3 Blink Turn Signal
Discussion in '5th Gen 4Runners (2010-2024)' started by 4runnerYC, Sep 10, 2015.
  1. Jan 25, 2024 at 4:37 AM
    #121
    STrooper
    STrooper Let’s Go Places!
    DM you!:thumbsup:
  2. Jan 25, 2024 at 6:31 AM
    #122
    Same here. PM sent.
  3. Jan 25, 2024 at 1:24 PM
    #123
    The one potentially set aside for me can be up for grabs. I realized that after not having this for the last 4+ years, I didn't miss it, and apparently don't need it after all.
  4. Feb 1, 2024 at 2:30 PM
    #124
    SROak
    SROak New Member
    2023 LTD
    none
    Question: What are the "arrival and departure lights?
  5. Feb 1, 2024 at 4:51 PM
    #125
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    When you unlock the vehicle, they’ll be on for a certain amount of time. Same with when you lock it. Gives some light to approach and leave the vehicle. I believe it defaults to 30 seconds
  6. Feb 1, 2024 at 4:55 PM
    #126
    Kezin
    Progress update on 2021+. Going to pull ignition and hazard positive from somewhere else. Using the 40 pin plug on the back of the instrument cluster is too much work just to pull two pins over to the new harness. Planning on pulling ignition from the 12V socket and hazard from right behind the hazard switch. New connectors are ordered
  7. Feb 9, 2024 at 4:28 PM
    #127
    onaquest
    onaquest New Member
    I'm still waiting for my SmartTap to show up. Has anyone installed their adapter from Kezin yet?
  8. Feb 10, 2024 at 2:27 PM
    #128
    Kezin
    onaquest likes this.
  9. Feb 10, 2024 at 3:06 PM
    #129
    SROak
    SROak New Member
    2023 LTD
    none
    That looks like police mode!
  10. Feb 10, 2024 at 3:44 PM
    #130
    Kezin
    It does catch more attention than regular flashers. One of the benefits of the module!
  11. Feb 29, 2024 at 5:43 PM
    #131
    vlanchet
    vlanchet New Member
    super excited for the 2020+, amazing work Kezin!
    Kezin likes this.
  12. Feb 29, 2024 at 5:58 PM
    #132
    Kezin
    Thanks! Full disclosure on the 2021+ (I think actually 2020+). I have a “working” module/harness right now that I’ve been using daily for about a month. Two caveats. Arrival and departure lighting from the SmartTap is not working and likely will never work. Second is that the Instrument Control Panel needs the ground from the turn signal to cancel the Lane Departure Alert when changing lanes. I have a couple ideas on how to make that work but trying to weigh the cost vs benefit.
    vlanchet[QUOTED] likes this.
  13. Mar 3, 2024 at 9:48 AM
    #133
    kevgru
    kevgru New Member
    Sent you a DM
  14. Mar 3, 2024 at 4:31 PM
    #134
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Finally got a chance to install the mount/harness from @Kezin and the relay! Mounts perfectly to factory mounting point and with the relay it works perfectly. I have multiple hazard strobe options and the tap/turn signal! Thanks for the great product!
    onaquest, 4 Sticks and Kezin like this.
  15. Jul 2, 2024 at 1:44 PM
    #135
    M-Bear41
    M-Bear41 New Member
    Mojo
    @Kezin any further updates on this? Just got a new to me 2023 ORP and after driving a tacoma with the 3 blinks, I need this on my 4runner!
  16. Jul 2, 2024 at 3:14 PM
    #136
    Kezin
    Unfortunately not. It’s working well enough for my liking so further iterations have been moved way down my priority list. It is getting hot here in Texas though so might mess around with the harness since it’s a mostly inside project.
    M-Bear41[QUOTED] likes this.
  17. Jul 2, 2024 at 4:09 PM
    #137
    M-Bear41
    M-Bear41 New Member
    Mojo
    Let me know if it comes to fruition, I'll definitely grab it from you!
    Kezin likes this.
  18. Jul 4, 2024 at 11:23 AM
    #138
    Emmantik
    Emmantik New Member
    This is definitely one of my favorite creature comfort mods! Thanks again @Kezin !
    Kezin likes this.
  19. Jul 6, 2024 at 6:25 AM
    #139
    Nash
    Nash New Member
    Nash
    2019 Toyota 4Runner TRDORP
    Who makes these? I'm very interested!
  20. Jul 6, 2024 at 7:13 AM
    #140
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    SEPA
    2023 PRO
    I'm Interested...
  21. Jul 6, 2024 at 8:22 AM
    #141
    Kezin
    I do. Send me a DM. If your signature matches your current vehicle, I can make one for you
    I’ll tag you when I get a complete 2020+ version. Right now lane departure alert has to be turned off or deal with it beeping when you change lanes even with your blinker on.
  22. Jul 7, 2024 at 2:57 PM
    #142
    Skillzo1
    Skillzo1 New Member
    Lloyd
    2018 Trd pro
    Pmed you also. Interested for 2018 pro.
    Kezin[QUOTED] likes this.
  23. Jul 7, 2024 at 6:17 PM
    #143
    Kezin
    Responded
  24. Oct 6, 2024 at 9:52 AM
    #144
    kevgru
    kevgru New Member
    After running the harness for nearly 6 months now, I have to say that it has been a nice quality of life upgrade and is going strong.
    I’ve gotten used to the single tap blinker functionality for lane changes in the newer Toyotas so now this is available in my 2015 4Runner along with all the other blink modes the SmartTap offers.
    Additionally, I’ve added the Diode Dynamics Tail-As-Turn kit (which swap the blinkers to the brake lights and turns the tail turn signal lights into brighter back up lights) and it’s been working flawlessly in this setup.
    onaquest, Kezin and STrooper like this.
  25. Oct 6, 2024 at 10:11 AM
    #145
    SROak
    SROak New Member
    2023 LTD
    none
    I also have been running Kezin's SmartTap harness modified for a 2023 4R LTD, and it works flawlessly. There was some issue with the power sourcing for the module (something different in wiring for '23 model), but I worked with Kezin until he got it figured out and now it's working perfectly. I highly recommend it!
    Only change I've noticed is that the blinker sound seems much quieter, so I've been that guy driving down the freeway "stupid, stupid, stupid"... But mostly I catch it before I get too far along. I use the turn signals for turns and the SmartTap for lane changes.
    Kezin likes this.
  26. Oct 6, 2024 at 10:13 AM
    #146
    SROak
    SROak New Member
    2023 LTD
    none
    Works well for my 2023 Limited
    Kezin likes this.
  27. Oct 6, 2024 at 10:29 AM
    #147
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Hence why it would be illegal, falls under dazzling lights. But cool nonetheless.
  28. Oct 6, 2024 at 3:08 PM
    #148
    SROak
    SROak New Member
    2023 LTD
    none
    Except here in California, where nothing's illegal any more.
    Ripper238[QUOTED] likes this.
  29. Oct 6, 2024 at 4:38 PM
    #149
    @Kezin is this technically doable with a 2010? Note I have a Canadian model with the turn signals as DRLs.
  30. Oct 6, 2024 at 6:44 PM
    #150
    Kezin
    2010 has a different part number for the flasher relay than 2014-2019 but the connector looks the same. As far as the replacement, it should not reduce functionality at all. One of the goals was to replicate existing functionality and add to it. There are a couple Canadians here that I’ve shipped 2014-2019 harnesses to that might chime in on the DRL functionality.
