2021 4Runner Limited lift nightmare
Discussion in 'Suspension' started by DrkKnight, Dec 11, 2020.
  1. Sep 30, 2022 at 6:18 PM
    #91
    4Runner007
    4Runner007 New Member
    2021 4 runner Limited
    2” level front
    It honestly rides smoother and better than it did stock too. It was too soft and “boaty”. Rides great now and i took it to hollister Ca on trails and it performed better than i thought without lockers. Im not going to be off roading too much, im a big skier so the snow is mainly why i did the mods, and the looks of course.
    kmeeg likes this.
  2. Jan 15, 2023 at 10:49 AM
    #92
    Alli2019
    Alli2019 New Member
    Hey there, I’m looking to toughen up my 2019 Black Limited Nightshade. Loved the TRD but needed a 3rd row for the kids. Also love the 2 tone look of the FJ cruisers, and the new Broncos, although I prefer the older originals. Aby suggestions? It would be great to walk into a shop and be taken seriously. I get “is this for your husband?” A lot.
    Ros likes this.
  3. Jan 15, 2023 at 2:20 PM
    #93
    Maybe I will share my Limited with Ironman lift here if that helps anyone.
    If possible have some patience and listen what I think about it.
    Is it good as my ELKA 2.5DC suspension? No
    Is it worth the price tag? May be / Not bad.
    https://youtu.be/Xrp-LYkTLf8
    ChessGuy likes this.
  4. Jan 19, 2023 at 6:22 AM
    #94
    funrunner21
    funrunner21 New Member
    Frank
    Houston Tx
    2021 4RUNNER TRD OFF ROAD
    RC 3inch spacers and rear shocks
    So I’m also thinking to do a suspension lift, but how do I determine if my 2021 4 runner has the xreas system, thank you
  5. Jan 19, 2023 at 8:45 AM
    #95
    4Runner007
    2” level front
    Check and see if there is a line coming out of any of the shocks. If so, thats the XREAS oil line.
  6. Jan 19, 2023 at 8:47 AM
    #96
    funrunner21
    Frank
    Houston Tx
    Got it, thanks a lot. flg
  7. Jan 26, 2023 at 9:44 PM
    #97
    4Runner007
    2” level front
    Does anyone know the inner dimensions of the factory TRD Pro tube roof rack? Trying to decide of i should install one on my limited and want to see if my Thule Snowboard racks would fit on the lower crossbars in-between the side rail Tubes.
    thanks in advance!
  8. Feb 14, 2023 at 12:04 PM
    #98
    4Runner007
    2” level front
    Next project had arrived! Converting the Limited upper Grille to the TRD Pro Grill. They finally make a TRD Pro one for a limited and actually fits snug with no gaps! Took the black lower facia and wrapped it in Color matched Blizzard Pearl Vinyl and am going to do black lettering. Just have to place the letters and swap out the upper grill and BAM. Finished product to follow.
    erfer1, dgrenier15 and ChessGuy like this.
  9. Feb 20, 2023 at 8:14 AM
    #99
    4Runner007
    2” level front
    Finished the TRD Pro piece conversion. Stoked they finally make the front piece for a limited now. Wrapped it to match the body and black lettering. 3 Raptor lights ordered as well
    4RunnerCub, dgrenier15 and ChessGuy like this.
  10. Apr 13, 2023 at 6:03 AM
    #100
    Geealvarez1905
    Geealvarez1905 New Member
    Jesse
    Central California
    2017 4Runner Limited 2008 Tundra Double Cab
    Where did you get the vinyl!? I’m trying to do the same to mine.
  11. Apr 13, 2023 at 10:17 AM
    #101
    4Runner007
    2” level front
  12. Apr 13, 2023 at 10:19 AM
    #102
    Geealvarez1905
    Jesse
    Central California
  13. May 1, 2023 at 11:55 AM
    #103
    mistic9
    mistic9 New Member
    Jasmany
    2021 4Runner nightshade
    Hey 4Runner007!
    Where did you get your trd style grill? Did you have any problems with the front sensor? I’m looking to do the same thing
    Thank you
  14. May 1, 2023 at 1:24 PM
    #104
    4Runner007
    2” level front
    Hi there, i got mine from CarTrimHome and them wrapped it with color matched vinyl before installing. No modification of the trim piece was needed to install and no issue with the sensor.
  15. May 1, 2023 at 7:52 PM
    #105
    4Runner007
    2” level front
  16. May 2, 2023 at 1:15 PM
    #106
    4Runner007
    2” level front
    Hey ya’ll! For my next upgrade I am looking at the Gobi stealth full length rack with sunroof cut out. Has anyone put this in a Limited by chance and can share photos? Im 97% sure i will go with it, but want to be 100% before i drop 2K on it lol.
    Thanks in advance.
  17. Jun 5, 2023 at 8:24 AM
    #107
    4RunnerCub
    4RunnerCub New Member
    2023 Black limited 4WD
  18. Jun 5, 2023 at 8:28 AM
    #108
    4Runner007
    2” level front
    looks great man! What lift did you go with? Looks like a 3/1?
  19. Jun 5, 2023 at 8:30 AM
    #109
    4RunnerCub
    I went with the Rough Country 3.5" front and 1.5" rear and upgraded the control arms. They did not have to remove the XREAS system. Rough country makes a lift that is compatible with the XREAS system. I have 265/60/20R Ridge Grapplers on it. I feel like the truck still handles great. Ive put about 7k miles one the truck while having the lift and tires. I also added a SB cold air intake system(louder than I would have liked), and a pedal commander as well. Hope that helps anyone searching.
  20. Jun 5, 2023 at 10:15 AM
    #110
    4Runner007
    2” level front
    Looks great man! I almost did the 3.5 but i didn’t want to mess with the UCA’s. Sounds like it wasn’t an issue at all with handling though. I may have to do mine after these BFG wear out. I have about 3/4 of an inch between my tire and UCA now, but if I go one size bigger, I think it will rub
  21. Jun 5, 2023 at 10:26 AM
    #111
    Looks like my 4x4shop was wrong (maybe). They refused to use a spring more than 1in in rear for XREAS. Said that XREAS shocks are shorter and not recommended over 1in in rear.
    Edit-
    Adding a pic of the conversation-
  22. Jun 5, 2023 at 10:53 AM
    #112
    4Runner007
    2” level front
    Definitely incorrect, my lift was originally a 3 front 1.5 rear and i ended up getting a 1” rear simply because I wanted the rear, the same or a little bit less than the front. But I put the 1.5 on and drove around for at least a month before I switched it. I think most 4 x 4 shops aren’t used to dealing with limiteds first of all especially with XREAS and have an error on the side of caution mentality. Liability, liability, liability.
    kmeeg likes this.
  23. Jun 5, 2023 at 10:54 AM
    #113
    4Runner007
    2” level front
    what does your front measure from ground to top of fender? Just curious
  24. Nov 13, 2023 at 11:51 AM
    #114
    2chains
    2chains New Member
  25. Nov 23, 2023 at 9:23 PM
    #115
    4Runner007
    2” level front
    Happy Thanksgiving 4Runner Fam!
    1rooster and TrailSpecial22 like this.
