2021 4Runner TRD Pro Replica Wheels
Discussion in 'Wheels & Tires' started by Factory Style Wheels, Jan 19, 2021.
  1. Mar 22, 2022 at 11:56 AM
    #181
    Factory Style Wheels [OP] New Member
    Dustin
    2019 Black 4Runner Pro
    Thanks for that comment. It may seem biased for me to say...but I agree. Lol. Especially with TRD Reps, the styles are actually very unique and cool looking imo. Our whole shtick is re-creating these styles but modifying them with Flow Forged Construction, more desirable specs & more variety of finishes: Providing a high quality & light weight alternative to the oem wheels with the aftermarket specs people are looking for to create the slightly more aggressive stance that looks so good on Tacomas/4Runners.
    -Dustin
  2. Mar 22, 2022 at 11:58 AM
    #182
    Dustin
    No worries! So, on stock suspension with the stock tire size, the (17x8.5, 0mm Offset) is a perfect fitment.
    We've had plenty of customers run that exact setup without any issues. The most common issue is the mudflaps, but with the stock tire size it should be no problem.
    -Dustin
  3. Apr 29, 2022 at 12:33 PM
    #183
    JM4Runner
    JM4Runner New Member
    Joe
    22 4Runner ORP
    Quick question, how far out past the fender do your tires go?
  4. May 13, 2022 at 5:07 PM
    #184
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I've been eyeing up the f158s. 17x8 with 4.5" bs and less then 20lbs. Its a great looking factory wheel imo.
  5. May 28, 2022 at 5:45 PM
    #185
    Sandman317
    Sandman317 New Member
    2022 AG ORP
  6. Jan 4, 2023 at 1:25 PM
    #186
    Yzf4runner
    Yzf4runner New Member
    Matt
    14 t4r sr5
    Trd Wheels, 265/70/17 wildpeaks, ECGS bearing
  7. Jan 4, 2023 at 1:30 PM
    #187
    Dustin
    Thanks for posting your question!
    I can definitely get you a quote for Shipping to Canada. Shoot me a message if you are interested.
    -Dustin
  8. Jan 11, 2023 at 4:26 PM
    #188
    DSRunner
    DSRunner New Member
    Is there a special trick to getting the center caps back on? I’m having a hard time getting it on and afraid to break the center cap.
  9. Jan 11, 2023 at 4:35 PM
    #189
    Dustin
    There is no trick that I am aware of...It's a snug fit, but they should clip in.
    Are you switching out the caps? Or putting the same ones back on?
    -Dustin
  10. Jan 11, 2023 at 4:48 PM
    #190
    DSRunner
    DSRunner New Member
    Switching out the caps. Actually, I just got them in using some PB Blaster.
  11. Jan 12, 2023 at 4:38 PM
    #191
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Any idea of when the 17x8 f158 will be back in stock? Looking to purchase 4
  12. Jan 13, 2023 at 3:09 PM
    #192
    DSRunner
    DSRunner New Member
    Thanks Dustin. It took awhile but glad I waited.
    hossler1788 likes this.
  13. Mar 18, 2023 at 2:15 PM
    #193
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
    Are you guys reusing factory lug nuts? I noticed while doing my leveling kit the factory lug nuts on my 2023 aren't the typical tapered style.
    This is my first Toyota so maybe they're all like that?
    EDIT-I found on fsw website they're compatable with factory lugs.
  14. Apr 7, 2023 at 10:13 PM
    #194
    HAWG!
    HAWG! New Member
    2020 TRD Off Road Premium
    I have trd replicas on my recently purchased ‘20 Off Road Premium but missing center caps on all four. Has JWL-T (Japan Light Alloy - Truck) mark but no brand. Anyone recognize the make and model of these wheels?
  15. Oct 21, 2023 at 1:11 AM
    #195
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Do those center on wheel register or conical lug nuts? I have learned OEM style or type means not quite Toyota. I know some are centered with lug nuts which is dangerous.
  16. Nov 5, 2023 at 6:21 AM
    #196
    Higgbra73
    Higgbra73 Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    Purchased these replicas, made by VOXX with Wildpeaks @ Discount Tire. 17x8.5 0 Offset [​IMG]
    xrevolver, Pentangler, Lc200 and 2 others like this.
  17. Nov 7, 2023 at 4:29 AM
    #197
    JakeFromStateFarm
    JakeFromStateFarm New Member
    New to the forum here, still learning alot about wheels and 4Runners in general. With that said, I'm running a stock suspension with no plans to lift, trim, or modify anything relating to. Short wife has a hard time getting is as it is lol.
    Looking at your Flow Forged F266, I had a few questions. A 17x8.5 with 0mm offset should work with no rubbing, and no need to add spacers, correct? If thats the case, my plan is to eventually get either Falken WildPeaks or KO2s, nothing too fancy. What size tire would fit that while still keeping rubbing to a minimum? 265s? 275s? I'm assuming 285s are out of the picture.
    Now, and this may sound dumb, but is it possible to fit the 16x8 0mm offset wheels on my 4runner and get a larger tire on in the process? If so, what tire sizes would fit that, while still keeping everything else stock and have little to no rubbing.
  18. Nov 7, 2023 at 6:55 AM
    #198
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Stick with stock 265’s. I had to trim a tiny section in front & push fender liner in. Nothing major! And NO Spacers
  19. Nov 7, 2023 at 8:11 AM
    #199
    Nubes
    Nubes Toyota Addict
    I believe our calipers are too big to fit 16" wheels but I could be wrong.
  20. Nov 7, 2023 at 12:38 PM
    #200
    JakeFromStateFarm
    I appreciate the input guys, I went ahead and got some F266's, 17x8.5. I'll try and get some pictures up here when I have them installed.
    Higgbra73, hossler1788 and Nubes like this.
  21. Nov 10, 2023 at 5:44 PM
    #201
    JakeFromStateFarm
    Alright, update. Got them installed yesterday, and they look killer! Took the wife and dogs out for a 2 hour drive, put about 150 miles on the new wheels. No issues at all, mpgs didn't dip at all and still managed around 19.4mpg on the drive, OEM Dueler tires still on it for now. No vibrations, no rattling, no rubbing, nothing but a smooth ride, very impressed on my first drive with them.
    I'll attach some pictures as promised, first time taking photos of a car I own so apologies if they aren't crisp photos
    Overall, DEFINITELY WORTH THE MONEY :yes:
    Higgbra73, Nubes and Technologic80 like this.
  22. Nov 10, 2023 at 6:19 PM
    #202
    Technologic80
    Technologic80 Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    Looks AWESOME! I want to buy these for my 23 ORP asap. So does the TRD decal come with the kit so you can stick them to the center caps?
  23. Nov 10, 2023 at 7:02 PM
    #203
    JakeFromStateFarm
    I think so too, was hesitant to choose these initially just because there are so many options, but it looks great. They do come with the center caps decals, they just adhere on, can't attest to how well they'll hold up over time but fingers crossed. I was also given a short list of 3 or so other caps that could fit but I thought these looked just fine. On the product information screen you can check a box to have the ring around the center cap be red, I opted against that (which should already be unchecked by default) and left it as a standard black cap.
    Technologic80[QUOTED] likes this.
  24. Nov 10, 2023 at 7:06 PM
    #204
    Technologic80
    Chris
    SE Michigan
    Thanks. That is awesome, I am fine with the stick on. Are any of the other caps that will fit OEM Toyota ones? Just in case the sticker falls off. lol. Also, how long did it take to receive the wheels after you paid for them? If I have to wait like 3 months or something, Im gonna go crazy.
  25. Nov 10, 2023 at 7:12 PM
    #205
    JakeFromStateFarm
    These were listed in my order email, not sure about other options:
    "The following OEM center caps are compatible with our 2022 Tac Pro Wheels:
    Black Cap w/Bronze "Toyota" Lettering:
    PT280-60200-05
    Red Ring Cap w/Red "TRD" Lettering:
    PT280-34190-02
    Black Cap w/Red "TRD" Lettering:
    PT280-34200-02"
    I would assume if you can get the size right, any decal should stick with some adhesive. Placed my order on Tuesday afternoon, got them Wednesday, and installed on Thursday. Shipped from San Diego to Phoenix in a day. Not too sure about Michigan, but I would assumed it'll be quick. Free shipping as well.
  26. Nov 10, 2023 at 7:14 PM
    #206
    JakeFromStateFarm
    Paid ~$820 for the wheels, $190 for installation and black lugs at Discount Tire. Would've been $1200 at the stealership and they wouldn't have swapped lugs and would have used a previous generation of TRD rims. Great deal overall imo.
    Technologic80 likes this.
  27. Nov 10, 2023 at 7:14 PM
    #207
    Technologic80
    Chris
    SE Michigan
    Cool Cool...thanks man!! Im going to order as soon as I get the better half's blessing :D Might take some wine & chocolate bribes. lol. But I want to have them ordered by this weekend for sure.
    Greg D likes this.
  28. Nov 10, 2023 at 7:16 PM
    #208
    JakeFromStateFarm
    Good luck, and remember, it's always easier to ask for forgiveness than permission. :cheers:
  29. Nov 12, 2023 at 7:11 PM
    #209
    xrevolver
    xrevolver New Member
    Jarred
    GA
    Beautiful finish! Reminds me of those km545 kmc wheels in matte bronze and black lip finish. Looks great on my buddy's Raptor.
    Higgbra73[QUOTED] likes this.
  30. Nov 13, 2023 at 10:43 PM
    #210
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I am assuming they center on wheel register. I looked at some TRD style on ebay and they were centered with lug nuts and not wheel register is why I ask, so I am careful at TRD style or type. You went to reputable place though.
