4.0V-6 longevity issues?
Discussion in '5th Gen 4Runners (2010-2024)' started by EBray3230, Jan 26, 2024.
  1. Jan 26, 2024 at 4:01 PM
    #61
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Wheeling is not cheap. Change your diff fluids after serious water crossings too
  2. Jan 26, 2024 at 4:18 PM
    #62
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    One of my first mod
    djwantke and Mtnmonkey like this.
  3. Jan 26, 2024 at 4:21 PM
    #63
    Yotaholic
    Olympia, WA
    What's that?
  4. Jan 26, 2024 at 4:35 PM
    #64
    semprenissart
    semprenissart Mèfi
    Diff breather for the rear diff. I have a Y connection for the locker as well. Front is not needed as it sits high enough
  5. Jan 26, 2024 at 4:48 PM
    #65
    Yotaholic
    Olympia, WA
    How does it stop the water from getting in? You drown the pumpkin in the water, water will get in somehow
  6. Jan 26, 2024 at 4:51 PM
    #66
    semprenissart
    semprenissart Mèfi
    How does the water get in other than through the breather? The pumpkin is sealed otherwise you’d kill your diff at the first puddle
    icebear and Mtnmonkey like this.
  7. Jan 26, 2024 at 4:55 PM
    #67
    Daddykool
    Maybe he doesn't understand how you have it installed...?
  8. Jan 26, 2024 at 4:58 PM
    #68
    semprenissart
    semprenissart Mèfi
    It’s a hose that is connected to the breather vent on the differential and that sits as high as possible (or higher than water at least) to let air in/out so water doesn’t get sucked back in when water cools the diff during a water crossing (like a scuba essentially)
  9. Jan 26, 2024 at 4:59 PM
    #69
    Snake River
    Snake River New Member
    2022 Army Green 4Runner Off-Road Premium
    This seems like a reasonable question from a newby. I’m disappointed that so many members chose to mock the original poster rather then take the question seriously.
  10. Jan 26, 2024 at 5:04 PM
    #70
    Daddykool
    Yeah, I understand the concept, just don't need to do it in my case. But maybe Yotaholic doesn't understand that the fitment at the diff is watertight and won't allow water in. At least, that's what it sounds like.
    semprenissart[QUOTED] likes this.
  11. Jan 26, 2024 at 5:04 PM
    #71
    Yotaholic
    Olympia, WA
    The seal doen't help 100%, I am changing my diff fluid
  12. Jan 26, 2024 at 5:09 PM
    #72
    Yotaholic
    Olympia, WA
    Dude, you need to check your diff fluid from time to time, don't rely on that breather
    Daddykool likes this.
  13. Jan 26, 2024 at 5:29 PM
    #73
    Meh. I drive through water a lot. No breather relocation either. No signs of water entry, so far. Only 108000 miles, though. Since January 2019.
  14. Jan 26, 2024 at 5:44 PM
    #74
    Yotaholic
    Olympia, WA
    How many times have you changed your diff fluid so far?
  15. Jan 26, 2024 at 5:46 PM
    #75
    Oakboro, N.C
    typically every 30k on vehicles I have owned, with no external leaks.
    semprenissart, djwantke and Yotaholic like this.
  16. Jan 26, 2024 at 5:53 PM
    #76
    Several
    Pavo and Yotaholic[QUOTED] like this.
  17. Jan 26, 2024 at 6:45 PM
    #77
    semprenissart
    semprenissart Mèfi
    Yea diff breathers relocations are not a necessity. More of an insurance sort of things. As long as diff temp is hot enough and water not cooling it down then water is not going to get in because air wants to go out of the vent with inside heat (air goes from high temp to low temp, high pressure to low pressure. Science…) It’s really when diff temps get cold suddenly due to water cooling it too much that it risks sucking the water in the diff. And then you’d definitely need to drain it and change the fluids if that happens
  18. Jan 26, 2024 at 7:07 PM
    #78
    You guys and your extended diff breathers. ;)
    If I need to cross deep water, I bring a boat. :)
  19. Jan 26, 2024 at 7:09 PM
    #79
    semprenissart
    semprenissart Mèfi
    I bring floaties and a rubber duck :D
  20. Jan 26, 2024 at 7:27 PM
    #80
    I just drive in until I get nervous. Then I walk through with waders.
  21. Jan 26, 2024 at 9:52 PM
    #81
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
  22. Jan 27, 2024 at 6:33 AM
    #82
    It doesn't seem the OP is too bothered - he's started two threads, with the initial post being the only input in each...
    Slopemaster, Han4Run and djwantke like this.
  23. Jan 27, 2024 at 6:59 AM
    #83
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Just saw his other post about his 3rd gen with 400k. So maybe he is legitimately concerned about 300k+ mile reliability...
    That said, this is really an incendiary topic and should be treated as such.
    Hearsay, check
    Outlandish claims, check
    Literally asking for arguments, check
    Not contributing to conversation, check
    Han4Run, 5thToy and 2ndGen22re like this.
  24. Jan 27, 2024 at 7:29 AM
    #84
    EBray3230
    EBray3230 [OP] New Member
  25. Jan 27, 2024 at 8:27 AM
    #85
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    i will repeat what I replied to the OP’s PM to me where it was stated I/we must not understand that “some engines can be rebuilt but not Toyotas”…
    My reply:
    You started a thread about over 300K reliability (framing it as a longevity issue) on one of the most reliable engines Toyota ever made for your first post on the forum (without introducing yourself or providing any context) and have not participated in any meaningful way in your own thread. You know exactly what you were doing.
    That is the mark of a troll until proven otherwise.
    …0.03% of all vehicles survive to 300K miles. I would not call that a longevity issue.
    2ndGen22re likes this.
  26. Jan 27, 2024 at 9:50 AM
    #86
    Yeah the post title and the post itself had two separate issues. Engine longevity is one, and that’s pretty well known. But engine “rebuildability” is a separate thing.
    I guess it’s good to know it wouldn’t be worth trying to rebuild. Besides the cylinder wall thickness, I didn’t think about the vvti and how that could be its own headache with clearances and such.
    Theoretically, in a mad max type of situation that really justifies putting money into a vehicle that wore out it engine, there is a solution. I think we all know the answer to that problem :D The cockroach of all crate engines…
    Before anyone gags, imagine the fuel efficiency of an LS in a tired old 4runner. :anonymous:
  27. Jan 27, 2024 at 10:02 AM
    #87
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    3k interval with oem oil?!
  28. Jan 27, 2024 at 10:07 AM
    #88
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Some of us have kids and mortgages and wives, I'm sorry man but I can't afford to change my oil every 3k and change my diff fluid after dusty trips or water ways. Overkill and naive I say. Toyota knows more about what your Toyota needs than you do, then they wrote you a manual.
    Diff breathers are a pretty common mod, I've seen many on here, not a bad idea if you like the rush of driving through water. The man seems to care about his diff, knows more about his diff than you, that's why he added a breather, I feel like it's possible that he likely does check his fluid / change his fluid as per manual.
  29. Jan 27, 2024 at 10:10 AM
    #89
    Frustrates me when I see OP's start threads and disappear, and don't contribute.
    Reminds me of the famous BeachGirl thread with the rusty ass parts
    semprenissart and Thatbassguy like this.
  30. Jan 27, 2024 at 10:13 AM
    #90
    Thanks for quoting this reply, and adding to your confusing lack of interest or input in your own thread !
