jan 8, 2025 at 6:04 PM
    #179
    Mass4runner
    2023 TRD ORP
    I just want the decal while I still have a 4Runner:)
    Bob[OP] likes this.
  30. Jan 8, 2025 at 6:19 PM
    #180
    Understood my man
    Just so ya’ll know, I also had to send a couple reminders to get my decals each time, but it was worth it. Not everyone interacts so often on 4R’s. com it is a point of contention in their marriage :p
    You’re gunna stop being a 4Runner owner?
    If you have a 1st-4th gen, the act is forgiven. If not, a curse will most certainly be cast upon you.
