2024 TRD PRO vs ORP w/KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by Fun Times 4Runner, Apr 4, 2024.
  1. Apr 7, 2024 at 9:59 AM
    #61
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Nope :oops:
  2. Apr 7, 2024 at 10:18 AM
    #62
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Lol
    I'm sure it's on the list
    That's OK, I can't even afford rear bumper, regear, or front locker on my list
    Yotaholic[QUOTED] likes this.
  3. Apr 7, 2024 at 12:31 PM
    #63
    garoto
    garoto New Member
    What does it do?
  4. Apr 7, 2024 at 1:58 PM
    #64
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    you have to! It’ll change the ride for the better on dirt roads
    turns off kdss.
    Kdss sucks on dirt roads/washboards at speeds.
    kdss is great for slow off roading (articulation) or avoid body roll when going faster on pavement
  5. Apr 8, 2024 at 10:48 AM
    #65
    Krup235
    Krup235 New Member
    I can’t complain about buying the PRO. It is pricey if your going to strip it down and build it back up with aftermarket.
  6. Apr 8, 2024 at 12:20 PM
    #66
    Krup235
    Krup235 New Member
    Couldn’t agree with you more. Got a couple jeeps myself. Never had KDSS so not sure of how good it is.
  7. Apr 8, 2024 at 12:20 PM
    #67
    Yotaholic
    Olympia, WA
    You can disconnect the swaybar on all Wranglers, Rubicon is eletronic and convenient. And KDSS shines more on the road, offroad is just a bonus
    STrooper and semprenissart like this.
  8. Apr 8, 2024 at 12:36 PM
    #68
    Does Rubicon have solid front axle and sway bar disconnect?
    Yotaholic likes this.
  9. Apr 8, 2024 at 12:44 PM
    #69
    Yotaholic
    Olympia, WA
    I read that KDSS was the invention of an Aussie company. They sold it to Toyota, Toyota refined it and started putting it in their vehicles. A pretty unique system if you think about it.
  10. Apr 8, 2024 at 12:46 PM
    #70
    Yotaholic
    Olympia, WA
    The JL Wrangler is nothing like the JK and TJ, they are very comfortable for what they are. The V6 is is smoorh and the ZF transmissiin is phenomenal
    djwantke likes this.
  11. Apr 8, 2024 at 12:49 PM
    #71
    Totally agree. Thanks for this
    And this is said time and time again, 4R's aren't rock crawlers and you shouldn't bother trying.
    But, when ya say "I have kdss on my gx... it's not that great...solid axle if you want to maximize articulation. my opinion."
    -its kind of an apples and oranges comparison. Nothing is great compared to solid axle with disconnect. Shouldn't compare KDSS or XREAS or PRO fox setup to a solid axle, period imo
  12. Apr 8, 2024 at 12:53 PM
    #72
    Yotaholic
    Olympia, WA
    They are pretty good, the only problem is the Jeep tax which breaks your back. You can configure a 2024 two-door Rubicon X with the Recon package for over $80,000. A great thing with this new Recon package is that you can ask the dealer to mount 37s, and it will not void the warranty, and it will have zero rubbing. But I wouldn't do that. I would buy a TJ for 15, and then rebuild it.
  13. Apr 8, 2024 at 12:54 PM
    #73
    TXRunner1979
    TXRunner1979 New Member
    Exactly! There is a reason "PRO envy" is a thing...JS:p and 90% owners of non-pros change looks to PRO facia, wheels, rack, you name it...
  14. Apr 8, 2024 at 12:57 PM
    #74
    semprenissart
    semprenissart Mèfi
    In terms of ride manners, I’ve never felt as planted in my TJ as in my 4R. Granted the TJ is on 35s and a solid front axle so apples to oranges here. In terms of engine both 4.0L 6 cylinders are more reliable than the JK and JL so no complaints there. TJ is obvi more fun than the 4R when rock crawling not just because of the tires and axle but also because mine has a stick. But the 4R easily beats the TJ when going far away on pavement to get to dispersed camping trails or “high speed” desert off roading. I’m getting sidetracked… lol
  15. Apr 8, 2024 at 12:59 PM
    #75
    STrooper
    STrooper Let’s Go Places!
    Lol, you got something right, 90% of smart people change the look to "Pro facia" to save thousands from the stealerships:thumbsup:...now that's how you do it!
  16. Apr 8, 2024 at 1:01 PM
    #76
    This is all true lol
    But then there's non-pro dudes like me, ZERO pro features or looks, no badges, no OE stuff - virtually all aftermarket upgrades n mods :p
    STrooper likes this.
  17. Apr 8, 2024 at 1:04 PM
    #77
    Nice man
    I've never operated a Jeep, I kinda wanna save for one on the side.
    If the 6th Gen 4R comes with stick shift, I'm all of the sudden very interested
    semprenissart[QUOTED] likes this.
  18. Apr 8, 2024 at 1:26 PM
    #78
    broken-giver
    broken-giver BFD
    when we settle this debate can you guys pls. discuss which oil is best, and what frequency of oil change is the best?
    For the record I have ORP I don't feel the need to defend it, nor do I feel the need to call out pro owners. I am not paying for their car so why should I care?
    semprenissart and brodeyo like this.
  19. Apr 8, 2024 at 1:31 PM
    #79
    But you do feel the need to pipe in and shit on us haha
    I don't disagree with you btw
    I often fall victim to deep off topic chatter on here.
    My bad
    That being said, your comment sounds like someone who says the dreaded, "it doesn't affect your life so why do you care"
    broken-giver[QUOTED] likes this.
  20. Apr 8, 2024 at 1:35 PM
    #80
    broken-giver
    broken-giver BFD
    :D
    I have chimed in in the past, but I want to make an effort to tone it down. I should care less, because its not my money and everyone likes different things :)
    djwantke[QUOTED] likes this.
  21. Apr 8, 2024 at 1:43 PM
    #81
    Yotaholic
    Olympia, WA
    I have FJ40 look
    TRDSD and brodeyo like this.
  22. Apr 8, 2024 at 1:53 PM
    #82
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    You also get the jbl subwoofer with the pro.
  23. Apr 8, 2024 at 1:56 PM
    #83
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    I got my pro last month with no markup. they had a 10,000 mark up on it originally and i said im not paying that, and they said ok haha
  24. Apr 8, 2024 at 1:58 PM
    #84
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    Love the black trd pro, wanted underground, settled for ice cap
  25. Apr 8, 2024 at 2:05 PM
    #85
    STrooper
    Lol
    brodeyo likes this.
  26. Apr 8, 2024 at 2:11 PM
    #86
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    Bruh i love dr. Gregory house. But ya the subwoofer does sound good
  27. Apr 8, 2024 at 2:11 PM
    #87
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    How many miles you got haha
  28. Apr 8, 2024 at 2:13 PM
    #88
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    Mad cuz you dont have a pro or kdss
  29. Apr 8, 2024 at 2:18 PM
    #89
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    The more I think about it. This topic is silly. Trd pro all the way (and I have a sr5p)
  30. Apr 8, 2024 at 2:21 PM
    #90
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    Its all 4runner love
    hossler1788[QUOTED] likes this.
