295/70/17 Much Worse Than 285/70/17?
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, Feb 13, 2024.
  1. Jul 11, 2024 at 6:25 PM
    #61
    DBow14
    DBow14 New Member
    Don
    Bronco Badlands
    lots
    Following threads like this ahead of time figuring out what I'm gonna do when it's time, never thought of the pizza cutter option, BUT it's only one width less than the stock and it makes it a true 33+, AND they appear to be e rated and cheaper than the other options. Thanks, I will have to really considering this tire size.
    What about rubbing issues? I have a 2" level kit on and if I remove my mud flaps, would I still have clearance issues? Also considered those viper cuts for the front bumper. Any info would be appreciated guys.
  2. Jul 11, 2024 at 7:36 PM
    #62
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Lol I came to the realization recently that I can’t fit skinnies on my 9”wide wheels. Oops
    Now I’m interested in skinny 35’s like a 35x10.5 or 35x11.5. But looks like in Canada, I’m not finding those sizes ever, searched Michelin, Yokohama, BF Goodrich, Mickeys, etc. and can’t find yet.
  3. Jul 11, 2024 at 9:00 PM
    #63
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Didn’t realize this thread was still going. I decided to go with 285/75/17 A/T4w’s.
    The rig handles them great. No need to regear in the flat plains of Texas.
  4. Jul 12, 2024 at 5:55 AM
    #64
    1SilverRunner
    Tejas
    Really just depends on a few factors like wheel offset, tire size and caster.
    Keep in mind a lift won't help you fit big tires on these things. Only trimming will.
  5. Jul 28, 2024 at 11:03 PM
    #65
    black_diamond_express
    black_diamond_express New Member
    Uddy
    2024 Black 4Runner
    Ironman coil-over 3-2 Pan-hard corrected, KMC XD Grenade, BFG KO2 275/70R17, Sherpa EC Crestone, C4 Fab Summit Hatch
    Yes but are SL worthy for any serious trail driving? I mean Colorado trails are pretty rough on the tires and I have had friends suffering from multiple punctures/rips/sidewall blowouts running C rated tires.
  6. Jul 29, 2024 at 4:03 AM
    #66
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    I cannot answer that because I don’t off road with my 4runner. Mine is a daily commute occasionally and more for the winter months. So someone who off road would have to answer that question.
  7. Jul 29, 2024 at 4:39 AM
    #67
    Good call sticking with an SL. I've seen where the LT versions of some tires have less siping than the SL versions, so the SL will actually be better in snow.
    RusPro17[QUOTED] likes this.
  8. Jul 29, 2024 at 5:07 AM
    #68
    RusPro17
    Don
    Pa.
    Thanks James, I have posted about these Mickeythompsons Baja boss tires on numerous posts. I think they are a great tire when I tried them in the snow when I had my 265’s so I believe the 285’s won’t be no different. The only thing I noticed changing size was the bigger tire as for power loss did not feel anything at all cause of the 4lb difference.
  9. Jul 29, 2024 at 11:29 AM
    #69
    DBow14
    DBow14 New Member
    Don
    Bronco Badlands
    lots
    I didn't post this initially for some reason, but the tires are E rated Nitto Ridge Grapplers 255/80-17, so like 33.3" tall and I guess they'll still fit on the stock rims, no problem.
  10. Jul 29, 2024 at 12:02 PM
    #70
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    I have the same size lift you do (2") and I exclusively run skinnies on my trucks and have for decades (both standard height and lifted, two Tacos, two 4Runners...not all at once lol). I ran 255/85R16's up until my newest 4Runner, and now 255/80R17's. My Toyo Open Country MT's are 33.3", just like the ones you're looking at. As Thatbassguy pointed out in his earlier post in this thread, people here and on Tacomaworld absolutely love skinnies. The performance is excellent, and they require the least modification. I removed my front mud flaps and then did the fender liner mod to get mine to fit without any rubbing whatsoever. 255/80 is basically the only true 33" size tire you can run on these rigs without the body mount chop, which is one of the biggest reasons they are so popular.
    Thatbassguy and DBow14[QUOTED] like this.
  11. Jul 29, 2024 at 8:47 PM
    #71
    DBow14
    DBow14 New Member
    Don
    Bronco Badlands
    lots
    Very nice, it's funny, these "pizza cutters", allegedly skinny tires don't really look that skinny, I guess since they are really only one size more narrow than a stock tire, maybe if they were side by side with a fat tire, you'd notice more difference. Yeah, it seems that's the way to go. That will be my next upgrade along with the APex sway bar disconnects. Gives me some articulation and ground clearance without fooling with the suspension much at all. I think I'll run that for a while and see how she does.
