3 Blink Turn Signal
Discussion in '5th Gen 4Runners (2010-2024)' started by 4runnerYC, Sep 10, 2015.
  1. Nov 28, 2023 at 12:23 PM
    #61
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Yes I am anticipating a write up on this - specifically if you are not worried about trailer wiring. Looking forward to it!
  2. Nov 28, 2023 at 3:10 PM
    #62
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    Yep. No more brake light to it. So you’ll need to do the full mod
  3. Nov 29, 2023 at 4:24 AM
    #63
    daveeasa
    daveeasa New Member
    David
    '02 Tundra, '05 Tacoma, '16 Tacoma
    Sorry, what specifically are you trying to do with the relays?
    If you're trying to combine brake + turn, curt has various modules for that. And if you're trying to split brake and turn from a combined source, there's a different curt module for that. The latter does have some lag with the turns on SR Tacomas per Johnny's testing. I don't have any vehicle with combined turn and drl as my '05 Tacoma doesn't have DRL, but I could test with the tow harness if I ever had spare time.
    Combine brake + turn Curt 59187 using external power
    Combine brake + turn Curt 56130 without external power
    Separate combined brake + turn Curt 56196
    4 Sticks, STrooper and Kezin like this.
  4. Nov 29, 2023 at 4:50 AM
    #64
    Kezin
    Awesome! The powered brake + turn is perfect. Don’t know why I didn’t think to check Curt’s offerings
    STrooper and daveeasa[QUOTED] like this.
  5. Nov 29, 2023 at 10:00 AM
    #65
    STrooper
    STrooper Let’s Go Places!
    How do we know which (Curts) to use for our 4R model year? Those Curts are on sale now and would be nice to buy it before they go up in price.
  6. Nov 29, 2023 at 10:54 AM
    #66
    Kezin
  7. Nov 29, 2023 at 12:30 PM
    #67
    STrooper
  8. Nov 29, 2023 at 12:31 PM
    #68
    Kezin
    Nope. Relays didn’t work correctly so they will be replaced by the Curt module
    STrooper[QUOTED] likes this.
  9. Dec 1, 2023 at 4:51 PM
    #69
    Kezin
    Emmantik, 4 Sticks and STrooper like this.
  10. Dec 1, 2023 at 4:57 PM
    #70
    STrooper
    That’s awesome! Where did you get the connector plugs to make the wire connections? Are you posting a diy? Exited to make this to my 4R. Thanks for making it possible for all of us!:thumbsup:
  11. Dec 1, 2023 at 5:25 PM
    #71
    Kezin
    No problem. Some of the wires are terminated correctly with the harness you posted and can be moved over to the correct connector with no modification. Others needed to be terminated with a different pin and those pins came with the connector. For all the other connections, I soldered. You could probably use a T tap or other solderless wire connector for the few that need more than one wire connected. I believe that’s just ground and turn signal output from the SmartTap although the turn signal output already comes with a spliced wire. I will post some sort of instructions although they will probably just be diagrams of the connectors and what wires need to be connected to them, not an actual electrical schematic because I don’t know how to make one of those
  12. Dec 1, 2023 at 5:58 PM
    #72
    STrooper
    By “wire terminated” you mean color matching the wires? What about the connector (below) and the pins, where can I get them?
  13. Dec 2, 2023 at 7:11 AM
    #73
    Kezin
    Part number for the connector is 90980-11973. This is for the male connector though. The female connector is what is needed to make it work. This can be found online from different retailers. Used to have a link here but it appears to be broken.
    Don’t follow that picture exactly. Wiring has changed since then. If you never tow, and have zero interest in keeping the trailer wiring in tact, then you can follow that first attempt. I’ll see if I can get some wiring instructions later today
  14. Dec 2, 2023 at 8:49 AM
    #74
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    If you're going to be changing/building wiring connectors, make sure to pick up a set of pin keys if you don't have them already. Makes all the difference and cheap too.
    Jason
    packetcollision and 2Toys like this.
  15. Dec 2, 2023 at 9:40 AM
    #75
    STrooper
    May be best to wait for @Kezin as he is drafting a DIY for everyone to follow and can provide guidance on how to install/remove the terminal from the connector.
    That’s a great pin kit! But may be too much to have around if you are not using it constantly.
  16. Dec 2, 2023 at 10:53 AM
    #76
    Kezin
    I have a set of those but ended up just using a pick instead. I like the handle on the pick more
  17. Dec 2, 2023 at 11:25 AM
    #77
    daveeasa
    daveeasa New Member
    David
    I’ll check, those may be 090IIU 18 way.
    ETA: nope, doesn’t look like a match. I can probably hunt them down though if I had them in hand. Or just buy from aliexpress in bulk.
    https://www.corsa-technic.com/item.php?item_id=1675
    if you want to send me a known good and tested unit I can reproduce and sell. And send you one in return which is crimped rather than soldered.
    onaquest, STrooper and 4 Sticks like this.
  18. Dec 3, 2023 at 7:36 AM
    #78
    Kezin
    Here is my crappy wiring diagram. I don't usually make wiring diagrams on any mods I do because there is no interest typically and I know how it's wired. The F11 connector with unknown part number needs to be set face down to match pins. You want the side you are pushing the pins through to be facing up
    4 Sticks, onaquest and Emmantik like this.
  19. Dec 4, 2023 at 8:46 AM
    #79
    Emmantik
    Emmantik New Member
    This is great! Great job on accomplishing this! Are you open to building a few and selling them? I am willing to pay for a plug and play product! If not, I would appreciate a dedicated write up on exactly how you accomplished this as there are a couple things I don't quite understand.
  20. Dec 8, 2023 at 9:36 AM
    #80
    Kezin
    Gonna run this for a few weeks and see if there’s any issues. Got a little too heavy for my liking with just a connector holding it up. 3D printed an enclosure that requires removing one nut on the old flasher relay bracket and replacing it with this:IMG_0783.jpg IMG_0784.jpg
    like2lean, onaquest, 4 Sticks and 2 others like this.
  21. Dec 8, 2023 at 10:02 AM
    #81
    Emmantik
    Emmantik New Member
    Looks great! Very professional looking!
    Kezin[QUOTED] and 4 Sticks like this.
  22. Dec 11, 2023 at 11:45 AM
    #82
    scooter
    scooter New Member
    Oh... I'm sure lots have been waiting for this! Make and sell!
    onaquest likes this.
  23. Dec 11, 2023 at 5:51 PM
    #83
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I still think this mod has safety concerns that need to be addressed.
    But that's just me. Sounds like others, not so much if at all.
    If a driver with this mod tries to move over on me, they'll get the horn and possibly some sign language.
    I retired with a CDL. I can and do appreciate a long signaled lane change.
    Habit leads me to still drive this way in my 4R or TJ.
    Ripper238 likes this.
  24. Dec 11, 2023 at 5:58 PM
    #84
    Kezin
    In what way?
    Very mature response to someone using their blinker
  25. Dec 11, 2023 at 6:00 PM
    #85
    alittleoff
    Steve
    406
    '16 TP
    You got no clue do ya.
    That's all from me.
  26. Dec 11, 2023 at 6:21 PM
    #86
    Kezin
    Seems like you chimed in without fully understanding the mod
  27. Dec 11, 2023 at 6:47 PM
    #87
    onaquest
    onaquest New Member
    Safety is always imporant, I appreciate you bringing this up to the group.
    Keep in mind the normal functionality is fully intact and unchanged:
    • The turn signal lever can be clicked up/down for left/right blinker signaling
    • Stays active until a turn is completed or until its manually clicked back to center
    What this thread aims to do is add a feature, which allows for multiple blinks without having to click the stock into a position
    • Activated by pushing the signal level up/down (lightly to make contact, but not clicking into position)
    • This feature is on many modern cars including other models from Toyota.
    • Here's a video from Toyota USA official showing the feature on a Corolla:
    https://www.youtube.com/watch?v=7LSMtQJIFvk&ab_channel=ToyotaUSA
    like2lean and Kezin like this.
  28. Dec 12, 2023 at 7:35 AM
    #88
    STrooper
    o_O... If the 3 blink turn signal was a "safety concern" it wouldn't be a standard feature on numerous vehicle brands.
    Kezin likes this.
  29. Dec 12, 2023 at 7:07 PM
    #89
    Kezin
    Reprinted the module bracket thing. First one had a small clearance issue with another module. It could have squeezed in, but I’d rather just fix it. Really the SmartTap needed to move forward just a little but the metal bracket interfered so I just moved it all the way to the front. It touches a wire bundle but should be fine. So far, no issues. I have noticed other drivers slow down and pay more attention when the hazards are on, which is good. Nobody seems to have gotten unreasonably upset about using a 4 blink to merge, and I was able to install some cheap Amazon 7440 LEDs in the rear with no hyper flashing. IMG_0793.jpg
  30. Dec 14, 2023 at 7:29 PM
    #90
    like2lean
    like2lean New Member
    I should hope not. Our last 2 new Fords have had the factory 3 blink and never even remotely upset anyone. 3 flashes are plenty and 4 is above and beyond. To the post above who suggests a very long signal, I reserve that for times when I "politely request" a merge where there is not room, not to simply change lanes as is the case 98% of the time.
    Kezin[QUOTED] and onaquest like this.
