255/80R17 tire size
Discussion in '5th Gen 4Runners (2010-2024)' started by szuyung3000, Sep 27, 2018.
  1. Jun 26, 2024 at 11:05 AM
    #121
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Big nasty tires!
    Thanks bud
    I know a lot of dudes in British Columbia running 35s in my groups that haven’t re-geared and at the moment I’ll likely be one of them because I can’t afford all that and I’d like to keep those components factory, Toyota. It’s part of the reason I booked a YotaTune OTT for low and mid torque…
    I haven’t told the wife about tuning, but I don’t think I’m gonna, We’ll see if she notices because she didn’t notice 1.25 inch spidertrax spacers or pedal commander LOL
    Haven’t told her about booking steel sliders mid July neither but I have a feeling she’ll notice :cookiemonster:
    captrussia253[QUOTED] likes this.
  2. Jun 26, 2024 at 11:27 AM
    #122
    Acesandeights
    Acesandeights #34
    So Oregon
    2024 ORP
    Some of us don't want a tire that wide. 265mm is a pretty good sweet spot for width. A 33x10.5 is a pretty nice size tire (ran them in the past, and would again if I could get the tire I want in that size).
  3. Jun 26, 2024 at 11:29 AM
    #123
    LunarTR4
    LunarTR4 New Member
    22’ TR4 ORP LR
    The only thing I have found are the BFG and Toyo in 34/10.5r17 which is essentially a ~265/80r17-ish...
  4. Jun 26, 2024 at 5:57 PM
    #124
    captrussia253
    captrussia253 New Member
    Ruslan
    Oh ya forgot about this size. But they’re so damn expensive.
    Acesandeights likes this.
  5. Jun 26, 2024 at 6:45 PM
    #125
    Woo Nelly 35x12.5 r big eh
    305 or 315/70 I may go
  6. Jun 26, 2024 at 8:56 PM
    #126
    3JOH22A Toyota Gigolo
    It is not, but you can drive a few minutes south of the wall to pick them up. :laughing: Kenda P/N 601015:
    AP1GczPzuvJykHz5pPhFc5RYCJ8iP8rXqqNwXmKO_ee729238a6eaec5d21e677b45b870eb8637d1268.jpg
    captrussia253 likes this.
  7. Jun 26, 2024 at 9:03 PM
    #127
    I guess I could eh hmmm
  8. Jun 26, 2024 at 9:05 PM
    #128
    whats dis
  9. Jun 26, 2024 at 9:10 PM
    #129
    ^You wanted a 35x10.5-17" tire? This one happens to be very good off-road.
