255/80R17 tire size
Discussion in '5th Gen 4Runners (2010-2024)' started by szuyung3000, Sep 27, 2018.
  1. Sep 15, 2024 at 8:37 PM
    #181
    meats
    meats New Member
    Broken Arrow, OK
    2018 Magnetic Gray TRD OR
    2/1 Cornfed Leveling kit Sway Bar Delete 285/70/17 - Arroyo Tamarock M/T
    good point. Looks good
  2. Sep 15, 2024 at 9:27 PM
    #182
    Got Goodyear Duratrac RT in 255/80R17 P/N 176315991 mounted on a set of used Tacoma TRD Sport wheels:
    Everything clears with stock suspension. Front fender liner clearance and mud flap / cab mount clearance:
    [​IMG] [​IMG]
    So far the tires are doing great. The 60 mph steering shimmy with (worn) BFG Winters is gone. The highway howl I experienced with gen-1 Duratracs is gone.
    jeepster09, SlvrSlug and Trail Runnah like this.
  3. Sep 16, 2024 at 12:14 PM
    #183
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    Front: JBA upper arms with Dobinsons MRR 3 way adjustable extended shocks
    Rear: ICON overland springs (lots of weight inside the rear cargo area and plan to add a rear bumper within the next 18 months) and Dobinsons extended travel shocks (non 3 way adjustable) I will upgrade these probably when I add the rear bumper.
  4. Sep 16, 2024 at 12:16 PM
    #184
    coryanderson
    Cory
    Rears no issue at all. Fronts, I couldn't even get my car out of the driveway with out cutting the body mounts and grinding down the pinch welds.
  5. Sep 17, 2024 at 4:31 PM
    #185
    trevor1030
    trevor1030 New Member
    Trevor
    24 4Runner TRD Pro, 23 Tacoma TRD Pro
    with a eibach trd pro lift which i think is 2.5" lift. Running 0 offset wheels AT4 255/80/17, i didnt rub daily driving. The only rub i ever noticed, was the front right tire when going into a driveway while turning right, it rubbed a little of the front mudflap. So i went and removed the front mudflaps and bought the delete kit for the rears. I think it looks better that way anyways! But i did not need to do any BCM, if it helps is a 24 TRD Pro
    meats likes this.
  6. Sep 18, 2024 at 10:19 AM
    #186
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    How much if you dont mind thanks
  7. Sep 18, 2024 at 10:46 AM
    #187
    CA4runner
    Nor Cal
    2019SR5
    How much lift do you have up front?
  8. Sep 19, 2024 at 9:09 AM
    #188
    Fishbum
    Fishbum New Member
    One and three quarters/2 inch on the other side to make up for the lean
  9. Sep 19, 2024 at 8:14 PM
    #189
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Right at 3"
  10. Jan 4, 2025 at 8:15 PM
    #190
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
    Thank you all for all the info 255/80/17 here I
    Come …
    8E382230-6C9F-4CC1-AA16-9A8FEEBB6CE1.jpg1A687782-1BF2-4558-8EF8-DFD0A4C4EF6B.jpg 8E382230-6C9F-4CC1-AA16-9A8FEEBB6CE1.jpg
    Jedi5150, CRasch505, java and 3 others like this.
  11. Jan 5, 2025 at 9:12 AM
    #191
    HuskerRunner
    O,NE
    2023 SR5P
    What's the setup in these pics?
  12. Jan 5, 2025 at 12:05 PM
    #192
    Fishbum
    Fishbum New Member
    C load?
  13. Jan 6, 2025 at 6:33 AM
    #193
    CRasch505
    CRasch505 New Member
    Chris
    5th Gen 4Runner ORP
    Fifteen52 Analog HD's, Nitto Terragrapplers, 1" spacer lift front, ceramic on all glass.
    I could only ever find 255's in E load.
    java likes this.
  14. Jan 6, 2025 at 7:17 AM
    #194
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Some 255/75R17 are available in C load
    All the 255/80R17 that I know are E load only
    CRasch505[QUOTED] likes this.
  15. Jan 13, 2025 at 6:26 AM
    #195
    broken-giver
    broken-giver BFD
    My next tire size is 255. Not sure 75 or 80. But this thread has me convinced.
    Jedi5150 and CRasch505 like this.
  16. Jan 13, 2025 at 7:17 AM
    #196
    CRasch505
    Chris
    5th Gen 4Runner ORP
    255/80, I feel, is perfect. It fits so nicely on a lift.
  17. Jan 13, 2025 at 2:28 PM
    #197
    java
    java fauxrunner
    2023 ORP ice cap
    Any recs for chains that fit 255/80/17?
  18. Jan 13, 2025 at 2:38 PM
    #198
    Acesandeights
    Acesandeights #34
    2024 ORP
    Peerless, Laclede
  19. Jan 17, 2025 at 3:44 AM
    #199
    Shanky
    Shanky New Member
    We have been on 255/75 for 30,000 miles so far. Stock ride height, K02. No regrets.
  20. Jan 17, 2025 at 3:50 AM
    #200
    Fishbum
    Fishbum New Member
    When you go to the 255 85 s does the tire start to actually measure out a little wider?
  21. Jan 17, 2025 at 8:26 AM
    #201
    Stoney Ranger
    Stoney Ranger Lockers? Pffft
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-F/R Bpr-Winch-Stickers-ALF
    I joined the pizza cutter cult yesterday. Falken Wildpeak AT4's.
    17371309806415734080669437378527.jpg 17371310541686004349817067826873.jpg 17371311224425782904645104066651.jpg
  22. Jan 17, 2025 at 9:12 AM
    #202
    java
    java fauxrunner
    2023 ORP ice cap
    Nice, you got a matching spare too! Have KDSS? How is the spare fitment under there?
  23. Jan 17, 2025 at 9:41 AM
    #203
    Jedi5150
    Jedi5150 New Member
    2022 4Runner ORP
    Congrats! You'll never look back. 255/80R17 is the only way to go. :D
    Stoney Ranger[QUOTED] and java like this.
  24. Jan 17, 2025 at 10:50 AM
    #204
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Actually I have 2 matching spares, for a planned trip to Alaska in June. It's an SR5 so no KDSS. I cannot speak to the spare fitment as I cut the 2 horse shoe brackets off when we installed the rear bumper.
    java[QUOTED] likes this.
  25. Jan 17, 2025 at 11:23 AM
    #205
    java
    java fauxrunner
    2023 ORP ice cap
    Nice, did you get alloy or steel wheels for spares? Where does the second spare go, on the roof? Do you rotate all 6 or 5?
  26. Jan 17, 2025 at 11:24 AM
    #206
    CRasch505
    Chris
    5th Gen 4Runner ORP
    For what it's worth I have a 22 ORP with KDSS and the spare fits just fine.
  27. Jan 17, 2025 at 11:26 AM
    #207
    java
    java fauxrunner
    2023 ORP ice cap
    Yeah mine too, but I have to play with it when raising the spare trying to pull towards bumper and to the right, lest it ends up too close to the left side kdss boot, can barely fit a pinky in there
  28. Jan 17, 2025 at 11:48 AM
    #208
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    I have factory snow flake wheels on the spares. 2nd spare lives in the rafters in the garage using a block-and-tackle. It'll go on the roof for extended road trips.
    I will do 6 tire rotation.
  29. Jan 17, 2025 at 12:04 PM
    #209
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    I’ve seen conflicting answers on this, but will a 255 80R17 on OEM non-TRD wheels fit without rubbing or trimming anything?
  30. Jan 17, 2025 at 12:16 PM
    #210
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    No issues. I had steel oem wheels btw in the beginning.
