4Runner Front Tweeter Speaker Mod
Discussion in '5th Gen 4Runners (2010-2024)' started by irfan0922, Sep 1, 2022.
  1. Mar 25, 2023 at 3:09 AM
    Matt83
    Matt83 New Member
    Northeast
    I did the Subaru tweeter swap as well. I am not an audiophile but I noticed a cleaner/crisper sound. Some complain they sound tinny but I did not experience that at all. The actual units themselves appear to be much better quality. Direct replacement, 10 minutes and done.
    Commited likes this.
  2. Mar 25, 2023 at 7:46 AM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    No non JBL. The stock speakers are just paper, the Sub/Kicker speakers feel and look well made.
    semprenissart likes this.
  3. Mar 26, 2023 at 3:29 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I also did the Subaru tweeter upgrade in my 2021 Off Road and am pleased with the sound improvement.
    That said, I’m not an audiophile and also unwilling to spend big bucks on a sound system but the $80 I spent on the new tweeters improved the system enough that I’m happy with it.
    Also, they are a direct replacement and are easy to swap in about 10 minutes or so…..
    Cheers,
    Bob
    dsnow and Commited like this.
  4. Mar 27, 2023 at 6:29 PM
    dsnow
    dsnow New Member
    Kansas
    2023 SR5P
    I also did the plug and play dash speaker swap. Definitely sounds better now, but it makes me realize how bad the door speakers are, the bass is so muddy. I am thinking about replacing the door speakers, there are some decently priced 6x9s on Crutchfield that would surely be an improvement. It is nice they include the brackets and wiring harness for free. I notice most folks mention they go with a component system with just woofers in the doors, but I can't see where it would hurt to put some 2 way speakers in there instead. If down the road I end up adding an amp, I will probably be glad to have the extra tweeters in the doors.
  5. Jul 17, 2024 at 4:34 AM
    Hayden_
    Hayden_ New Member
    Hayden
    2007 2wd SR5
    Daystar 2.5"/1.5", All weather mats, fire extinguisher
    Maybe I'm missing something here, but I have a 2019 TRD Pro w/ JBL and the swap to the Subaru tweeters are not plug and play, in fact it's a different connector entirely. Does the TRD Pro have a different dash speaker? I can upload pictures in a bit. Does anyone have a true plug and play recommendation? Unfortunately, after a small trip from home where my 4runner was parked in the sun, my driver side tweeter got cooked.
  6. Jul 17, 2024 at 1:49 PM
    The Subaru tweeters are not plug-n-play on the JBL system.
    Rocko9999 and Spare Parts like this.
  7. Aug 22, 2024 at 3:28 PM
    Villyn
    Villyn New Member
    18 black limited 4Runner
    None
    Subaru tweeter replacement is not plug and play with 4Runner jbl system. Clip on jbl system has a clip in center that does not allow Subaru tweeter to plug in. Disappointing but fact. On to the next replacement
  8. Aug 23, 2024 at 11:38 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Also, are the speakers the same impedance? Usually drop in upgrade tweeters having higher sensitivity ratings throwing off the balance-tweeters too bright.
  9. Aug 23, 2024 at 11:45 AM
    Yeah it's been known for a while and there is a solution but I don't remember what. The JBL system just makes things complicated.
    CalcityRenegade likes this.
  10. Aug 24, 2024 at 4:45 AM
    Villyn
    Villyn New Member
    None
    Yeah just disappointed that the jbl system has not matched the sound quality I had in my 07 sr5 4Runner. I bragged about how decent, imo, the sound system was in a base model truck. I thought when I purchased the 18 limited the sound system would be the same or better than the 07. Oh well, I guess Toyota didn’t want to create the perfect beast.
  11. Aug 25, 2024 at 10:58 AM
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    Completed the upgrade on my 19' SR5 and after readjusting the EQ its a noticeable improvement..
  12. Aug 25, 2024 at 1:31 PM
    Lost Woods
    Lost Woods New Member
    I had the same experience in my Taco but they settle in nicely after some play time. I was not impressed the first day. The only reason I like them is they're plug and play and don't mess with the factory setup. Otherwise I'd be doing Infinity tweeters too, they were awesome in my Jeep.
  13. Aug 29, 2024 at 11:27 AM
    TheSponge
    TheSponge New Member
    So the Subaru tweeters don’t fit the Limited models with JBL. What’s the solution? Is there a wiring adapter or similar?
  14. Aug 31, 2024 at 7:14 PM
    4RFever
    4RFever New Member
    Mac
    Portland
    2023 Blue 4Runner TRD Off Road Premium KDSS
    OEM Audio Plus Reference RCI Steel KDSS Engine Skid Plate RCI Aluminum Transmission Skid Plate RCI Aluminum Transfer Case Skid Plate RCI Lower Link Skid Plate FJ Toyman Shock Skids Toyota Rock Rails RCI Bumper Filler Plate DuroBumps Front and Rear SDHQ Billet ABS Guards Falken Wildpeaks 275/70R17 C Load DR. KDSS KDSS Control Switch Trail Grid Pro Front Camera
    I recently did the DS18 audio upgrade for the tweeters and can confirm they work better than the kickers. They come with a harness adapter for JBL equipped cars and you simply do not use the wiring harness if you have a non JBL truck.
    https://www.amazon.com/gp/product/B09HVCQZXF?ie=UTF8
    Guppy1301 likes this.
  15. Aug 31, 2024 at 7:15 PM
    4RFever
    4RFever New Member
    Mac
    Portland
    plus it's cheaper than the kickers so win win!
  16. Sep 1, 2024 at 5:59 PM
    TheSponge
    So these would work in a limited as long as the provided adapter is used? Since I’m in Canada these show as $110 vs the kickers being sub $90..
    Was the change worth it?
  17. Sep 3, 2024 at 1:23 PM
    4RFever
    4RFever New Member
    Mac
    Portland
    I can’t comment on if it’s better than the limited jbl speakers. They should work with the provided adapter you will just have to crimp the wires together.
  18. Sep 3, 2024 at 2:00 PM
    Rocko9999
    2011 Limited
    These are 4 ohm tweeters, stock JBL are 2 ohm. The levels won't be the same. That being said you may like the sound.
  19. Sep 3, 2024 at 9:58 PM
    #49
    legend1011
    legend1011 New Member
    2024 White 4Runner TRD Offroad Premium (No KDSS)
    I wish I could find some
    Tweeter pods/enclosures that look oem so I could build a nice 3 way setup… I might just go 2-way with a 2.5” speaker and 6 or 6x9 for the doors
