400w plug can’t power espresso machine
Discussion in '5th Gen 4Runners (2010-2024)' started by mattrsupplyco, Sep 17, 2023.
  1. Sep 18, 2023 at 4:49 PM
    Coffee can be a hassle on the road. Sometimes I will settle for tea.
    gomiami likes this.
  2. Sep 18, 2023 at 4:59 PM
    DesertSurfer
    Can it run a blender for a Margarita?
    pastoreater and Captain Spalding like this.
  3. Sep 18, 2023 at 5:05 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    No. Blenders are 500+ watts.
  4. Sep 18, 2023 at 5:11 PM
    DesertSurfer
    Darn it! Will have to drink the Patron with salt & lime, oh well, git er done!
  5. Sep 18, 2023 at 6:57 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    My goto is the 1500W outlet in the trunk of my Prius Prime. The car is almost a generator lol!
    Mity Quinn PDX likes this.
  6. Sep 18, 2023 at 7:13 PM
    Rocko9999 likes this.
  7. Sep 18, 2023 at 8:34 PM
    Toyota.ARK
    Toyota.ARK New Member
    2021 Magnetic Gray TRD-ORP
    We have a portable ecoflow River pro that powers our pixie Nespresso machine. It’s humble but gets the job done. The factory outlet trickle charges the EFRP while on the go until we get to a recharging setup.
    raimieb likes this.
  8. Sep 18, 2023 at 9:26 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    You would need to run a pretty big inverter off your battery. You'd either need to directly connect it. Or if hard wired replacing the stock inverter you would need HUGE cables for the length of the run and the amp draw.
    I went with a battery station for versatility and ease.
    Battery station that charges off the rear cigarette lighter while driving. Or solar.
    https://www.amazon.com/gp/aw/d/B0B9XB57XM?ref=ppx_pop_mob_b_asin_title
    And a small electric kettle, then instant coffee
    https://www.amazon.com/gp/aw/d/B0BCPZJ3CW?ref=ppx_pop_mob_b_asin_title
    The people I go with love me. If only for the coffee.
    LuLu likes this.
  9. Sep 19, 2023 at 2:07 AM
    MooreKen
    MooreKen 2023 TRD PRO “Solar Octane”
    Just a rule of thumb… if something produces heat then there is current thus Wattage (Power=Current x Voltage) thus 400Watts =3.5Amps x 110 Volts (roughly). Most coffee maker draw a lot more than 3.5 Amps. I think I did that right. Ohms and Kirchotfs law was many years ago for me….lol
  10. Sep 19, 2023 at 2:21 AM
    MooreKen
    If you love coffee and need it when the power is out find one of these on EBay. Given, I use natural gas which works when the power is out but this has to be one of my greatest purchases for emergency situations. (It is perked however). PS: Mrs Cleaver is always using one of these on “Leave it to Beaver”…lol
  11. Sep 19, 2023 at 8:18 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    If a coffee maker draws 3.5 amps at 110 volts then its pulling 385 watts. At 12 volts thats 32 amps it would be pulling from your car battery.
    Google says the average coffee maker takes 750 to 1250 watts which is up to 104 amps @ 12 volts.
    The small electric kettle I linked above is a low power unit @ 600 watts.
  12. Sep 19, 2023 at 8:30 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Yeah it's AC 400 watts. I think it might not be pure sine; or it may be dirty power because my power station won't charge from it even when told to only charge off 200 watts.
    I was mostly throwing that out there because while the outlet is AC, the power ultimately comes from a 12 volt car battery. You could upgrade the inverter but you would need to upgrade the wires for the 12 volt amp draw.
    MooreKen[QUOTED] likes this.
  13. Sep 19, 2023 at 8:32 AM
    MooreKen
    Yeah, I deleted my post after re-reading yours, I understand what you are saying now.
  14. Sep 19, 2023 at 8:47 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I don't think that was necessary, it showed you can't power much from that AC outlet.
  15. Sep 19, 2023 at 11:13 AM
    TRD5thgenner
    TRD5thgenner Not Very Well Known Member
    2021 4runner TRD Offroad Premium
    Ive powered a crockpot with it, worked good
  16. Oct 20, 2023 at 11:57 PM
    Fieldworks
    Fieldworks New Member
    2017 black limited 4runner
    This k-cup machine works just fine with the OEM inverter "Mainstays Single Serve Coffee Maker, 1 cup Capsule or Ground Coffee, Black, New, Model 202140" $20 from Walmart.
  17. Oct 21, 2023 at 12:19 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    That's volts, you need to know wattage but expresso requires watts. You should have bought a Ford Lighting
  18. Oct 21, 2023 at 12:20 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Coleman Peak 1. Boiling hot in 3 minutes
  19. Oct 21, 2023 at 8:06 AM
    #49
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Low powered blenders exist, I managed to find one under 400w at Walmart years ago. (Tailgating margaritas were essential at that time).
  20. Oct 21, 2023 at 8:08 AM
    #50
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    French coffee press
