255/75r17 Geolandar at go15 anyone?
Discussion in 'Wheels & Tires' started by Trees91, Jan 22, 2023.
  1. Mar 22, 2023 at 6:43 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    Finally got my yokos on.
    1311689C-BB68-4FF6-9BF9-3A1FCA545F88.jpg 4CAF361F-62E6-4D50-A0F5-30B0E580BCD8.jpg
  2. Mar 22, 2023 at 6:50 PM
    If you happen to test them on snow and ice on pavement would love to hear your thoughts. Yoko Geolander AT G015 & Cooper Discover AT3 4S is high on my list for my Limited when Falken Wildpeaks AT3W are done or if I get a really good offer for them.
    mrmike7189 likes this.
  3. Mar 22, 2023 at 6:54 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    Will do. With any luck we'll be done with snow, but not likely....had 4" this morning. All melted off the roads already, missed testing the yokos out by a few hours.
  4. Mar 24, 2023 at 7:55 AM
    LunarTR4
    LunarTR4 New Member
    22’ TR4 ORP LR
    They look great! I bet they ride well too. I have a set of these on my 2015 Crosstrek drove around Lake Tahoe in January with no problems with ~ 50K miles on them.
    I almost got the P-Rated version of these for the 4Runner, but ultimately went with the E-rated version.
  5. Mar 24, 2023 at 1:50 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    I really like how the e rated look. A lot more tread and squared off shoulder lugs. I've always ran e rated tires on my pickups and jeeps but wanted to keep the 4Runner tires light....it'll be on the highway the majority of the time. And when these came up for $170 a piece I just couldn't pass them up.
  6. Mar 24, 2023 at 2:46 PM
    LunarTR4
    LunarTR4 New Member
    22’ TR4 ORP LR
    That price and weight of the P-rated versions are hard to beat. I strongly considered it, I decided to do the E-rated for insurance because of the rocks around here.
  7. Mar 24, 2023 at 8:41 PM
    4runningMan
    4runningMan New Member
    New Mexico
    How are they on snow/ice?
    mrmike7189[QUOTED] likes this.
  8. Mar 24, 2023 at 9:25 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    Finally put a few miles on mine. No snow or ice yet. They're quiet, maybe a little noise over the factory duelers but still very quiet. They throw tons of small rocks and road grit. Our main highway into town is cement with some groves. They tend to follow the groves more than any at tire I have had. I kinda saw it coming, they have the "longitudinal" lines in the tread that tend to wander. Duelers did it as well as the factory tires on a lot of my older vehicles.
    Averaged 20mph on the 22mile drive home so I'm happy.
    mrmike7189 and nicko524 like this.
  9. Mar 26, 2023 at 7:51 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Get you alignment redone. Have them add caster. There a couple threads on it.
    It'll help with the wandering.
    Did you get any shimmy or viberate in the steering wheel?
  10. Mar 26, 2023 at 8:18 AM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    Zero feeling in the steering wheel. Balance feels perfect.
    Alignment Wednesday.
    Do you think pushing caster forward will lessen the "darty" feeling? It did it with stock duelers too. Or are you just thinking for more clearance?
    "slacked" our caster makes me think of a downhill bike, slaked out head tube to make it less darty....maybe not the same idea with a car....or maybe it is.
    Camber definitely needs adjusted. Can tell it's on the positive side.
  11. Mar 26, 2023 at 9:25 AM
    Accelerator
    Accelerator New Member
    Chris
    Satellite Beach, Fla
    2022 SR5 Super White 4Runner #3
    Yes, it should absolutely get rid of that darty feeling. Your truck will want to straighten itself naturally while driving down the road. I replaced my entire suspension and the new UCA’s pushed my castor past 3 degrees and now it wants to track straight. Previously, from the dealer it had been a bit darty as you say.
  12. Mar 26, 2023 at 9:43 AM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    Darty through the steering wheel too? This has no feed back through the wheel.
    It's mostly the tire and road combo. Only about a 15 mile stretch of cement road that has some pretty aggressive groves in it.
    Our outback did it before I put Toyo open country at3 on. My f150 did with stock tires, but in no longer does with the falken wild peaks.
    Either way I will ask if they can push the caster forward and report back.
  13. Mar 26, 2023 at 10:00 AM
    Accelerator
    Chris
    Not really sure about the steering wheel, although the wheel would turn when the tires would wander.
    When you get your alignment, see if they’ll provide a printout of the before and after numbers. I’m curious what your current castor is. Mine is a bit over 3* on both sides and it tracks straight and rides smoothly. Let me add, I drive 40 miles each way to work on the interstate between 80-85 mph (that’s the normal speed around here) and any issues would be magnified pretty quickly.
  14. Mar 26, 2023 at 11:37 AM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    It's an odd feeling. Can feel the back wander too. I'll see if I can get the alignment specs on Wednesday. I'll be sure to ask about pushing caster forward.
    And it's just this bit of cement road. Smooth as can be on asphalt.
    hossler1788 likes this.
  15. Mar 29, 2023 at 12:08 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    Well it's at the alignment shop as I type. Guy said you usually can't add any caster so I don't have very high hopes.
    I asked for a spec sheet before and after so we'll see what happens.
  16. Mar 29, 2023 at 1:15 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    Better than I thought...I think?
    How's it look?
  17. Mar 29, 2023 at 2:52 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    How's it drive?
  18. Mar 29, 2023 at 2:54 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    Feels good. Very little input to keep it going down the road.
  19. Mar 31, 2023 at 1:31 PM
    #49
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You gotta post more pictures! Do the 255s come off narrower then stock? I'm curious since you added 8.5" wide wheels.
  20. Mar 31, 2023 at 1:41 PM
    #50
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    I don't think they look any narrower. I think the wheel width might help. I need to get some more pictures one of these days. Been trying not to drive it too much. Nasty, wet, salty roads lately.
    Heres one from the other day while cleaning the garage.
    pre alignment..
  21. Mar 31, 2024 at 4:25 PM
    #51
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    New picture just cuz...i always had a hard time finding pictures of 255/75s on a 4Runner.
  22. Mar 31, 2024 at 4:49 PM
    #52
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    They are very good in snow ice sleet. The rubber compound is a little soft.
    Yokohama literature says that the rubber compound is infused with "orange oil." Whatever that means?
    They are not super in deep snow....but that's what I have 4 wheel drive for:yes::D
  23. Mar 31, 2024 at 5:04 PM
    #53
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    I've had them a year now. Been pleased with them. I really haven't driven in much snow, when it's snowy wet or salty I drive my rusty old paid for pickup. The 4Runner has had a pretty easy life so far. Few trails and fire roads this summer but other than that just highway miles with the family.
    Klinsman55 and mrmike7189 like this.
  24. Apr 30, 2024 at 8:51 PM
    #54
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    will this size tire fit well on stock ORP wheels or TRD Pro wheels?
    im very tempted to to sell my Wildpeaks and get Coopers or Yoko AT tires.
  25. May 1, 2024 at 4:05 AM
    #55
    Shanky
    Shanky New Member
    Had 255/75 Ko2s for nearly 20K miles. I won’t go back to wide. Performance /efficiency trump “looks”
    kolter45 and Klinsman55 like this.
  26. May 1, 2024 at 6:50 AM
    #56
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    They should fit just fine. Even on stock suspension I don't think you'll have a problem. I just have a 1" level and there's plenty of room.
    Klinsman55[QUOTED] likes this.
  27. Jul 23, 2024 at 8:48 PM
    #57
    Klinsman55
    K
    Northern Nevada
    2024 LE silver
    Hopefully will be mounting these tomorrow
    Trail Runnah likes this.
  28. Jul 29, 2024 at 8:46 AM
    #58
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    Is your front end ride height OE? It just looks leveled in the pics. Im looking at the 255/75 go15s for my 19' MGM b/c i had um on a 3rd gen and liked um. I have 6112s installed up front @ 1".
    thanks.
  29. Jul 29, 2024 at 9:40 AM
    #59
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    It has a 1" level. Just a simple cornfed spacer. I'll do 6112s sometime down the road.
  30. Jul 29, 2024 at 9:55 AM
    #60
    CA4runner
    Nor Cal
    2019SR5
    Ah .Thanks
    Any chance youd be able to post a straight side shot? I'd be using 7" wide Pro rims and was wondering if i might end up with more height..
