2” vs 3” lift
Discussion in 'Suspension' started by Cram15, Oct 8, 2020.
  1. Apr 17, 2021 at 8:04 AM
    LPFE42
    LPFE42 New Member
    Kenneth
    21 4Runner
    Hello All,
    what's a good setup for a 21 4runner OR with KDSS?
    3''- 2'' maybe?
  2. Apr 17, 2021 at 8:20 AM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    2" for the rear and 3" for the front to level it out. Select coil springs with your final front/back build weight in mind.
  3. Apr 17, 2021 at 9:54 AM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    I have a separate thread on here titled Elka, which addresses this. Elka’s suspensions are KDSS specific. Lift height depends on your needs, or preferences, but IMO 4 Runners look best with a modest lift that isn’t too ungainly. They have tremendous high speed driveability, which is unique for such an off road worthy vehicle that’s worth preserving.
  4. Apr 17, 2021 at 10:45 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    You want the front end slightly lower than the back so when you load the truck up the ass doesn’t sag too much.
    LPFE42 and Thatbassguy like this.
  5. Apr 17, 2021 at 10:52 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    https://www.4runners.com/threads/elka.15163/
  6. Apr 17, 2021 at 11:17 AM
    Here's mine at 2.3/1.5" on Bilstein 6112's and 5100's. Tires are 295/70/17 (33.5 × 12 ×17).
    Also, every worthwhile suspension manufacturer has options specifically for KDSS equipped 4runners. Eibach and Bilstein are the most popular entry level setups, and as you spend more, Fox, King, Elka, Ironman,and Radflo are all excellent options.
    I agree with this. Unless you're hardcore rock crawling, a large lift is unnecessary.
  7. Apr 17, 2021 at 5:54 PM
    LPFE42
    LPFE42 New Member
    Kenneth
    21 4Runner
    Think ill be going with the Bilstein 6112's
    99% it will be on road its my wife New 4runner
    Toy4X4 and Thatbassguy[QUOTED] like this.
  8. Apr 19, 2021 at 10:12 AM
    ThEoNe1
    ThEoNe1 New Member
    Drew
    2018 YOTA 4runner TRD OR
    LED s Emblems
    This is an "EIBACH" with ICON Deltas UCAs ... still sitting on stock 265.70.17s... I am in the process of researching a 285/75/17 on the stock TRD rim... will it rub ??? blah..blah...blah
  9. Apr 19, 2021 at 10:18 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
  10. Apr 20, 2021 at 9:31 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Love it! Cheers to the low-lift gang.
  11. Apr 20, 2021 at 11:19 AM
    I too followed Ronny dahl's Hilux build and started thinking about BP-51 again.
    I was thinking for changing the lift on my Limited and my highest priority is comfort. From what I looked at BP51 seems to be the most comfortable setup there is even better than Kings / ELKA / Fox DSC. I could be wrong since this is based on Youtube. But when I saw Shock Surplus video seeing the whole shock body tend to spin when you adjust the settings I gave up looking at BP-51.
  12. Apr 20, 2021 at 11:46 AM
    DRH
    Dave
    Santa Clarita, Ca
    2020 ORP
    I too looked at the BP-51s but saw too many negative reviews. I decided on the Dobinson MRAs and was very pleased with the adjustable ride settings for comfort or performance.
    kmeeg[QUOTED] likes this.
  13. Apr 23, 2021 at 9:02 AM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    Getting 2” won’t necessarily spare you from rubbing, alignment issues, or needing UCAs.
  14. Apr 23, 2021 at 9:05 AM
    No amount of lift spares you from rubbing, really. Alignment and trimming are the only ways to deal with rubbing, aside from wheel offset and tire size.
    nimby and LandCruiser[QUOTED] like this.
  15. Apr 23, 2021 at 10:27 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    ^ I disagree. Lifting does alleviate rubbing, but of course only to an extent. More lift does mean less rub, though. Until you put bigger tires...
    My 275's rubbed bad at OE height, and is completely gone when lifted 2". If you lift so much that the body and fenders are not even around the tire anymore.. how would you rub? ;)
  16. Apr 24, 2021 at 6:00 PM
    beankozi
    beankozi New Member
    Jarrett
    Vancouver Island
    2021 Venture
    quite a few
    you would rub if you were articulating.... your tire is still able to travel just as far up into your wheel well after a lift.
    nimby, Mtbpsych and Thatbassguy like this.
  17. Apr 24, 2021 at 8:55 PM
    4Runner170V
    4Runner170V New Member
    Tony
    Los Angeles
    2014 4Runner Trail
    FOX 2.5 W/RES AND ICON UCA IN THE FRONT, FOX 2.0 W/RES AND ICON 2" SPRING IN THE BACK. 3" FRONT AND 2" BACK LIFT AND PERFECTLY LEVELED NOW.
  18. Apr 24, 2021 at 9:54 PM
    This is incorrect. Lift only reduces rubbing on level ground. You don't think it rubs because you haven't flexed the suspension. Stuff that 275 into the wheel-well and see what happens.
    Exactly!
    SlvrSlug and Mtbpsych like this.
  19. May 6, 2021 at 10:11 AM
    #49
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    So you guys are saying that the tire will always go as far into the wheel after a lift?
    I want to disagree with that....
    If spacers were added on top of the front top hats, how could the tire ever go as far up?
    Under the same amount of articulation, I used to rub, and now I do not. To me, that is the lift alleviating the rub. Sure, it may still be possible for that rub to happen if the max articulation occurs, but it is far less likely to happen, because the lift is always trying to "be there," which keeps the tire farther from the body. Without the lift, the rub would be sooner/worse. I get what you guys are saying, though.. "It's still possible." But the lift does help. At least, that's how I look at it. Maybe I'm wrong.
  20. May 8, 2021 at 1:26 PM
    #50
    Trd361
    Trd361 New Member
    Victor
    South Texas
    2015 Limited 4x4 PW
    In this pic what are
    what size tire you running here?
  21. May 8, 2021 at 4:21 PM
    #51
    285/70 / 17
