2021 Pricing Announced
Discussion in '5th Gen 4Runners (2010-2024)' started by Red_5, Jul 30, 2020.
  1. Aug 1, 2020 at 8:22 AM
    #61
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
    I do find myself amazed at how cool the interior stays in my super white 4R. We were in Leavenworth and it was +90° outside and after sitting for 3 hours, the interior wasn’t that bad. I thought we’d be getting into an easy bake oven.
    Singleminded likes this.
  2. Aug 1, 2020 at 9:55 AM
    #62
    will van
    will van New Member
    Will
    2019 Toyota 4Runner TRD ORP and 1977 FJ40 Land Crusier
    Dumb question - What tires come stock on the 2020 and 2021 4Runner OR/ORP? Bridgestone Dueller? I'm guessing that a set of genuine off-road tires should be my first purchase if I intend to use the truck for actual off-roading?
    Singleminded and NightRunner like this.
  3. Aug 3, 2020 at 7:34 AM
    #63
    Red_5
    Red_5 [OP] New Member
    Correct. Tires are far more important than lifts. Give me a stock truck on good tires over a lifted truck on Duellers every time.
  4. Aug 3, 2020 at 7:41 AM
    #64
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    I chuckle when I see car mag reviews reporting the number of feet it takes for the car to stop from, say, 70 mph. Most of that number depends on tires that can easily be upgraded, not the braking system itself. Hard to overstate the importance of good tires.
  5. Aug 4, 2020 at 11:20 AM
    #65
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    So these are stock tires for 2020 TRD OR and are they THAT bad for snow, logging roads and light gravel ?
  6. Aug 4, 2020 at 8:10 PM
    #66
    Ianv18
    Ianv18 New Member
    2020 Trd orp
    Heritage grille blackout and led
    If you have the same ones stock as I got then they will work for snow and ice as well as any basic car made these days but I'm in florida so they work for me. If I had your environment the better A/T tires would be worth the early upgrade
  7. Aug 6, 2020 at 12:55 PM
    #67
    NightRunner
    NightRunner New Member
    Tyler
    2020 Venture
    Fair question actually. Mines a '20 and came with the Duelers. I replaced them last month with some A/Ts and there's definitely a noticeable improvement in handling and traction, even on dry pavement. I'd say tires should ABSOLUTELY be your first purchase if you're taking it off-road. Plus, they look better. :cool:
    mrmike7189 and Singleminded like this.
  8. Aug 6, 2020 at 12:57 PM
    #68
    will van
    will van New Member
    Will
    Thanks, I agree. I have continued to do research since asking my question.
    I'm most likely going to buy 275/70/17 BFG AT KO2s immediately after purchase. I'm 99% sure they will fit the stock TRD ORP suspension and "Trail" wheels without any rubbing.
    wmdtech and NightRunner[QUOTED] like this.
  9. Aug 6, 2020 at 1:07 PM
    #69
    Singleminded
    OEM LED foglights
    I realized after buying my 2020 Limited that the stock Duelers are relatively craptastic. There's a good version of the Dueler for highway use (the H/L "Alenza Plus") but these sure ain't it.
    My plan is to switch to Toyo AT3 once these are worn -- or immediately if I end up moving to a more wintry climate. Fortunately they come in the stock 20" size for the Limited. I know the AT3 doesn't have reviews yet, but it seems a pretty safe bet given the good reviews on the AT2. Plus it has the severe snow service designation. So seems like a good compromise choice that works well on the highway, is good in slippery stuff and is decent off road should that be needed in a pinch.
    NightRunner[QUOTED] likes this.
  10. Aug 7, 2020 at 7:46 AM
    #70
    Do you have a part # & link for the place you got your OEM LED fogs (or did you get them from the dealer)?
  11. Aug 7, 2020 at 8:02 AM
    #71
    Singleminded
    OEM LED foglights
  12. Aug 7, 2020 at 8:40 AM
    #72
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    I ran 275 on stock suspension on mine for about 6 months, minor rubbing at full lock in reverse on the fender liner. Easy fix so you'll be fine.
  13. Aug 7, 2020 at 12:11 PM
    #73
    will van
    will van New Member
    Will
    What wheels were you running? Trail? TRD Pro? Other?
  14. Aug 7, 2020 at 5:54 PM
    #74
    will van
    will van New Member
    Will
    Just to throw another curve ball...How do you guys feel about the optional moonroof?
  15. Aug 7, 2020 at 11:17 PM
    #75
    wmdtech
    Nate
    Mid TN
    18 TRD ORP
    The gray pro wheels
  16. Aug 8, 2020 at 3:24 AM
    #76
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    I hardly use mine and would be happier without it.
  17. Aug 8, 2020 at 5:49 AM
    #77
    Red_5
    Love mine. Got it tinted along with my windows so the sunshade stays open most of the time.
    And moonroof + back window open is a very nice way to cruise around town. Very little buffeting.
    will van[QUOTED] likes this.
  18. Aug 8, 2020 at 7:14 AM
    #78
    will van
    will van New Member
    Will
    Gotcha. I wonder if the rubbing would be worse with the stock Trail wheels?
  19. Aug 8, 2020 at 9:39 AM
    #79
    You probably wouldn’t rub at all with stock trail wheels and 275s. The pro wheels have a lower backspacing than the trail wheels, which pushes them out a little further. This is why Toyota does the fender liner mod on the pros at port.
  20. Aug 8, 2020 at 12:38 PM
    #80
    will van
    will van New Member
    Will
    The TRD Pro/SEMA wheels are 17"x7" with 4.5" backspacing.
    The Trail wheels are 17" x 7.5" with 4.875" backspacing.
    The lower backspacing on the Pro wheels causes rub? That sounds counter-intuitive, but I believe you.
    Link for the fender-liner mod?
  21. Aug 9, 2020 at 8:34 AM
    #81
    Im sorry, I misspoke. I meant offset in my post above, not backspacing. Trail wheels have an offset of +15 while the Pro wheels have an offset of +4. The Pro wheels being pushed further out increases the likelihood of rub when running a larger tire.
    link to the fender liner mod:
    https://trail4runner.com/2019/07/14/fender-liner-push-back-trimming-on-4runner/
  22. Aug 9, 2020 at 9:07 AM
    #82
    will van
    will van New Member
    Will
    No worries, I knew what you meant. The punchline is: With 275/70/17 tires, Trail wheels rub less than TRD Pro wheels because of backspacing/offset.
    Thanks for the link!
    nimby[QUOTED] likes this.
  23. Aug 9, 2020 at 11:36 AM
    #83
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    Blizzard pearl is like the red head step child. It only comes in one model which is the limited, soccer mom car :-(
    mrmike7189 and nimby[QUOTED] like this.
  24. Aug 10, 2020 at 6:53 AM
    #84
    NightRunner
    Tyler
    2020 Venture
    I can't say I dislike the moonroof, but I was originally looking for a model without one. It's great to have on a nice cruise through the mountains, but I don't use mine aside from those occasions.
    My only concern is the long-term durability. I've read some people that have had their moonroof randomly shatter/explode while driving down the road. I'm hoping for better luck.
  25. Aug 10, 2020 at 7:09 AM
    #85
    will van
    will van New Member
    Will
    Exploding moonroof?! Holy sh*t!
  26. Aug 10, 2020 at 7:29 AM
    #86
    Red_5
    One more reason to have window tint applied to your moonroof (in addition to making it nicer to use during the day). Tint keeps the glass from raining down quite as aggressively. :D
    NightRunner likes this.
  27. Aug 10, 2020 at 7:40 AM
    #87
    NightRunner
    Tyler
    2020 Venture
    :laugh: I've actually read that being true as well. It doesn't prevent the shattering, but keeps the glass from raining down.
  28. Aug 20, 2020 at 12:51 PM
    #88
    Red_5
    Pricing for the 2021 Pro has also been announced: $51,645.
    $605 more than 2020.
  29. Aug 28, 2020 at 11:52 AM
    #89
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
  30. Aug 28, 2020 at 12:47 PM
    #90
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
    What do you think the odds are that Toyota sells just the cooler? The Army Green has an Army Green Yeti cooler!
