285/70/17 or 285/75/17
Discussion in '5th Gen 4Runners (2010-2024)' started by @Jerry, Feb 17, 2023.
  1. Mar 1, 2023 at 8:34 AM
    #61
    @Jerry
    @Jerry [OP] New Member
    ONZ
    2020 4Runner TRD PRO
    I'm running a 285/70/17 no BMC or trimming at all. I'll be running a KM3 in a 285/75/17 I've made my decision. I'm waiting for the C4 wings to install them. Then I will do the BMC.
    Broll and Thacrow like this.
  2. Mar 1, 2023 at 12:45 PM
    #62
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    You da man Jerry
    @Jerry[OP] likes this.
  3. Mar 1, 2023 at 1:26 PM
    #63
    For those that want to see different angles with the 34” Toyo R/T’s
    pastoreater, Commited, 5six and 8 others like this.
  4. Mar 2, 2023 at 6:17 AM
    #64
    @Jerry
    ONZ
    :yes:The 34”s have the look I want. I really like the way you set it up.
    Thacrow, SlvrSlug and Thatbassguy like this.
  5. Mar 11, 2023 at 3:24 PM
    #65
    Dracarys4R
    Dracarys4R New Member
    I was peeping on this post because I am making the decision to move to 34's and I like to be annoyingly thorough. It is interesting to me that so many people have such a variation of setups with BMC's, trimming, etc. on the 285/70 tire.
    I think tire brand and trim level sometimes matters here, maybe the shop you get it done at and a lift maybe? I have a 23 TRD Pro with the stock suspension but with the Westcott Pro level lift and changed the OEM 265/70/17's to 285/70/17's. It was hardly a difference, no rubbing at all. No real huge difference really. So it's interesting to see that so many needed a BMC with the 285/70's and I dont touch at all.
    So I am looking at gaining a little extra height with the 285/75/17s which has in turn snowballed into needing to accommodate in other ways. I will say this, the research I have done is that UCA's are a requirement for this. A trim is necessary... the mudflaps will have to go and a small trim to the bumper (or a full viper cut). I test fit a 34 on it with a negative offset wheel and was BARELY rubbing but still rubbing. It was worse with a baby flex (curb).
    A BMC is likely if you are ever going to flex your wheels but I am going to TRY to get away without one.
    It has been a difficult decision because it is a LOT just to gain an inch. It is also why I am overkilling this decision just to make sure.
    285/70 seems to offer a sweet spot but I feel like I'd enjoy the extra inch of height and beefy look even if it's about 40 lbs heavier overall than the current tire which is minimal in comparison?
    Falken 285/70/17 C Load (6 ply) is 54.97 lbs (anthemwheels.com source)
    Falken 285/75/17 E Load (10 ply) is 65.5 lbs (tiresize.com source)
    For reference, the top pic is OEM 265/70/17 on a TRD Pro
    The middle and bottom pic are the 285/70
    I haven't done the 285/75 quite yet but if I do, it will happen within 2 weeks. I already ordered the UCA's (Apache Offroad)
    329462002_1539557176539884_180251891008635856_n.jpg 327872647_1284063968816977_6102248506855609243_n.jpg
  6. Mar 11, 2023 at 3:33 PM
    #66
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Just do the bmc! Don't be scared.
    Toyo at3 c rated 285 75 17 are 58ish lbs i believe.
    SlvrSlug likes this.
  7. Mar 13, 2023 at 8:02 AM
    #67
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    From what I’ve been reading, anyone with a Westcott lift for the pro and running 285/70/17 did not need to do anything else (BMC, UCA, etc…) and have no issue with rubbing
    is that no rubbing at full lock off roading or just on pavement?
  8. Apr 12, 2023 at 2:30 PM
    #68
    DesertDigger
    DesertDigger New Member
    '14 White SR5
    OEM Kings, Total Chaos Uppers, Rear Coil, Prinsu Rack, Rear Molle Panels
    Was watching this thread while trying to decide myself. Ended up doing the 285/75/17 BFG KO2. I love the look and it does feel better to me offroad than the 285/70. I did total chaos upper control arms and king 2.5 shocks front and rear. Also did an eibach rear coil. Had accutune revalve the shocks for their adventure tune (daily drive use and trail use) and rides great. I reset the computer because I replaced my battery same time I did the lift and after about 1000miles the computer is telling me I’m getting 13.6mpg if anyone was curious. I think it’s closer to 14 because I was playing in the silt in Mexico and had it floored hahaha.
    Deff had to chop the cab mount and when I got it aligned I had them push the caster forward more to clear the back of the wheel well better. I found out in Mexico that the front tire hits the inner fender before the bump stop hits so I added a spacer on the factory bump to make it strike sooner. Might order a pair of those durabumps soon to try those.
    I can get a better shot this weekend when I head to Ridgecrest.
  9. Apr 12, 2023 at 2:54 PM
    #69
    If you haven't regeared, or had the speedometer and odometer recalibrated, you're getting closer to 14.5 due to the extra diameter of the tire. So, that's pretty good! :D
  10. Apr 12, 2023 at 3:31 PM
    #70
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Looks great! Definitely get yourself some bumps( I have superbumps) they are awesome.
    DesertDigger[QUOTED] likes this.
  11. Apr 12, 2023 at 4:03 PM
    #71
    DesertDigger
    '14 White SR5
    Haven’t regraded yet so yeah you’re right. I was about 4mph faster than speedo reading at highway speeds. That photo was also before we cranked the front coil overs down a little more to level out the front.
  12. Apr 12, 2023 at 4:23 PM
    #72
    I think it looks great....I'm really trying to find the courage and do the same. Dumb question, is the 285/75/17 almost like a 34's? Is the 75 what gets you almost over...to the 34s..
  13. Apr 12, 2023 at 4:35 PM
    #73
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    Loving the look! How much of a spacer did you add to your OEM bump stop...and did it help? lol
    I just ordered the Durobumps, going down this same route and hoping to have a proper bump stop solution in place to avoid contact with the inner (upper) fender.
  14. Apr 12, 2023 at 4:46 PM
    #74
    By the math, a 285/75/17 winds up at like 33.8. while a 285/70/17 winds up around 32.7.
    You're correct, it's the 75 that makes the difference.
    285 × .70 = 199.5 mm sidewall
    285 × .75 = 213.75mm sidewall
    So, you gain 14.25mm sidewall height, or 28.5mm more diameter.
    DesertDigger and djwantke like this.
  15. Apr 13, 2023 at 9:41 AM
    #75
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I've found 285/70R17 don't rub with lifts as long as you don't have large negative offset wheels. It's about the wheels. It's about the wheel spacers. 0 offset wheels, no rub. 1.25" spacers, major rubbing lol
  16. Apr 13, 2023 at 9:48 AM
    #76
    DesertDigger
    '14 White SR5
    I added some oversized washers we cut at work to add to a motor mount kit for the for broncos. I think it’s a 3/16 sheet we cut them from. I haven’t had the chance to cycle them fully and test. I have a feeling I might need to add a second one in there, but I’d rather order the better bumps instead. After all she isn’t a street princess and sees a fair amount of off-road. I have the rear bump kit being delivered today that accutune released a couple weeks ago.
    I’m headed to ridgecrest this weekend to mark a motorcycle race course so I should be able to test out this weekend. Mounting an awning on the rack though so might not go full send. Will have to test the integrity of that mount also. :burnrubber:
    Fortuner[QUOTED] likes this.
  17. Apr 13, 2023 at 10:50 AM
    #77
    Fortuner
    Fortuner New Member
    CA
    Thx for the reply. I was thinking ¼" spacer, but that's pretty close to 3/16...Looking forward to hearing the results!
  18. Apr 13, 2023 at 5:18 PM
    #78
    Austin26
    Austin26 New Member
    Austin
    5th gen ORP
    I'm really glad I went 255/80/17s. 32.8"x10.0"
  19. Apr 14, 2023 at 4:38 AM
    #79
    sportcoupe
    sportcoupe New Member
    2023 TRD Pro Solar Octane
    Why is that?
  20. Apr 15, 2023 at 12:34 PM
    #80
    Austin26
    Austin26 New Member
    Austin
    5th gen ORP
    No rubbing with stock suspension, even when off roading quite aggressively (articulation slow speed). Plus they're probably quieter than my Nitto Terra Grapplers and they fit the narrower 7" wide wheel many of us have (TRD SEMA). Stock wheels are 17x7.5". 285s don't belong on 7" wide wheels which mine are.
    semprenissart likes this.
  21. Apr 15, 2023 at 3:25 PM
    #81
    sportcoupe
    Well hundreds of folks run 285's on stock wheels.
    Also, 255/80/17 seem to only be available in Load E rating.
  22. Apr 15, 2023 at 3:39 PM
    #82
    Austin26
    Austin26 New Member
    Austin
    5th gen ORP
    10s of thousands, probably. But if you look it up, they're not meant for that width. If possible I try to follow the engineers and folks that know their line of work so I sleep a bit better.
    Yes mine are E, but I want that as I'm tired of getting flats often and I'll take the supposed edge it gives me along with my tire manufacturer's claim of reinforcement. No idea how much it helps but I'm trying lol.
    raimieb likes this.
  23. Oct 6, 2023 at 10:21 PM
    #83
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I am getting 285/75/R17 KO2s with the OME lift. I signed the paperwork today at 4WD shop. There will be be some minor chopping involved.
  24. Oct 7, 2023 at 6:32 AM
    #84
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Your paying $500 for a body mount chop? I should start a bmc business lol.
    Kezin likes this.
  25. Oct 7, 2023 at 7:43 AM
    #85
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    And $255 for an alignment. Wonder what retail is for all the other parts….
  26. Oct 7, 2023 at 8:55 AM
    #86
    captrussia253
    captrussia253 New Member
    Ruslan
    285/70r17 Falkens. But I prefer the 315/70r17 K02s.
    BMC, pinch weld mod, trim some plastic up front, 3” Dobinsons lift, a good ass alignment.
  27. Oct 13, 2023 at 10:23 AM
    #87
    Going all in?!? Wow, nice. What wheels are you going to use?
    djwantke and Yotaholic[QUOTED] like this.
  28. Oct 14, 2023 at 1:44 AM
    #88
    Yotaholic
    Olympia, WA
    I am keeping my wheels.
    djwantke and McSpazatron[QUOTED] like this.
  29. Mar 9, 2025 at 12:18 PM
    #89
    fomo4runner
    fomo4runner New Member
    Allie
    2019 trd pro
    Westcott level falken wildpeak at3 285
    you can 100000% run a 285 on the westcott level no cutting.
  30. Mar 9, 2025 at 12:19 PM
    #90
    fomo4runner
    Allie
    2019 trd pro
    Westcott level 285 wildpeak at3 NO BMC.
    Thatbassguy and djwantke like this.
