2022 needle bearing issues
Discussion in '5th Gen 4Runners (2010-2024)' started by Tmiesowicz, Jan 19, 2022.
  1. Mar 6, 2023 at 12:47 PM
    #211
    Superdave1.0
    Superdave1.0 New Member
    LX470
    I've done 3 in the last week lol. They come in waves.
    Breeze, Toy4X4 and MyWyfsRnnr[QUOTED] like this.
  2. Mar 16, 2023 at 10:19 PM
    #212
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
  3. Mar 16, 2023 at 11:01 PM
    #213
    4runningMan
    4runningMan New Member
    New Mexico
    So strange that this issue persists through the years. There must be a reason why they stick with the same part? I can’t make it make sense.
    LuLu likes this.
  4. Mar 18, 2023 at 7:36 AM
    #214
    MAXIM
    MAXIM New Member
    There is, MPG. Sleeve has more friction than Needle Bearing. I lost 1 MPG after sleeve install (18 before 17 after, consistent for years now). Regardless, I'll take ECGS bushing any day over poorly engineered bearing. Shame on you, Toyota!
    Toy4X4 and MyWyfsRnnr like this.
  5. Apr 19, 2023 at 7:09 AM
    #215
    4runningnoob
    4runningnoob New Member
    Hey, super new to the forum and first time 4Runner owner. I have the 2022 Trail Edition with 15K on it. Had the rumbling noise and took it to the dealership. They rode in it with me, put it up on a lift and ordered a new diff. On the spot. No Hassel, no questions asked. Not happy about it on a brand new vehicle but dealership took care of it. Just wanted to share my experience.
    Tmiesowicz[OP] and Toy4X4 like this.
  6. Apr 19, 2023 at 10:21 AM
    #216
    That's good news. Mostly. Hopefully the 2nd diff will last longer. Same design.
    Toy4X4 likes this.
  7. Apr 19, 2023 at 10:26 AM
    #217
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    You may want try check out the thread below. So far replacing those plastics worked for me.
    Still testing out since last week. No noise. Waiting for temperature to drop to lower 30F before reaching a conclusion.
    The 2022/2023 have a superseded differential from Japan.. not same as the older ones
    https://www.4runners.com/threads/plastic-noise-while-moving.29304/
  8. Apr 19, 2023 at 10:31 AM
    #218
    But still use a needle bearing. If 2022/2023 have a superseded differential, why would @4runningnoob have to get a new differential? His is a 2022
    MyWyfsRnnr likes this.
  9. Apr 19, 2023 at 10:36 AM
    #219
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Pardon my limited knowledge. Just out of curiosity i went to the parts department with my VIN.
    Was told that my differential was new and only available from Japan. Backordered. Without any delivery dates.
    That was last year though.
    Also. I wanted @4runningnoob to be aware of the part numbers been ordered and installed.
    The service Department might be going the extra miles to please the customers or just making a quick buck.
    Best of luck.
  10. Apr 19, 2023 at 11:38 AM
    #220
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    I don't believe the service department replaces just the bushings... Right
  11. Apr 19, 2023 at 1:28 PM
    #221
    So I agree that a service department would replace the differential, not just the needle bearing. My point in Post #217 above is that a replacement differential will not insure that the needle bearing won't prematurely wear again. New diff, same design, same needle bearing. Hopefully someone at Toyota figured out the old differential was not cutting the mustard, as they say, and replaced it with one that has tighter tolerances, but I wouldn't put any money on it.
    Toy4X4, MyWyfsRnnr and LuLu[QUOTED] like this.
  12. Apr 19, 2023 at 2:25 PM
    #222
    Technically speaking, the differential itself isn’t the problem. The needle bearing isn’t really the problem either, as a brand new one with zero wear will make noise. The problem is the excessive play between the CV as it sits in the bearing. This is the reason a new bearing with the same dimensions doesnt reliably solve the problem.
    Toyota could just as easily make CV axles that are a tiny bit bigger in outside diameter where they go into the needle bearing, or source needle bearings that are a tiny bit smaller inner diameter. Instead, they replace a differential that (by all indications) has the the same CV/needle bearing clearances.
    Their decision to “solve” the problem by replacing the entire diff assembly (presumably because something about replacing a needle bearing in the field is problematic for them?) unfortunately just gives the impression that something is wrong with the diff. The diff itself is pretty solid.
    I just don’t get toyota’s reasoning.
    Old Tanker, MyWyfsRnnr and LuLu like this.
  13. Apr 19, 2023 at 8:43 PM
    #223
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Bingo to you both. Both are dead on! @glwood54 unfortunately no, nobody has made the call to fix it at Toyota. The 2023's have the same issue from the showroom floor. Super disappointing.
    @McSpazatron dead on... The tolerance is 100% the issue paired with needle bearings that are not as strong as roller/barrel etc bearings or bushings. I am going to pull our CV and document the wear on the ECGS bushing when we have 50k miles on ours as well. Curiosity is gunna kill the axle seal haha!
  14. Apr 20, 2023 at 6:37 AM
    #224
    Thank you. Some time back, I asked if anyone could show the difference in the needle bearing vs the ECGS bushing once the axle was out, and the bearing/bushing slid onto the axle...would you happen to have a video showing the two items' different tolerances, perhaps?
  15. Apr 20, 2023 at 7:46 AM
    #225
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    semprenissart, Toy4X4 and jdm-v35 like this.
  16. Apr 20, 2023 at 10:56 AM
    #226
    MyWyfsRnnr[QUOTED] likes this.
  17. May 8, 2023 at 5:59 AM
    #227
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    I just ordered 4 more to keep in stock. Nobody in our area (Sacramento CA) actually stocks these for emergency so I keep some on the shelf in my backyard shop for working on forum trucks and Runners
    Toy4X4 likes this.
  18. May 8, 2023 at 6:07 AM
    #228
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    I had the ECGS bushing upgraded preventatively on my 2021 while suspension being upgraded. No issues and only 10k on the truck but worth it to me to upgrade with superior part preventing the issue from happening.
    Han4Run, Toy4X4 and MyWyfsRnnr like this.
  19. May 8, 2023 at 6:39 AM
    #229
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I have not experienced this issue (yet).
    I have almost 14k miles on mine. Can this issue show up after tens of thousands of miles or if it hasn’t appeared at the beginning does it mean it’ll be fine?
    why some people have the issue brand new while others don’t?
    Are some of the parts defective to begin with?
    From what I read here it almost seems like it doesn’t matter, the Toyota part is a faulty design. If so, why it doesn’t happen to everyone right away and is it just a matter of time before this issue occurs in any 4R?
    thanks for educating me on the subject as I have no idea about it.
  20. May 8, 2023 at 6:47 AM
    #230
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    https://www.tacomaworld.com/threads/needle-bearing-yes-replace-it-ecgs.716338/page-11#post-28504506
    Jump up a few posts to see the videos I took of the play etc
    Bob and semprenissart[QUOTED] like this.
  21. May 8, 2023 at 7:05 AM
    #231
    semprenissart
    semprenissart Mèfi
  22. May 8, 2023 at 8:05 AM
    #232
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    In my opinion, it is geometry and tolerances. A lift will increase the likelihood of feeling/hearing the issue because it increases the angles and pressure that the needle bearing sees. In my opinion, every, Toyota has the issue wether the driver feels it or not (look at the videos I posted with a brand new truck, no lift, and how much the driver moves vs the passenger). I consider the play excessive and unacceptable direct from the factory. Eventually parts wear and tolerances open up. It just may not be felt or get bad enough to be a real issue for some. Personally, I see the ECGS bushing as a preventive mod. I have pulled and changed one differential for a customer that the needles have grenaded into and it was not pretty. Big money repair for a relatively easy prevention.
  23. May 8, 2023 at 9:05 AM
    #233
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    That got me intrigued on my 2022 T4R TRD Sports too. Was hearing annoying groaning/clicking noises on cold days but stops when temps reach 70F outside.
    Finally isolated the noise to the engine splash guard and clip pins. (through this forum)
    Pardon me if this is totally unrelated. Newbie.
    It was driving me nuts for almost a year of ownership. Until now.
  24. May 12, 2023 at 12:03 PM
    #234
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    Just got mine done from @MyWyfsRnnr. My symptoms were atypical (vibrating only from 45-48) but nonetheless when pulled it off I had grind marks and some shavings. 2022 ORP with 12k. Lifted 2" KDSS.
    He also had some late mileage stock Runner examples (old bushings) on the wall. Lift just doesn't matter folks.
  25. May 12, 2023 at 1:56 PM
    #235
    Is your symptom now gone?
  26. May 12, 2023 at 2:48 PM
    #236
    icyhotahs
    Samuel
    Sacramento, CA
    Yessir. Smooth as can be.
    Before it was a synchronous vibration resembling running over the "wake up" bumps near the highway shoulder.
  27. Jun 1, 2023 at 7:16 PM
    #237
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    My ECGS bushing is coming Saturday. Going to install next Monday. 2019TRD ORP. Stock suspension until about 58K. 2" front lift installed. Now at 75K and get noise and vibration around 65-72MPH. Sound and vibration goes away when in 4 Hi. Thanks to all the good info on this forum!
  28. Jun 3, 2023 at 2:35 AM
    #238
    Matt83
    Matt83 New Member
    Northeast
    Mine issue showed up early at 6,000 miles. Dealer replaced the front diff, I am at 42,000 miles now and it is still quiet. Next go around will be the bushing install. On the original diff I had the noise and vibration at around 35-45 mph in cold weather, went away in 4HI.
  29. Jun 3, 2023 at 10:23 AM
    #239
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Consider changing to the bushing whenever you have some time and are feeling frisky.... Better to be preventative than forced at an inconvenient time. It is a shame that Toyota is still installing these diffs and just swapping when there is an issue. Seems like a waste of resources when there is such an easy fix out there.
    Guppy1301 and Toy4X4 like this.
  30. Jun 11, 2023 at 9:41 PM
    #240
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Did the bushing upgrade job today as part of the 30K service.
    ECGS makes a great kit. The oil seal and bushing installers are easy to use.
    As some others have mentioned, the puller had to be ground down just a bit to be able to fit behind the bearing. No big deal.
    Job took 3 hours. Probably spent 30m of that making a puller for the front hub assembly. Steering wheel puller I had was not wide enough. Hut assembly is already drilled and tapped for puller screws.
    Needle bearing was intact and pulled with no problems.
    After new bushing installed.
    Truck drives nicely. Vibration/hum really hadn't become much of an issue. Was intermittent and rare. Just wanted to take care of it pre-emptively as the truck is a bit lifted and we take it off road and tow a camper pretty frequently (why we have this truck).
    Jason
