275/70R17 or 285/70R17?
Discussion in '5th Gen 4Runners (2010-2024)' started by P226Navy, Mar 5, 2019.
  1. Mar 9, 2019 at 8:46 PM
    Deadpool
    Deadpool New Member
    2017 SR5 white
    Perfect! And like backslider said post pictures so we can live vicariously through you....
    P226Navy[OP] likes this.
  2. Mar 9, 2019 at 10:23 PM
    redneckj
    redneckj New Member
    2018 TRD Off Road 4Runner
    working on it
    There is NO rubbing on my 4Runner.
  3. Mar 13, 2019 at 4:49 PM
    P226Navy
    P226Navy [OP] 2016 T4R
    Vee
    South San Francisco
    2016 Toyota 4Runner
    9CEA11BE-4534-4F57-895E-86DFF52BDF53.jpg I decided to go BFG KO2 285/70R17. What a smooth and quiet ride I had. Big difference coming from BFG KM like WOW! And my mileage was up by 2 miles.
    I just have a minor fender rubbing on full turn and on reverse but I’ll figure it out how to do it. I’ll install the 1” cornfed spacer at Rear soon. 6305F933-D916-4424-9282-BC73CFCC4D7E.jpg
    From Procomp with BFG KM 255/75R17
    SKT_07 and DrewMan like this.
  4. Mar 13, 2019 at 6:45 PM
    P226Navy
    Vee
    South San Francisco
    2016 Toyota 4Runner
    I measured both from center caps to bottom of the fender, both on 21”. Will adding 1” spacer in Front and 2” rear lift would solve the minor rubbing in the fender?
  5. Mar 13, 2019 at 10:48 PM
    P226Navy
    Vee
    South San Francisco
    2016 Toyota 4Runner
    Now that I changed my wheels and tires from 255/75R17 to 285/70R17, do I need to get an alignment?
  6. Mar 15, 2019 at 3:02 PM
    I would before you start trimming anything. One of the best purchases you can make with a lifted 4wd vehicle is a lifetime alignment from a reputable place.
    Have them push your caster up to as close to 4 degrees as you can get. It will track better on the highway and you'll be less likely to rub on the mudflaps. You may rub a bit on your front fender liner, but the fender liner is easy to push forward.
    Glad you're liking your 285's :thumbsup:
  7. Mar 15, 2019 at 4:24 PM
    P226Navy
    Vee
    South San Francisco
    2016 Toyota 4Runner
    I assume to any alignment shop?
  8. Mar 15, 2019 at 9:35 PM
    P226Navy
    Vee
    South San Francisco
    2016 Toyota 4Runner
    Did push back front fender liner and made a new hole for the bolts and nuts and took the mud guard (ouch!) and rubbing issue is gone. Made full turn lock both left and right in reverse. No rubbing at all. I’ll crank .5” more in my Fox Coilovers and will install 1” cornfed or 1.5” daystar rear spacer this week. Right now I have 21” from center hub both Front and Rear.
  9. Jun 26, 2019 at 8:16 PM
    mderenthal
    mderenthal New Member
    2016 4Runner SR5
    Black NFab Nerf Bars, TRD 17" rims, Cooper AT/3 275/70/R17,
    FYI for others - I just installed factory sourced TRD Pro rims on my 2016 SR5 along w/ some Cooper AT-3 275/70/R17's, and no rubbing in drive but do rub when turning in reverse (despite MOST of what I researched online telling me they would not rub), so yes, seems to be case by case basis at that size. I'll report back after effort at adjusting fender liner.
    TacoTo4Runner likes this.
  10. Jun 26, 2019 at 8:36 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Pics please
  11. Jun 27, 2019 at 8:20 AM
    So it's rubbing on the front fender liner? Have you had it aligned? What is your caster set at?
  12. Jun 27, 2019 at 1:40 PM
    danssr5
    danssr5 New Member
    Dan
    2017 sr5 premium 4x4
    This is correct. My local Toyota dealer sells pro's all day long and the only thing they do is swap out the tires for 275 bfg's.
    here is a picture. (This is stock suspension on a pro)
  13. Jun 28, 2019 at 8:34 AM
    danssr5
    danssr5 New Member
    Dan
    When you say "stock backspacing" which stock wheels are capable of this? I have the sr5 wheels.
    Thanks!
  14. Jun 28, 2019 at 8:42 AM
    danssr5
    danssr5 New Member
    Dan
    If you look closely at the pictures of the pro i posted with 275's you will notice they removed the front mud flaps.
  15. Jun 28, 2019 at 8:45 AM
    danssr5
    danssr5 New Member
    Dan
    Where is this picture taken from?
    Thanks!
  16. Jun 28, 2019 at 8:45 AM
    SR5 wheels, Off-road wheels, Pro wheels.
  17. Jun 28, 2019 at 11:03 AM
    danssr5
    danssr5 New Member
    Dan
    Any of these will work with 285's? I really do not want to run wheel spacers (I don't know if i would need to)....some of the shops around here wont touch your truck and you are left with removing them.
    Thanks!
  18. Jun 28, 2019 at 11:30 AM
    Yes, any of these will work with 285's.
    One caveat to this is that both the SR5 wheels and the Pro wheels are 7" wide. Most 285's recommend a minimum 7.5" wheel. Plenty of people still run 285's on a 7" wide wheel with zero problems. I have never known a tire shop that has refused to put 285's on a wheel because it was 7" and not 7.5".
    You don't need wheel spacers. In fact, you are more likely to rub with wheel spacers.
    I have 285's on Off-road (Trail) wheels and a 1.6" lift in the front. Caster at 4* and the fender liner on mine is pushed forward slightly. I still have the front mud flaps. No rubbing whatsoever.
    jester243 likes this.
  19. Jun 28, 2019 at 11:47 AM
    #49
    danssr5
    danssr5 New Member
    Dan
    Really 1.6" in front? I am seriously thinking of installing the toytec 1.6" springs in front (with a 1/4 inch spacer ~2.1 inch lift up front combined) setting my bilsteins back to zero. and running the toytec 1" spring in the rear. this combo after the spring rates all iron out will have a difference of 8% higher spring rate ratio to rear with the new springs. This probably will be my best bet for balance. Cant complain after this lol.
    are you running front eibachs only?
  20. Jun 28, 2019 at 12:52 PM
    #50
    Yes, Eibach adjustable shocks set at 1.6" in front with the stock coil. Stock shocks and coils in the rear.
    I plan to get some Dobinson 1.5" coils for the front so I can set the Eibach's to 0".
    Why not get a Dobinson 2" spring, set your Bilsteins to 0" and forget the spacer?
    Weps28 likes this.
  21. Jun 28, 2019 at 1:00 PM
    #51
    Huzer21
    Huzer21 New Member
    CO
    2011 GX 460
    I’m tossing 275s on my SR5, on Pro wheels right now. I went back and forth for a while before finally making a decision.
  22. Jun 28, 2019 at 4:23 PM
    #52
    ForRun
    ForRun 4Runner
    2020 orp
    I want 285s but do not want to lose power mpg etc. Was going to do 275 but I like a wide tire not for height. Since 265 is same width as 275 I went stock size. Toytec coils coming next week to level, air bags to tow and I'm done.. probably not but :notsure:
  23. Jun 28, 2019 at 4:44 PM
    #53
    danssr5
    danssr5 New Member
    Dan
    I want matching springs. I have used eibach in the past so i trust their springs. EMU springs? Even though we did not discuss these i heard that they sag after a while (never had an eibach sag) Dobinsons? thats pretty new to me. I will have to look into it...Im looking for a 2/1 setup as i do not want to deal with upper control arms.
    nimby[QUOTED] likes this.
  24. Jun 28, 2019 at 4:59 PM
    #54
    danssr5
    danssr5 New Member
    Dan
    FYI I read another thread where you went with destination AT/s GREAT TIRE! I had them on my Tacoma before i traded it in last month. I want a 2/1 lift as it will be the exact same height as my Tacoma was which was perfect
  25. Jun 28, 2019 at 9:11 PM
    #55
    Huzer21
    Huzer21 New Member
    CO
    2011 GX 460
    Here’s mine, stock suspension. Will not be stock tomorrow (6112/5160 going on in the morning). No rubbing at all with 275s on the BFGs, I cranked full left and right, forwards and reverse.
    jester243, nimby and TN_FunRunner like this.
  26. Jul 5, 2019 at 9:32 PM
    #56
    Huzer21
    Huzer21 New Member
    CO
    2011 GX 460
    Here’s the after. 275s with 6112/5160 and Wheelers T13 rear springs. Fronts are set at 2”.
    SKT_07, WallyT4R, Weps28 and 2 others like this.
  27. Jul 5, 2019 at 10:05 PM
    #57
    ForRun
    ForRun 4Runner
    2020 orp
    Looking good! How much lift did you get with the 13s out back?
  28. Jul 6, 2019 at 9:43 AM
    #58
    Huzer21
    Huzer21 New Member
    CO
    2011 GX 460
    Prior to the total lift, I was at 37” ground to fender on the passenger side, 36.5” on the driver side. The fronts were assembled to balance out the driver’s side lean. After, I ended up at 38.25” both sides. The tires added about a 1/2”. I also have the third row. I took measurements at stock, then with the new tires, then finally with the lift.
  29. Jul 7, 2019 at 5:35 AM
    #59
    Bgdv1
    Bgdv1 New Member
    Dave
    Butler
    2014 SR5P
    This is my '14 SR5P with Bilstein 1500 leveled and bags in rear for when I pull my bike trailer. Running 275 70 17 Cooper AT3 on AR Fuel 8" +25 wheels and have -0- rubbing issues. 20190705_135038.jpg
  30. Jul 18, 2019 at 1:44 PM
    #60
    Huzer21
    Huzer21 New Member
    CO
    2011 GX 460
    Follow up, I got an alignment today after letting the lift settle a little. I had driver's side rub at full lock right turn in reverse. Passenger side was fine, but really close. I did the fender liner mod and all is well.
    SlvrSlug and nimby like this.
