2022 Limited Full Build
Discussion in 'Audio & Video' started by LadeDruck, Feb 28, 2023.
  1. Jul 3, 2023 at 5:50 PM
    #61
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
  2. Jul 3, 2023 at 6:06 PM
    #62
    LadeDruck
    LadeDruck [OP] New Member
    2022 Pearl Effect White Ltd.
    the connections to the alternator are a buss bar design, not a loop terminal or lug. The reason is for compact fitment, that said the routing around the alternator would be meh if changed. When the alternator gets upgraded one day I may consider it.
    also the aggravation of having to fuse all the positive leads as done with the factory clamp.
    lastly no need, iirc it’s a 3ft run of 4ga…. It has the capability of carrying a ton of current in that short of run mitigating any benefits of running 1/0 to reduce impedence. Upgrading the battery to chassis ground was warranted, but otherwise there is really no need for a big 3 in this specific application without a serious build. Remember in the 90s a car would have an 8ga (or worse 10/12 ga) for a ground, modern care demand more and therefore are built to a much higher electrical standard.
    Rob41[QUOTED] likes this.
  3. Jul 3, 2023 at 6:50 PM
    #63
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Thanks for the info.....your knowledge is greatly appreciated!
  4. Jul 21, 2023 at 10:52 AM
    #64
    LadeDruck
    Update:
    had to take the elite out for now, the weight caused strain on the rack (as expected).
    Hd1200/1 sitting in its place for now.
    next phase will be the fall, big changes to the back.
  5. Aug 1, 2023 at 2:15 PM
    #65
    LadeDruck
    Mods: delete my account and remove posts.
    this site is a joke.
  6. Aug 1, 2023 at 7:16 PM
    #66
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Why do you think so? I mean other than there's not much activity and not many people really doing much.
    Edit: checked your post history. I totally get it. Nothing too crazy going on here. I asked on reddit what the best rrunner forums were because this forums isn't all that active and someone said T4R. I went there and get bombarded by ads.
    Reddit is pretty lame. It's just instagram.
    Maybe some crazy 4x4 forums? I've looked around a little but not much.
