255/75 R17 who's running them?
Discussion in 'Wheels & Tires' started by Charlievee, Jan 2, 2019.
  1. Apr 13, 2023 at 9:46 AM
    topdec
    topdec New Member
    2023 4R ORP CSM 2023 Tundra LTD ORP. 2016 4R TE (sold)
    From my experience the Cooper AT3 4S were stiffer than stock Dunlop (4R) and Geolandar (Tundra) tires, but really shine on snow/ice-covered roads.
    kmeeg likes this.
  2. Apr 13, 2023 at 1:08 PM
    Shanky
    Shanky New Member
    Not close to rubbing. It is barely over 32 inches.
    topdec[QUOTED] likes this.
  3. May 2, 2023 at 9:24 AM
    Metal4Ever
    Metal4Ever New Member
    Do you have a front and rear pic of these tires?
  4. May 2, 2023 at 11:37 AM
    topdec
    topdec New Member
  5. May 2, 2023 at 1:44 PM
    Shanky
    Shanky New Member
    Here are some front /rear 3/4 views. I will take some straight on later this week.
  6. May 3, 2023 at 7:42 AM
    Shanky
    Shanky New Member
    Here you go. These views should give you the “tall skinny” perspective. I still really like the tires, and fuel Econ is virtually unchanged from stock.IMG_1677.jpgIMG_1679.jpg IMG_1680.jpgIMG_1676.jpg
  7. May 4, 2023 at 7:04 AM
    Metal4Ever
    Thanks, looks good
  8. May 4, 2023 at 9:06 AM
    Fisch
    Fisch New Member
    Jacksonville, Fl
    2018 TRD ORP
    Empty wallet
    This may be a little easier to read, but still doesn’t truly answer the MPG question.
  9. May 4, 2023 at 2:10 PM
    Shanky
    Shanky New Member
    I know it is anecdotal, but for 6,000 miles on the KO2 275/75 17’s my MPG is about the same as it was on the Stock tires, which we had for about 40,000 miles. Without correcting for the slightly larger diameter, I am seeing mileages from known routes about +/- 2 tenths of a MPG. I did have one long highway run of about 1200 miles. I was actually disappointed on the way up with about 19.5 MPG, but the return trip was near 21 MPG. Strong wind was the likely culprit. Into a strong north wind on the way up, it was on my tail on the way back. Also, I Usually only run at 74 MPH on the interstate, 65 when towing.
  10. May 4, 2023 at 4:02 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    255 75 17 yokohama a/t are cheap on Amazon right now. I'm debating if I want to jump down from 285 70 17s, I'd save on gas, but id lose the sex appeal.
  11. May 4, 2023 at 11:28 PM
    topdec
    topdec New Member
    What contributes more to drop in mpg, the extra width of the 285s or the added height? My real question is if you've considered 255/80R17s.
    BC Hunter likes this.
  12. May 5, 2023 at 9:29 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I honestly can't complain about the gas mileage. Im averaging 350-375 miles from full to when the gas light comes on. So with 285s I'm averaging 18mpg....
    I looked into 255 80 17, just since they are all e rated they weigh more then my p rated 285s so there's that. But lot of the 255 75 17s actually measure 32" where my 285 70 17 measure 31.75".
    My next tires are going to be the 285 70 17 maxxis razrs a/t. They are still on the cheaper side(less then $800)
  13. May 5, 2023 at 12:09 PM
    topdec
    topdec New Member
    Why do you think this is the case with 285s? Is it a specific brand with this inaccurate height?
  14. Apr 12, 2024 at 1:22 PM
    david9962000
    david9962000 New Member
    Los Angeles, CA
    I wanted to bump this thread for feedback?
    I'm about to switch to 255 75 17.
    Thank you.
  15. Apr 12, 2024 at 4:21 PM
    id rather have 285s and mine measure at 33”
  16. Oct 3, 2024 at 12:03 PM
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    LT C Load Hankoook At2 Extremes on 7" 255 1.jpg 255 2.jpg pro rims. 6112 set @ 1" front & OE rears for now
