255/80R17 tire size
Discussion in '5th Gen 4Runners (2010-2024)' started by szuyung3000, Sep 27, 2018.
  1. Jan 17, 2025 at 12:32 PM
    #211
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    On mine, I am very happy with the 235/80 17's on factory wheels with no rubbing issues at all. I have about 1 inch approx. lift.
    They look great and ride great.
  2. Jan 17, 2025 at 2:56 PM
    #212
    Stoney Ranger
    Stoney Ranger Lockers? Pffft
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-F/R Bpr-Winch-Stickers-ALF
    I'd like to help, but I had already done the fender tuck and a very small amount of trimming so my last set of tires wouldn't rub. The few videos I have seen say 255's fit. One guy had to remove the mudflaps. The others were fine.
  3. Jan 17, 2025 at 5:24 PM
    #213
    Jedi5150
    Jedi5150 New Member
    2022 4Runner ORP
    No. I mean, not that I've ever heard of. This size is awesome for not having to get a body mount chop, but it WILL rub. I've never heard from anyone who said they had zero rubbing (is that what doglover2003 meant??). The fix is super simple, but you will absolutely have to shave off a little plastic and move the front fender well forward. I'm not mechanically inclined and it was like a 15-minute job after youtube. If someone isn't rubbing with 255/80R17's, and they haven't done any cutting, then I'm guessing they've never turned their steering wheel or gone over a bump. :rofl:
    Gman2530 and bassist[QUOTED] like this.
  4. Jan 18, 2025 at 5:37 AM
    #214
    :help:Guys, i am slow here with tires. So what are the benefits of the pizza cutters? They look like stock to me. Are they quieter than regular 33s? Or better for HWY only?
    Fairway2Heaven likes this.
  5. Jan 18, 2025 at 6:04 AM
    #215
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I believe the argument is
    -They are lighter and you still get the advantages of a tall tire
    -Less rolling resistance due to a smaller contact patch
    -Easier to clear everything without chopping up your 4Runner
    -Still offer great sidewall deformation when aired down.
    Not my thing personally but I understand why it's an attractive option for a lot of people.
    Jedi5150 and java like this.
  6. Jan 18, 2025 at 6:08 AM
    #216
    Fairway2Heaven
    Fairway2Heaven New Member
    Alabama
    '21 SR5P 4WD, Nautical Blue
    Yota Expedition Grille Smoked Amber Raptors Anthracite Grey Wheel Dip Black Emblem Overlays Black Roof Rails (Painted) AuxBeam Amber DRLs Lasfit & Husky Floor Mats Side Window Guards
    in similar boat. I have watched and read several stuff on wide vs. tall and only conclusion is there’s no consensus. Seems to me the answer is “it depends”. Tire press, terrain, driver, conditions, etc.
    for me, i am about to do an Eibach level on front and leaning towards 255/75 Geolanders as I mostly need HWY and like the look of a bit taller stance. Though, getting older so hopefully I don’t regret this little extra height via climbing in and out. I figured the 75 instead of 80 would be better with the uncertainty of rubbing or not.
  7. Jan 18, 2025 at 3:01 PM
    #217
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
    Just installed the 255/80/17 Toyo Open Country AT/III
    38psi eibach pro truck lift stage 2
    On the road no rubbing I’m just getting back from the shop so I don’t have enough miles on the road or off-road yet, but it will come soon as for the field on the way home no problem with the rated tire but again I need more time I like the way they look and I like the extra ground clearanceF3979A95-DDAD-48ED-8A9A-611A612ADD73.jpgF3979A95-DDAD-48ED-8A9A-611A612ADD73.jpg
  8. Jan 18, 2025 at 3:53 PM
    #218
    Henry J
    Sacramento Ca
    Those look great! I’m still curious on air down for you all. I’m heavily leaning to try and trade my wheels to a skinnier TRD pro wheel.
  9. Jan 18, 2025 at 3:58 PM
    #219
    Gman2530
    Gman2530 New Member
    I mainly do desert trails, combination of sand and rock nothing extreme and don’t always air down but when I do, it’s very noticeable in the ride and traction… I will air down to 22 psi
    Makes going through those washboard ruts, much more comfortable, and easier on the rigA02FAB28-6097-4F34-8B28-02ED5CAA663D.jpg
    Henry J likes this.
  10. Jan 18, 2025 at 4:07 PM
    #220
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I have gone as low as 13-15psi on my 255's in some deep snow and have had no issues. Generally stay around 20 psi on the trails
    Henry J[QUOTED] likes this.
  11. Jan 18, 2025 at 4:14 PM
    #221
    Gman2530
    Gman2530 New Member
    Got some nasty sharp edged rocks in desert
    Worry about sidewalls
    So I stay 20-22psi Looking forward to putting the new tires to the test
    Henry J likes this.
  12. Jan 18, 2025 at 4:31 PM
    #222
    java
    java fauxrunner
    2023 ORP ice cap
    Beautiful weather!
  13. Jan 18, 2025 at 4:45 PM
    #223
    Gman2530
    Gman2530 New Member
    Get cold at night low 30s then niceeeeee
    Jedi5150, java and Stoney Ranger like this.
  14. Jan 18, 2025 at 4:58 PM
    #224
    Gman2530
    Gman2530 New Member
  15. Jan 19, 2025 at 9:00 AM
    #225
    Jedi5150
    Jedi5150 New Member
    2022 4Runner ORP
  16. Jan 19, 2025 at 11:37 AM
    #226
    Acesandeights
    Acesandeights #34
    2024 ORP
    It shouldn't. 255mm is the width regardless of the wheel or aspect ratio, height.
  17. Jan 19, 2025 at 12:18 PM
    #227
    Fishbum
    Fishbum New Member
    Ok I simply ask because other tires get tall with more width. I wasn't sure if the same could go in this instance. Really prefer standard sizes... 33/10:50 or whatever
    Trail Runnah likes this.
  18. Jan 19, 2025 at 12:57 PM
    #228
    Acesandeights
    Acesandeights #34
    2024 ORP
    The first numer is the width in millimeters, so at least that's a constant. The rest is an equation, so you have to know the aspect ratio, second number is a percentage, and the wheel size to add to the percentage of the width. Carry the two, multiply by the square root of the hypotenuse, etc.
  19. Jan 19, 2025 at 12:59 PM
    #229
    Fishbum
    Fishbum New Member
    Um... Nope I'm not that smart
  20. Jan 19, 2025 at 2:41 PM
    #230
    Gman2530
    Gman2530 New Member
  21. Jan 19, 2025 at 2:52 PM
    #231
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    That method hasn’t been the standard for a couple of decades now when it comes to tires.
    Metric sizing isn’t hard to get used to…
  22. Jan 20, 2025 at 4:14 PM
    #232
    Gman2530
    Gman2530 New Member
    Did the fender mod, made cut with a Dremel.. also pushed fender liner forward … hoping to try em out in the desert tomorrow…. Will advise when I return … thanks to all that had input about the size & fender mod needed. Cuts are not perfect :/
    java likes this.
  23. Jan 22, 2025 at 12:53 PM
    #233
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    Where is this? Johnson Valley?
  24. Jan 22, 2025 at 3:17 PM
    #234
    Gman2530
    Gman2530 New Member
    It’s out in Anza Borrego. Not certain if it has a name :/
  25. Jan 22, 2025 at 6:19 PM
    #235
    coryanderson
    Cory
    That was my other guess. Looks mostly untouched. Hard to find in the southwest with all the sxs.
  26. Jan 22, 2025 at 6:47 PM
    #236
    Gman2530
    Gman2530 New Member
    True
    I see more trails & camp spots being closed off with signs.. in just the last few years.. folks not cleaning up & wrong types of vehicles being run through them. 8EFD2FE2-E21F-4EF8-A24F-F2BBE5CE28DC.jpg
  27. Feb 14, 2025 at 12:38 PM
    #237
    MEski4x4
    MEski4x4 New Member
    2024 TRD Pro
    Reviving this a bit. Have a few options and really can't figure out the best move.
    24 Pro - stock suspension (for now)
    255/75/17 C Load
    265/70/17 XL Load
    255/80/17 E Load (but I don't want to go this route)
    What are people's thoughts on a 255 C load vs 265 XL load as far as ruggedness? I have read dozens of pages over and over, and I can't decide.
    The first two are basically the same height 31.9 vs 32.1 in the tires I am looking at - obviously the 80 is 33" - but that's a last ditch move because I already get shit MPG and do a lot of highway driving at 70-75
  28. Feb 14, 2025 at 2:24 PM
    #238
    Fishbum
    Fishbum New Member
    255/75 c
    MEski4x4 likes this.
  29. Feb 14, 2025 at 3:04 PM
    #239
    Gman2530
    Gman2530 New Member
    After trimming the fender and pushing the fender liner forward, I purchased this off of Amazon not really necessary since no one can see it unless you crawl underneath, but it’s a clean look
    E5D77E5D-3265-4419-8EE3-3D42CE7DBE25.jpg E07A3510-D537-4BAB-8031-C2F26A92AEBB.jpg
  30. Feb 14, 2025 at 3:11 PM
    #240
    Gman2530
    Gman2530 New Member
