4Runner Stalking, er...um, SPOTTING with Charlie™ (5th Gen Edition)
Discussion in '5th Gen 4Runners (2010-2024)' started by PennSilverTaco, Sep 27, 2019.
  1. Nov 11, 2024 at 9:31 AM
    #631
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    Please see signature!
    2012 SR5; I had a feeling that this wasn’t a real TRD PRO, and Carfax confirmed it…
    November 10th, 2024:
    Warrington, Pennsylvania
    IMG_0669.jpg IMG_0670.jpg IMG_0671.jpg IMG_0672.jpg IMG_0673.jpg IMG_0674.jpg
    Texas-Gorilla likes this.
  2. Nov 15, 2024 at 10:43 PM
    #632
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2014 SR5
    November 15th, 2024:
    Horsham, Pennsylvania
    IMG_0858.jpg IMG_0859.jpg IMG_0860.jpg IMG_0861.jpg IMG_0862.jpg IMG_0863.jpg
  3. Jan 11, 2025 at 7:32 AM
    #633
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2023 TRD Off-Road
    January 10th, 2025:
  4. Jan 13, 2025 at 9:40 PM
    #634
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2024 TRD PRO
    January 12th, 2025:
    Philadelphia, Pennsylvania
  5. Feb 5, 2025 at 10:18 AM
    #635
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2018 Limited
    February 2nd, 2025:
    Doylestown, Pennsylvania
  6. Feb 5, 2025 at 5:15 PM
    #636
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I wanna blackout my garnish and valance like this
  7. Feb 6, 2025 at 5:05 PM
    #637
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    Enterprise does rent T4Rs, but they don’t commonly come through the branch where I work; I cleaned up this 2024 SR5 on Monday…
    February 3rd, 2025:
  8. Feb 10, 2025 at 3:32 AM
    #638
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2020 SR5 Premium
    February 8th, 2025:
  9. Mar 4, 2025 at 7:05 PM
    #639
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2011 TRD Off-Road (Carfax says it’s a Limited…?)
    March 4th, 2025:
    IMG_7182.jpg IMG_7183.jpg IMG_7184.jpg IMG_7185.jpg IMG_7186.jpg IMG_7187.jpg
    ratcoon likes this.
  10. Mar 9, 2025 at 6:44 PM
    #640
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2016 Trail
    March 8th, 2025:
    Oaks, Pennsylvania
  11. Mar 9, 2025 at 6:59 PM
    #641
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    It's a 2021, and Carfax says the trim level is Venture, which I have never heard of...
    March 8th, 2025:
    Oaks, Pennsylvania
  12. Mar 9, 2025 at 7:15 PM
    #642
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2023 TRD Off-Road
    March 8th, 2025:
    Oaks, Pennsylvania
    ratcoon likes this.
  13. Mar 10, 2025 at 6:53 AM
    #643
    Now that's curious - you've posted a bazillion photos of 4Runners, but never heard of a Venture?
  14. Mar 10, 2025 at 8:09 AM
    #644
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    No…? Is it a regional trim package not sold in Pennsylvania?
  15. Mar 10, 2025 at 8:36 AM
    #645
  16. Mar 10, 2025 at 4:32 PM
    #646
    344Takeoff
    344Takeoff New Member
    Ormond Beach
    2022 MIDNIGHT BLACK SR5 4WD
    Daytona Beach Belair Plaza Publix, 5th Gen Arctic White…with my Midnight Black in the background.
  17. Mar 11, 2025 at 4:01 AM
    #647
    Whaler94
    Whaler94 New Member
    Michigan, United States
    2023 ORP white
  18. Mar 12, 2025 at 9:32 AM
    #648
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    I’ve already got the Matchbox one!
  19. Mar 25, 2025 at 5:43 PM
    #649
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    m
    March 22nd, 2024:
    Oaks, Pennsylvania
  20. Mar 29, 2025 at 8:05 PM
    #650
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    My girlfriend and I went to a Tesla dealership to look around, and somebody apparently traded this TRD PRO for a Tesla! The former owner was removing the license plate shortly before I took the pictures...
    March 29th, 2025:
    Warminster, Pennsylvania
    hossler1788 likes this.
