4runner has power but no crank
Discussion in '5th Gen 4Runners (2010-2024)' started by Musa, Jun 20, 2024.
  1. Jun 24, 2024 at 6:22 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
  2. Jun 24, 2024 at 6:23 PM
    Musa
    Musa [OP] New Member
    2016 White 4Runner limited
    New battery in, still no response. I’ve got power throughout the car, just no crank as if it’s in some sort of “safety mode”.
  3. Jun 24, 2024 at 6:25 PM
    Mongoosvscobra
    Mongoosvscobra New Member
    Juan
    Sr5 4x4 bigwheel
    Nice hello kitty sticker
    push start without foot on brake and turn wheel to see if it "unlocks" if you haven't tried that.
    Musa[QUOTED][OP] likes this.
  4. Jun 24, 2024 at 6:26 PM
    Musa
  5. Jun 24, 2024 at 6:28 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    That's the best price I could find, usually it sells for around $441.
  6. Jun 24, 2024 at 6:28 PM
    Musa
    God Bless!!
    AuSeeker[QUOTED] likes this.
  7. Jun 24, 2024 at 6:40 PM
    Musa
    Update guys: After attempting multiple different ways to get the engine to crank and verifying the programming of the smart keys, I am going to check the ECU code B2781 code.
    The code “B2781” DTC Detecting conditions are:
    • Steering lock motor drive circuit is defective.
    • Both lock and unlock position sensors detect "ON".
    The trouble area is:
    “Steering lock actuator assembly (Steering lock ECU)”
    I found the hint bellow which applies to my problem in hand:
    “When the engine switch is off, the main body ECU may occasionally go into a non-active state called sleep mode. Therefore, before proceeding with the inspection, it is necessary to perform the following step to wake up the ECU:
    Before starting the inspection, open the driver door with the engine switch off. Then (with the engine switch still off) open and close any door several times at 1.5-second intervals”.
    However I tried to open and close any door several times at the 1.5-second interval to no avail.
    I will post the latest updates once I have more info, and I’ll post a step by step of how I solved the issue once I do solve it, fingers crossed ;)! Thank you to each and every single person that replied to this thread and chimed in!!
    AuSeeker likes this.
  8. Nov 17, 2024 at 5:00 PM
    socali33
    socali33 New Member
    any luck? Im in a similar situation and am curious your status/results. thanks!
  9. Nov 20, 2024 at 8:54 PM
    ilgl-tint
    ilgl-tint New Member
    2024 TRDPRO UDRGND
