295/70/17 Much Worse Than 285/70/17?
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, Feb 13, 2024.
  1. Feb 13, 2024 at 3:19 PM
    I feel like at this point the ridge grap is an older tire, and even some of other Nitto offerings are better. Sometimes it's tough though, finding the tire that you want in the size and load range that you want.
  2. Feb 13, 2024 at 3:20 PM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I really like the RGs and I will likely stick with them when I move to 295s. They are very tough tires. I've folded these C load range tires up pretty bad on the rocks and they held up great. They are quiet enough on the road. They are easy to balance and have retained their balance well. Overall I'm very pleased with them.
    Since they are a hybrid terrain (All terrain/ and Mud Terrain) they work very well off road are impressive in the mud (although I do try to avoid mud when I can.)
    My only critique for them is their performance in light rain or ice. I'd say if you lived in further north you would probably be better suited with a different tire. In Texas though, these things rock.
    Thatbassguy and Trail Runnah like this.
  3. Feb 13, 2024 at 3:24 PM
    Sounds like a winner then. Good to know about the strength, that's a great review. I'm in the Northeast, that's why they're not a very attractive option to me, I've heard bad things about them in winter weather.
  4. Feb 13, 2024 at 3:39 PM
    1SilverRunner
    Tejas
    Yea there is not a lot of siping in the design. It does clear standing water well enough and is fairly resistant to hydroplaning in my experience.
    But a slick road + light rain or ice? Pretty lack luster performance.
    If I lived in the northeast it would not be my first choice. Switching out tires with the seasons like @Thatbassguy described is probably one of the best options.
    Texas weather is like taco bell hot sauce. Hot, Mild, or Fire.
    It doesn't get cold and rainy enough to dictate a tire change.
  5. Feb 13, 2024 at 3:56 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Those are very good points and solid feedback.
    Absolutely do them again then.
    I will say that that sounds exactly like Mickey Thompson Baja boss including being a hybrid, except they actually do rock in snow and rain.
    Can I ask you this have you ever ran another all-terrain tire to compare with tho
    Trail Runnah likes this.
  6. Feb 13, 2024 at 3:57 PM
    I'm only asking because it drives me nuts when people tell me they love for instance ko2s and are going to stick with ko2's and their ko2s are great but all they ever had is ko2s
  7. Feb 13, 2024 at 4:00 PM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    I love the Nitto ridge grapplers look. And had them on my 20 AG Pro. Did not like them in the rain and snow. So far my Mickey tires been great in the rain and snow.
  8. Feb 13, 2024 at 4:00 PM
    1SilverRunner
    Tejas
    Never as a daily. I’ve driven a few vehicles with all terrains but never got to see how they performed in different conditions throughout the year.
  9. Feb 13, 2024 at 4:02 PM
    Gotcha, hell I don't have a lot of experience with a variety of A/T's either
  10. Feb 13, 2024 at 4:54 PM
    But but but I really do love my K02s! And they really are the best tire ever. So good in fact, I don’t need to try anything else ever! :p:p:D I’m just kidding……
    although it’s true :poking:
    :anonymous:
  11. Feb 13, 2024 at 5:52 PM
    HazOpRed
    HazOpRed 22' TRDOR
    Just go skinnies. You will have every problem in the world if you don't
  12. Feb 13, 2024 at 6:11 PM
    Hmmmm.. I don't run skinnies, and I don't have problems. I definitely don't have "every problem in the world."
  13. Feb 13, 2024 at 6:17 PM
  14. Feb 13, 2024 at 6:21 PM
    Oh right you do have ko2's dont you?!!! Hah
    But you don't live in British Columbia so I'll relax
  15. Feb 13, 2024 at 6:43 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Which brand comes in that size?
  16. Feb 13, 2024 at 6:45 PM
    Stoney Ranger
    Stoney Ranger Lockers? Pffft
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-F/R Bpr-Winch-Stickers-ALF
    Same could be said for me.....but Falken Wildepeaks instead of KO2's.
  17. Feb 14, 2024 at 5:21 AM
    1SilverRunner
    Tejas
    Oops must have been a typo. I meant 285/75/17.
    I stand by my mistake and refuse to edit it out :sadviolin:
  18. Feb 14, 2024 at 7:10 AM
    semprenissart
    semprenissart Mèfi
    Oh man! you had me intrigued. I was thinking "275/75, a 33in tire that is not as wide as a 285/70 but with more side wall, that seems interesting"
    in between a 285/70 and a 255/80 in terms of width/sidewall and slightly taller than both yet not as big as a 34in tire. I wonder if it exists?
  19. Feb 14, 2024 at 8:40 AM
    #49
    1SilverRunner
    Tejas
    Only one I can think of is the Toyo AT3 in 34x10.5R17.
    It's 33.5" tall, 10.6" wide.
    It's kind of a goldilocks tire size for a lot of IFS vehicles.
    My problem is I like my 285 tires and don't really want to lose an inch of tire width.
    If I was sticking with my 7" wide TRD wheels a 255/80/17 or Toyo's 34x10.5 would be ideal.
    Personally I'll go with 295s and add a power steering cooler before I run pizza cutters xD
    But I definitely understand the argument for them and they make a lot of sense for many rigs out there.
  20. Feb 14, 2024 at 8:44 AM
    #50
    semprenissart
    semprenissart Mèfi
    pizza cutters definitely don't look as cool as wide tires but they have a lot of usable benefits from being lighter to having a better deformation profile.
    https://www.youtube.com/watch?v=6wAJAOxh8LE
  21. Feb 14, 2024 at 8:46 AM
    #51
    1SilverRunner
    Tejas
    ^ Correct.
    But I believer the Tinkerer himself said he'd be sticking with wider tires :headbang:
    Shredder and Thatbassguy like this.
  22. Feb 14, 2024 at 9:33 AM
    #52
    I think the deformation has a lot to do with the specific tire brand and style, as well. I posted this awhile ago on Tacomaworld:
    "I was a little curious so I did my own little test with two 2x4's stacked. This is significantly taller and wider than his 2.5 inch tube. I didn't take any actual measurements though. Just took some pictures.
    At 32 PSI, which I am running on the street:
    15 PSI, which is where I usually start out off-road.
    12 PSI, which I typically run if I know I'm going to be doing technical stuff.
    10 PSI, which I generally don't run, but might drop to if I was stuck, or trying to get extra traction for an obstacle.
    8 PSI, which it was as low as I felt comfortable going. I don't think I would ever run this low without beadlocks, but I have heard of people running 8 psi.
    I don't know if it is due to the smaller tire, or the fact that this is MT, but, even without measuring, It's obvious that my 295/70/17 deformed much more than the 315 AT he was testing. Even at 15 PSI, my tire began to wrap around the 2x4.
  23. Feb 14, 2024 at 3:20 PM
    #53
    semprenissart
    semprenissart Mèfi
    I think it also depends on the tire brand and model as well. When he compared his wide personal tire to the skinny from his testing they were similar. What I like is that when he compared both sizes he used the exact same tire brand and model. So in that case the skinny had better deformation that its counterpart
  24. Feb 14, 2024 at 3:30 PM
    #54
    HazOpRed
    HazOpRed 22' TRDOR
    You missed the point and I know you know lol
  25. Feb 14, 2024 at 3:34 PM
    #55
    When I read this I kind of laughed and thought to myself he's not wrong who is pulling their hair out to accommodate tall skinnies, I don't hear much of that
    semprenissart and Trail Runnah like this.
  26. Feb 14, 2024 at 3:35 PM
    #56
    I took it as sarcasm, but I don't disagree that skinnies make much more sense on this platform.
  27. Feb 14, 2024 at 4:37 PM
    #57
    I can never tell when people are joking around here. :notsure:
    1SilverRunner[OP] and djwantke like this.
  28. Feb 14, 2024 at 4:44 PM
    #58
    True. I'd like to see a comparison between wide and skinny MT's, or different AT's, though. Plus, bigger tires are going to react differently, so I'd like to see a comparison of tire sizes that are more common. The fact that the 35's didn't even wrap around the pipe at 0 PSI makes me think that those tires are just too stiff for a good comparison.
    I'm not saying that there aren't advantages to skinnies. I just don't think you can base everything on a comparison of one specific tire, in a size that very few of us will ever use.
  29. Feb 14, 2024 at 5:48 PM
    #59
    semprenissart
    semprenissart Mèfi
    Yes I agree with you. I would really like a direct comparison with a smaller size and maybe different type of tire like an MT as you said. I still believe skinnies are underrated mainly because of the look factor. We almost always see older rigs like older land rovers and land cruisers with skinnies. They are tried and true and I believe are the best for most scenarios (Swiss army knife of tires). Wide tires will perform better in certain extreme environment that require flotation like mud or deep snow (like in Iceland for example, although these tires are FAT). However most people in the southwest will benefit from skinnies based on the terrain.
    I also think that the “need” for big tires has gone a bit over board mainly in the jeep community. 31 to 33s use to be plenty fine. Then 35s became the new 33s, then 37s are the new 35s, and now it’s almost 40s minimum lol
    don’t get me wrong big tires look good, but is it really necessary for 99% of what people do? 33s are a perfect balance IMO between on and off road for most obstacles other than hard core rock crawling
    DBow14 and djwantke like this.
  30. Feb 14, 2024 at 6:13 PM
    #60
    I agree with most of what you've said, except that skinnies are underrated.
    Half of the people on this forum and Tacomaworld gush over skinny tires, so I really don't think they're getting a lack of credit. Pretty much anyone who knows what they're talking about considers them an ideal choice for most types of off-roading.
