255/80R17 tire size
Discussion in '5th Gen 4Runners (2010-2024)' started by szuyung3000, Sep 27, 2018.
  1. Aug 15, 2024 at 12:47 PM
    #151
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    I think if I were looking at 255/75 I'd just go 275/70...but I'd probably go 255/80 over 285/70. I should have one more winter before I need to make a decision though (and should be lifted before then).
  2. Aug 15, 2024 at 12:55 PM
    #152
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Think fitting 255/80 is similar to 285/70? Only experience I have with 34s 285/75/17 is my buddies. Big jump from 285/70 to 285/75 suspension and cutting.
  3. Aug 15, 2024 at 1:26 PM
    #153
    Acesandeights
    Acesandeights #34
    2024 ORP
    I don't think so @2021venture . The narrower 255 allows for more clearance as you turn full-lock.
    Stoney Ranger and 2021venture like this.
  4. Aug 15, 2024 at 1:32 PM
    #154
    2021venture
    Todd
    2021 Venture
    It makes sense thinking about it. Toyotas have problems fitting wide tires not tall tires.
  5. Aug 15, 2024 at 2:55 PM
    #155
    CRasch505
    CRasch505 New Member
    Chris
    5th Gen 4Runner ORP
    Fifteen52 Analog HD's, Nitto Terragrapplers, 1" spacer lift front, ceramic on all glass.
    I just mounted some 255/80 AT4W’s. No rubbing and the ride great.
    djwantke, meats, Trail Runnah and 3 others like this.
  6. Aug 15, 2024 at 3:45 PM
    #156
    Stoney Ranger
    Stoney Ranger Lockers? Pffft
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-F/R Bpr-Winch-Stickers-ALF
    Thanx for the pic. I haven't seen many with 255's. I have the same rake and stance. When the 275's wear out, 255's are going on.
    CRasch505[QUOTED] likes this.
  7. Aug 15, 2024 at 4:10 PM
    #157
    fiddy5000
    fiddy5000 New Member
    2019 Classic Silver ORP
    I did last week as well - quite and rides nicely for an E rated tire.
  8. Aug 15, 2024 at 4:45 PM
    #158
    Do you have the same for a spare, just wondering if it fits underneath?
  9. Aug 15, 2024 at 4:50 PM
    #159
    fiddy5000
    It does
  10. Aug 15, 2024 at 4:52 PM
    #160
    2021venture
    Todd
    2021 Venture
    Tucks up a little more gaining some clearance also. This is from @Agent_Outside.
    meats, mostfrantic, fiddy5000 and 3 others like this.
  11. Aug 15, 2024 at 5:26 PM
    #161
    CRasch505
    Chris
    5th Gen 4Runner ORP
    Yep! 255 fit without any issues at all.
    fiddy5000 likes this.
  12. Aug 15, 2024 at 8:06 PM
    #162
    CRasch505
    Chris
    5th Gen 4Runner ORP
    For reference, I’m on an Eibach stage 1 lift, Dobinsons, UCA’s, some Dr KDSS brackets/clamps,drop spacers, Perry bumps, and a BMC. Doesn’t rub anywhere and it’s articulated about as much as I’ll ever need it to. Tire photo is the back of the rear tire IMG_6426.jpg IMG_6425.jpg
  13. Aug 17, 2024 at 7:51 AM
    #163
    java
    java fauxrunner
    2023 ORP ice cap
    Mine just fits, you can't slide your finger between the tire and KDSS arm, it's that tight of a fit. That's after airin down to 20psi.
  14. Aug 17, 2024 at 7:55 AM
    #164
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    Well I am happy with tiny 235/80/17's :yes:
    java and CRasch505 like this.
  15. Aug 19, 2024 at 3:59 PM
    #165
    Henry J
    Sacramento Ca
    Got mine put on today
    255/85r17 MT Baja boss
    Photon_Chaser, djwantke, roc and 5 others like this.
  16. Aug 19, 2024 at 8:30 PM
    #166
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I am going to pick our brain since I am debating this size. BMC(if not any rubbing)? How are you liking them.
  17. Aug 19, 2024 at 8:35 PM
    #167
    Henry J
    Sacramento Ca
    I got a BMC a little over a year ago. I had bad rubbing with 285/70 and -25 RRW wheels. Yeah, it was because of the wheels I know.
    I didn’t notice any issues, taking it in to Stellar Built to check it out though. Rather be safe than sorry.
    1SilverRunner likes this.
  18. Aug 20, 2024 at 8:08 AM
    #168
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Hey Todd I think you were referring to my build in your last few posts ;)
    The jump from 285/70/17 to 285/75/17 really wasn't that much. What required a ton of cutting was adding wheel spacers behind -12 offset wheels.
    1.25" spidertrax mounted behind 17x8.5 -12 equals a 17x8.5 -44 offset. The more common wheel size with the equivalent offset would be 17x9 -38.
    Just pointing out not to overlook offset. 255/85/17 (skinny 34) may have been slightly easier to fit for me. But if I wanted to avoid trimming the bumper and fenders I'd just remove the spacers. But I like the wider track width, the poke, and having the bigger contact patch personally.
    Another downside of the 285 width (other than weight and rolling resistance) is hydroplaning. Typically a skinny tire will be less susceptible to hydroplaning due to it's ability to "cut" through the water. The skinny tire simply has less water to evacuate.
    Lots of pros and cons to consider. The 255/80/17 (33") or the 255/85/17 (34") are both great options though. Just be mindful that wheel width and offset have a big part to play when it comes to trimming.
  19. Aug 20, 2024 at 9:04 AM
    #169
    Henry J
    Sacramento Ca
    Back from Stellar Built, had to do a little grinding for the pinch weld, just the lower point.
    like stated above, the issue was my -25 offset.
  20. Aug 20, 2024 at 11:50 AM
    #170
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    255 85 17s. BMC and lots of fender cutting. I still have some slight rubbing driver side when making left turns over bumps/holes. Need to get the grinder out and take a little more off.
    meats and hossler1788 like this.
  21. Aug 20, 2024 at 11:54 AM
    #171
    1SilverRunner
    Tejas
    Looks great! What width and offset are those Method's? Any wheel spacers?
  22. Aug 20, 2024 at 12:04 PM
    #172
    Henry J
    Sacramento Ca
    Dang man! Yours looks great!!
    coryanderson[QUOTED] likes this.
  23. Aug 20, 2024 at 12:07 PM
    #173
    coryanderson
    Cory
    Thanks! Very happy so far with them. I did a ton of suspension work just before I installed the tires and went from 285 70 KO2s on stock rims to this setup.
    Part number: MR70378560500, 8.5" wide and 0/4.8" offset. No wheel spacers.
  24. Aug 20, 2024 at 1:28 PM
    #174
    Acesandeights
    Acesandeights #34
    2024 ORP
    Why would you go with 8.5" wide wheels? It seems a 6.5" - 7.5" wide wheel would work better for that tire, increase tire life, hold a bead better off road, and limit rubbing.
    coryanderson likes this.
  25. Aug 20, 2024 at 1:31 PM
    #175
    coryanderson
    Cory
    I wanted Method Beadgrip wheels and I think this was the skinniest wheel they make that fits 4Runners with Beadgrip...
  26. Aug 20, 2024 at 1:35 PM
    #176
    Acesandeights
    Acesandeights #34
    2024 ORP
    You're right, it is.
  27. Aug 20, 2024 at 7:25 PM
    #177
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Man I wish I could test fit these tires first. The 255/80's look small on my 4Runner, I am 95% it will be rubbing on my body mount. I think I would fine in the rear. I have a high clearance cut in the front, but want to see if there would be any fender issues.
  28. Sep 15, 2024 at 7:50 PM
    #178
    meats
    meats New Member
    Broken Arrow, OK
    2018 Magnetic Gray TRD OR
    2/1 Cornfed Leveling kit Sway Bar Delete 285/70/17 - Arroyo Tamarock M/T
    What front bumper is that? Love that look. Nice!
  29. Sep 15, 2024 at 8:35 PM
    #179
    meats
    meats New Member
    Broken Arrow, OK
    Looks great- I am looking at some pizza cutters too. 255.80.17s
  30. Sep 15, 2024 at 8:36 PM
    #180
    meats
    meats New Member
    Broken Arrow, OK
    Looks pretty good tho. What lift do you have?
