265, 275 tires? What are the suggestions ?
Discussion in 'Wheels & Tires' started by PCRIDE4RUNNER, Jun 13, 2018.
  1. Nov 15, 2018 at 11:01 AM
    PrettyGoodSam
    PrettyGoodSam New Member
    Philadelphia
    2012 4Runner Trail
    this was very helpful as well as i have been agonizing over 265 or 275 haha. going w 265.
    @edgesalon tirebuyer.com has a 10% off promo going on right now for all terrain tires "ALLTERRAIN10" is the coupon code.
  2. Nov 15, 2018 at 11:35 AM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    thanks
    thanks @PrettyGoodSam looking at Falken - Wildpeak A/T3W
  3. Nov 15, 2018 at 2:12 PM
    PCRIDE4RUNNER
    PCRIDE4RUNNER [OP] New Member
    SUPER DUPER
    Yea if you aren’t looking for a big lifted look, then the 1.6” lift (equilvent to 2” actual ) then the 265’s are a great fit proportionally, any larger of a lift you’ll probably want 275’s to fill in the wheel well so it doesn’t look like you have small tires :benchpress:. I’ve noticed a lot of 4 Runners I see are much bigger than mine and have 2” , 2.5” and 3” lifts and IMO they are just too big for a 90% street, unless you just like the looks. I consider a balance of utility and practically to some degree on most things. Also I don’t want to have my wife climb a ladder to get in each time we go somewhere :)
  4. Nov 16, 2018 at 3:30 PM
    Crossfit4Runner
    Crossfit4Runner New Member
    Saint Louis
    2018 TRD Off Road Permium
    To many to list
    I went with the 3” Ready Lift and have the stock 265’s still on the OEM TRD wheel. I’m concidering 275’s when I need to replace my OEM tires. I think they look a little small, but not to bad.
    Caltech90 and PCRIDE4RUNNER[OP] like this.
  5. Nov 18, 2018 at 1:28 AM
    Offwidth
    Offwidth New Member
    Ordered LT275/70r17 Kumho AT51. Will see how it goes. Good reviews, good snow and wet behavior unlike KO2, and comes in C 7ply version for not much weight gain over stock (E is 10lb per tire heavier). Will also swap stock wheels to TRD ones, though on the narrow side, should be OK, and saves some weight gain back..
    No lift unless I have to. Maybe will get adjustable and lift front under an inch..
  6. Nov 18, 2018 at 7:10 AM
    PCRIDE4RUNNER
    SUPER DUPER
    Interesting .. I’ll take a look at these for my next tire set. One reason I steered away from 275 is they only had 10 ply E, nice to see 7 ply and save some weight and ride quality.
    I didn’t hear anything about Ko2’ in the snow! I hope they work. Cooper AT3 tires work amazing in snow, and so does the Blizzacks. I was amazingly impressed how good blizzacks do (installed on our other vehicles)
  7. Nov 18, 2018 at 10:05 AM
    Offwidth
    Offwidth New Member
    KO2 are decent in snow, I was less then impressed in wet on E rated. Sketchy. My common winter trip (to Tahoe area) involves both. Both KO2 and AT51 are 3peak snow rated.
    Kumho lists 275/70 weight at 46.7. P class stock size are 42.6 . E rated LT stock size is 52.6 . KO2 in 275/70 are 52lb
    I will post pictures. 7.0 rims ore on lower end of their recommended width for 275s, but I wanted TRD wheels for appearance reasons, and prefer OEM on a brand new vehicle.
  8. Nov 18, 2018 at 11:13 AM
    WallyT4R
    WallyT4R New Member
    I have the KO2 C rated and my experience is they are excellent in the snow and good in the wet. I have had no issues with them but have to be diligent on rotating them every 5000 miles. That said I will probably try another tire if these ever wear out. Possibly to a 255/75 size.
  9. Nov 18, 2018 at 1:36 PM
    Offwidth
    Offwidth New Member
    I can see how C rated would be better, not being as stiff. No such option in 275/70
    I think 4Runner does not need E load, unless many other modification to suspension, LCA and UCA, etc to take on the extra weight.
  10. Nov 20, 2018 at 7:35 AM
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    Got the 265/70/17 KO2's installed on Saturday. Previously had 285/70/17 Michelin defenders and I mentioned this in the "what have you done..." thread: The difference in braking, acceleration and handling is incredibly remarkable. The runner responds so much better and I am really happy with my choice. Now for some crappy weather to go play in! IMG_20181117_170137108.jpg
  11. Nov 21, 2018 at 5:44 PM
    PCRIDE4RUNNER
    SUPER DUPER
    That’s awesome to hear. I was worried about that exact thing... big uncontrollable weight factors.
    I think 285 is much to large anyway for a 4Runner IMO, I think a lot of Jeeps can handle it well if you upgrade other components proportionally. No sense having big tires with a small axle that’s not designed for it in the first place!
    You 4R looks awesome!!
  12. Nov 23, 2018 at 9:20 AM
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    Thanks @PCRIDE4RUNNER ! I've also noticed a slight increase in MPG. I am taking a 200 mile round trip this weekend that will be 95% highway so i am gonna see how well it does.
  13. Nov 26, 2018 at 11:31 PM
    Offwidth
    Offwidth New Member
    Installed aforementioned LT275/70 C-load Kumho AT51 on TRD black rims. Seems to fit and look well. Will see how it lasts and performs.
    It also seems that with LT thread depth they will be smaller than stock size by its half life.
  14. Nov 27, 2018 at 9:24 AM
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    tires were great on the highway. quiet! excellent handling and the mpg's are still up a little. thats a nice bonus!
  15. Nov 28, 2018 at 5:49 PM
    Offwidth
    Offwidth New Member
    For reference, stock 2019 trd off-road tire was 39.3 lb and rims 30 lb. 275 Kumhos 46.5lb, TRD wheels 25.4lb
    So very small weight gain - actually none as will be replacing steely spare as well.
    Much better looking and should be by far better performing.
    Next thing replace running boards with sliders.
    Anybody need five brand new stick tires in SF Bay Area.
    7385 and WallyT4R like this.
  16. Dec 7, 2018 at 6:00 PM
    Crossfit4Runner
    Saint Louis
    To many to list
    Just put 285’s on my ride today. So far so good.
    brad and SlvrSlug like this.
  17. Dec 7, 2018 at 6:20 PM
    CPaul
    CPaul New Member
    Chris
    Mobile, AL
    2018 TRD Off Road Premium Silver KDSS
    Beautiful 4R!! I am still trying to decide what to do with my stock ORP.
  18. Dec 9, 2018 at 4:08 PM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    That looks great, I love the white letters out. Sure, these things are subjective, but that’s a classic Toyota look that goes waaayy back.
  19. Dec 9, 2018 at 7:29 PM
    #49
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    LT255/80/17 in Cooper ST Maxx for my 4Runner ORP :thumbsup:
  20. Dec 10, 2018 at 8:50 AM
    #50
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    Thanks! i love the look as well. doesnt get old haha
  21. Dec 10, 2018 at 6:09 PM
    #51
    WallyT4R
    WallyT4R New Member
    I would like to see pics please. Is yours lifted? I am thinking about 255/75/17's next but it will be awhile. No lift here.
  22. Dec 10, 2018 at 11:11 PM
    #52
    Doglover2003
    '18 ORP w/KDSS
    My 4Runner:
    On Kings with adjusters and Metal Tech 2" rear springs
    7385, WallyT4R[QUOTED] and SlvrSlug like this.
  23. Dec 11, 2018 at 7:06 PM
    #53
    WallyT4R
    WallyT4R New Member
    Very nice Dog!
    Doglover2003 likes this.
  24. Jan 3, 2019 at 10:44 AM
    #54
    CrznErick
    CrznErick New Member
    Erick
    2008 Toyota FJ Cruiser
    BFG all terrain!!!!
    WallyT4R likes this.
  25. Jan 6, 2019 at 1:49 PM
    #55
    Doglover2003
    '18 ORP w/KDSS
    It's actually Cooper ST Maxx LT255/80/17 tires :hattip:
    toy33 and WallyT4R[QUOTED] like this.
  26. Jun 1, 2019 at 2:50 AM
    #56
    rpl77
    rpl77 New Member
    Nice looking rig! I too have a black 4Runner (2018 ORP w/ KDSS). I'm getting the TRD rims and have been debating on 265 vs 275 but after seeing your post, I'm doing the exact same thing you did with the 6612/5160 Bilsteins and 1" cornfed spacer.
    Sorry if I missed it, but did you experience any rubbing with the 265 prior to the lift?
    Did you notice any change in handling with this exact set up? And how much did you pay for install if you don't mind me asking? Thanks
    Ryan
  27. Jun 12, 2019 at 11:28 AM
    #57
    danssr5
    danssr5 New Member
    Dan
    2017 sr5 premium 4x4
    I stopped by the Dealership the other day. They had a STOCK Trd pro and the only upgrade it had was 275 70 17 K02's mounted to its TRD wheels. It looked really good. I do know that the pro is 1" higher up front.
    If your stock suspension is fresh I would say put a cornfed 1" spacer up front and call it a day. I just hit 55k miles and installed bilstien 5100's set at .85. To be honest it was not as amazing as everyone says it is....but when you get up to higher mileage and want to replace to be proactive it is cheaper than buying stock replacements. Nose dive has been reduced (never was that much of a problem anyway) and handling improved somewhat. It is NOT harsh and I do not understand why some say it is.....Maybe its the revo 3's i am running? I would say for sure it is an improvement over stock in all areas. I will not recommend replacing if your shocks are in good shape. What i can say is that at .85 up front reusing stock coils the handling of the vehicle remains intact and improved. i need an alignment which will be done on Saturday at the dealer (local firestone are clowns and they refunded me last time...toyota in my area does a better job. I do feel that the rear spring might need a small boost in stiffness to compliment the total package if you have like 100lbs of stuff in the back. I am going to test removing all the crap in the back and see if it is improved or the same. For now I am not going to go any higher on 265's as i think it will look goofy if it were any higher.
    My thoughts on aesthetics are
    265's just level the front
    275's look great with the front still leveled and will look great if you go 2/1
    285's look good at 2/1 and also at 3/2 (i'm going to stay away from these) This size comes with unknown potential issues. If you do not want wheel spacers you will have to buy new wheels and are in about 2k for tires and wheels plus probably the need for UCA's and probably a cab mount chop. In my opinion not worth the extra 1/4 inch of lift coming from 275's. Not that 285's don't look great but my goodness you can get up to 3k just trying to fit 285's and imagine what else you can buy for your 4runner just stopping at 275's.
  28. Jun 20, 2019 at 8:55 AM
    #58
    danssr5
    danssr5 New Member
    Dan
    Forgot to add the picture of the trdpro i saw at the dealer with 275 ko2. Looks like you have to remove the front mudguards on stock suspension.
    arnette64 likes this.
  29. Feb 12, 2020 at 2:00 PM
    #59
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    That looks awesome. I'm contemplating 275's for my TRD Pro, but in the Wildpeaks because they have a C load.
  30. Apr 10, 2021 at 7:32 AM
    #60
    Rommelf1
    Rommelf1 New Member
    I have a 4Runner 2013 limited lifted it to 2” with Old man emu, I would like to know if would be safe to use Goodrich all terrain ko 265 60 20? I hear the minimum width of the Rim should be 7.5 and mines are OEM that mean 7. Someone know is is gonna be safe or not? Thank you
