285/70R17 fit on a stock 2018?
Discussion in '5th Gen 4Runners (2010-2024)' started by WhoDoiFollow, Mar 10, 2018.
  1. Sep 1, 2021 at 7:54 AM
    #61
    If you are are going with 285-70-17 tires TRD PRO OEM wheel should be out of your list.
  2. Sep 1, 2021 at 8:09 AM
    #62
    Ronkirby22
    Ronkirby22 New Member
    2019 Toyota 4Runner
    2 inch lift in front 1 in back.
    Thank you for pointing that out. Very helpful
  3. Sep 1, 2021 at 3:00 PM
    #63
    I'm running 285's on Pro rims. Works great, no issues.
    That's what the local dealership does here. Tons of 4Runners and Tacomas with this setup in my area.
    Roland and Evo03 like this.
  4. Sep 19, 2021 at 5:54 PM
    #64
    jsantoli
    jsantoli New Member
    Joe
    2021 Off Road Pro 4 Runner
    285/70/17 3” lift Trd pro grill with raptor lights
    Hey guys, new to the forum. My question is this. I picked up 5 285 70 17 KO2’s today. My lift kit is being delivered on Thursday but we are heading out for the weekend Saturday morning. I wanted to try and get the tires mounted to my rims Thursday and install the lift Friday. Would I be able to drive the truck 2 miles with the 285’s on a stock height Trd off road 4 runner?
  5. Sep 20, 2021 at 6:33 PM
    #65
    jsantoli
    jsantoli New Member
    Joe
    Anyone? Trying to save some time and do the tires prior to the lift because of weather
  6. Sep 20, 2021 at 6:40 PM
    #66
    What are the new rim specs? Do you know their offset?
  7. Sep 20, 2021 at 6:42 PM
    #67
    jsantoli
    jsantoli New Member
    Joe
    They are the factory Trd pro rims
  8. Sep 20, 2021 at 6:53 PM
    #68
    Hope you don't need to make tight turns.
    I personally wouldn't do it.
    Mtbpsych likes this.
  9. Sep 20, 2021 at 6:54 PM
    #69
    Yeah, you should be fine to drive it. Depending on your current alignment, you could get a little rubbing on the mudflap or body mount on tighter turns or bumps, but nothing bad enough that will hurt anything........unless you're sending it. You could also have no rubbing at all........just depends on that alignment.
    Your best bet is to just drive it normally with the 285's mounted on your way to the shop. Don't try a "Dukes of Hazzard".
    Mtbpsych, Roland and Thatbassguy like this.
  10. Sep 20, 2021 at 6:57 PM
    #70
    jsantoli
    jsantoli New Member
    Joe
    The shop doing it is a straight shot down my street. Maybe 20 houses away
  11. Sep 20, 2021 at 6:58 PM
    #71
    You'll be fine.
  12. Sep 20, 2021 at 7:00 PM
    #72
    jsantoli
    jsantoli New Member
    Joe
    Awesome thanks so much !
    Thatbassguy and nimby[QUOTED] like this.
  13. Sep 20, 2021 at 7:04 PM
    #73
    jsantoli
    jsantoli New Member
    Joe
    Straight down the street. Only turn is into my driveway
  14. Sep 20, 2021 at 7:13 PM
    #74
    2 miles on city streets shouldn't be that big of a deal. Just take it easy in and out of the parking lot entryway if it's elevated.
  15. Sep 20, 2021 at 7:21 PM
    #75
    There are people that run 285's on stock SR5's, Offroads, and Pros with no rubbing.
    Not saying you won't rub but lift isn't the determining factor for tire rub with our vehicles.
    It's mainly alignment and wheel specs (offset).
    If you do rub when you put your 285's on @jsantoli, you will most likely still rub with your lift on.
    You'll need to dial in your alignment or do a body mount chop/mudflap trim to get rid of it.
    hossler1788 and Roland like this.
  16. Sep 20, 2021 at 7:25 PM
    #76
    I was going to mention this, but you beat me to it!
    Lift does not clear tires! Alignment, trimming, and offset clear tires. :)
    Roland, SlvrSlug and nimby[QUOTED] like this.
  17. Oct 11, 2021 at 6:10 PM
    #77
    jsantoli
    jsantoli New Member
    Joe
    I got everything squared away. Had to take off the front mudflaps and I get slight rub at full turn but it’s not bad at all
  18. Oct 11, 2021 at 6:34 PM
    #78
    Looking good!
  19. Apr 20, 2023 at 3:02 PM
    #79
    lucasahall
    lucasahall New Member
    Lucas
    2020 SR5 Premium
    285/70/r17 tires. Viper cut.
    This was very helpful. Just added 285/70/r17s to my 2020 SR5 Premium. All I did was a small viper cut on the front fender. Didn't have to remove the flaps in the front. Also used the TRD pro rims that came with my truck.
  20. Apr 20, 2023 at 4:49 PM
    #80
    Stock height?
  21. Apr 20, 2023 at 5:33 PM
    #81
    lucasahall
    Lucas
    2020 SR5 Premium
    Yes, stock height. I ran some reverse left and right lock and forward left and right lock at various speeds and I have a smidge of rub on the mud flaps. I will remove them and use a heat gun to remold them a little. But stock height. I plan on doing a 2-2.5" lift within a couple of months.
    nimby[QUOTED] likes this.
  22. Apr 21, 2023 at 7:20 AM
    #82
    Have you tried moving caster forward yet?
    You might be able to get away from the mudflap going this route.
    Then again you might not want to do an alignment before your lift.........depending on how long you plan to go at stock height.
    On the other hand if you get a lifetime alignment, you could do an alignment before your lift and after.
    lucasahall[QUOTED] likes this.
  23. Jan 19, 2024 at 7:36 PM
    #83
    Limited runner
    Limited runner New Member
    Arkansas
    Toyota 4 runner limited
    Do you have any lift on your vehicle ?
  24. Jan 20, 2024 at 3:11 PM
    #84
    HazOpRed
    HazOpRed 22' TRDOR
    275/70 won't fit without rubbing
  25. Feb 24, 2024 at 9:29 AM
    #85
    Benghazi757
    Benghazi757 New Member
    2018trd off road
    I have a 2018 OR with stock trd premium wheels eith 285/70/17 Toyo R/T which is a beefer tire than the A/T but less than the M/T 33.4 dia I believe no rub just need fender liner tuck! I have 6112 bilstien in front and 5112 in the back just to get some height!
