4runner Trd off road premium with KDSS and lift?
Discussion in '5th Gen 4Runners (2010-2024)' started by titan34, Jul 21, 2021.
  1. Oct 11, 2021 at 3:24 PM
    Roland
    Roland New Member
    I knew I'm going to have a strong following, no kidding. I let you know about the dents when I put mine to the test. :santa2: present.
    Thatbassguy and The last breed like this.
  2. Oct 11, 2021 at 3:29 PM
    The last breed
    The last breed New Member
    Muhammad
    Dying to get my hands on a 4Runner
    Your 4R looks army green in the second pic. Too many trees around I guess :)
  3. Oct 11, 2021 at 3:32 PM
    The last breed
    Muhammad
    Stop the tempetation guys, my stock 4Runner is fine. I have no more money ;)
    Thatbassguy and Roland like this.
  4. Oct 11, 2021 at 3:37 PM
    The last breed
    Muhammad
    I asked my boy, he says he is fine in stock :)
  5. Oct 11, 2021 at 4:01 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    To address your question of whether or not KDSS is worth it, I will give you my 2 cents worth. When shopping for my 2020 4R, I drove one with KDSS and one without. I can tell you that the ride quality is improved with KDSS, and is especially good at minimizing body roll when cornering. I really disliked the body roll on a 4R without KDSS. It is truly that noticeable. I have not lifted my 4R yet, but am going to limit a lift to no more that 2.5 inches based on my research of the potential risk to the KDSS system, which is expensive to repair.
  6. Oct 11, 2021 at 5:30 PM
    How well would titanium slide on rocks? Would they dig in?
    I wonder what the actual cost would be...
    Budbuilt makes stainless steel skids. They're expensive, but maybe worth it. :notsure:
  7. Oct 11, 2021 at 8:10 PM
    Roland
    Roland New Member
    Sliding on rocks, pretty much the same as steel or Aluminum. "Would they dig in" don't know. Will let you know working on mine.
    The prototype is always expensive, working on it, when everything is done and tested, I let you know.
    Chrome/Nickel alloys stainless steel 304 or 316 is ok not worth the money for skid plates; it's just steel with Chrome 14-18% - 8-13% Nickel and the more expensive 316 has some molybdenum added to it. Density is pretty much the same as steel (heavy), rust resistant, that's all.
    Titanium is far superior for skids IMHO, for now, I can only speak because of the properties. When testing in real life, I will have something to backup my statement.
    I think an important factor with Titanium is the reflection of heat, (steel, Aluminum, stainless steel all absorb heat, heating up protected components) besides the weight/strength relationship and being impervious to most chemicals and salts, makes Titanium a great prospect for this application.
  8. Oct 11, 2021 at 8:14 PM
    It sounds pretty nice! I'm just curious where the cost would end up compared to steel and aluminum. Obviously higher, but how much?
    My interest in the stainless sliders would be purely for the rust resistance. Not having to worry about coating them or touching them up would be sweet!
    The last breed likes this.
  9. Oct 11, 2021 at 8:31 PM
    Roland
    Roland New Member
    Something like this, between $2800 & $3500.
  10. Oct 11, 2021 at 9:11 PM
    That's really not that terrible if you'll use them.
  11. Oct 12, 2021 at 5:32 AM
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    OP: I have found TRAIL4R.com to be an excellent resource for all things 4Runner. Many of the writers speak highly of KDSS. Many articles on suspension and KDSS.
    https://trail4runner.com/
    Roland, Spare Parts and Thatbassguy like this.
  12. Jul 25, 2022 at 9:27 PM
    JK4RNew
    JK4RNew New Member
    JK
    2022 4R-ORP
    Dobinson Lift & UAC 2.5" F, 1.5" R
    @Roland I've got a very similar set up as you. Did you end up measuring your rear lift height before and after? I installed the 1.5" 505 coils but ended up with a bit more than expected ... rear hub center to fender height of 24.5". My stock height was around 22"
  13. Jul 26, 2022 at 12:11 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    PPF, Tint, Black out badges/Valances. Bilstein 6112's & 5100's
    Love the stance of your rig. Was this kit purchased from yotamafia by chance?
  14. Jul 26, 2022 at 12:59 PM
    josephp732
    josephp732 New Member
    2019 Silver Limited, 2021 White TRD OR Premium
    For the folks that are doing moderate lifts (2"-3") are you experiencing the needle bearing failure issue on the front differential? Has anyone been proactive with a ECGS bushing replacement?
    Nevin likes this.
  15. Jul 26, 2022 at 1:48 PM
    Thank you!
    I purchased everything from Performance Off-Road in Waukesha, Wisconsin. I went with them because they were local, and I needed fab work also.
    Nevin[QUOTED] likes this.
  16. Jul 26, 2022 at 1:50 PM
    I had my differential replaced just before I installed the lift (around 29K miles). I haven't had any symptoms with the new differential and 2.4" front lift yet. I'm at 81K miles now.
    josephp732[QUOTED] likes this.
  17. Jul 26, 2022 at 7:12 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    I know it's not 4runner related but I did do the ECGS clam shell bushing on my Tacoma when I had a OME lift installed. It got rid of the groan that I was hearing around 30-40MPH. I would recommend it, and will most likely install on 4runner once I decide on a lift.
