2020 Infotainment swap into my 2014?
Discussion in 'Audio & Video' started by 5bucksis5bucks, May 27, 2020.
  1. Aug 26, 2022 at 1:49 PM
    DenverCSUMatt
    DenverCSUMatt New Member
    2019 TRD Pro
    Really appreciate that!!!! You are the man.
  2. Sep 1, 2022 at 12:30 AM
    M!xT@pe
    M!xT@pe New Member
    Alex
    2007 Sequoia, 2012 4Runner [RIP :( ], 2024 4Runner SR5
    Numerous Audio Mods, Tint
    Frustrating that they didn't include that cable! It's not like it's useful for anything else!
  3. Oct 19, 2022 at 11:26 AM
    JustATallDude
    JustATallDude New Member+
    2019 Toyota 4Runner TRD Pro
    Gibson Single Exit Exhaust - Magnuson Supercharger - Sprint Booster - GTR Ultra2 Highs - Evil Headlights w/ Morimoto LED - Anzo Black Smoked Tail Lights - LED Interior Lights - A-Pillar Phone Mount Mod - CTH Side Mirrors - Eibach TRD Pro-Lift Springs - Falken Wildpeak A/T3s 285/70/17 - FSW F246 17x8.5 - Lasfit LED Turn Signals - DDI Seat Jackers - Apex Overland Front Recovery Points - Big Red's Turn Signal Mod and AMD Mod - R4T Blackout Turn Signals - BlackVue DR590 Dashcam and more to come...
    Finally found another head unit from TRDLunar on Instagram. Everything works great except for Android Auto and Nav. Harness is on the way for nav tho. I went through and updated the firmware and still nothing. Apple Carplay works great tho. Going to try my partners older device when I get home tonight to see if that does anything. Any ideas? My device is a Samsung Galaxy S21 Ultra.
  4. Feb 25, 2023 at 4:26 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Those of you did this, did you have any issues with the hazard switch? I noticed the newer 2020+ housing has a different slot for it. I got the newer switch but when I plug it in I can't get it to turn off.
  5. Mar 2, 2023 at 5:16 PM
    LadeDruck
    LadeDruck New Member
    2022 Pearl Effect White Ltd.
    This. The EQ curve is terrible (like most every oem unit) and like my man said, you’re gonna spend 2k on a fix86/twk88 and integration. A CarPlay pioneer is like 400 bucks, integration is another 250, then throw 1000 at properly amplified channels.
    you could leave the factory speakers in on low gains and still see amazing improvements…. If you start with a crap signal, it’s all downhill from there.
  6. Mar 9, 2023 at 9:42 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Sorry to bump an older post but wanted to ask as I am looking to do the same swap into my 2015 SR5P. Do all 2020+ headunits have Apple Carplay/Android Auto integrated? If not, which part number/model/trim should I look for? How would I determine which 2020+ headunit has Android Auto? TIA!
  7. Mar 9, 2023 at 10:03 PM
    spyder918
    2019 TRD ORP MGM
    From my understanding yes all 2020+ have it. Just know that some have Navi some don’t. I just did the swap and well worth it to me.
  8. Mar 10, 2023 at 7:38 AM
    Emmantik
    Emmantik New Member
    Did everything work normally or did you come across some glitches?
    Where did you find the headunit? And how much is a decent price to pay you think?
    Thanks!
  9. Mar 10, 2023 at 12:37 PM
    Emmantik
    Emmantik New Member
    Did Apple Carplay / Android Auto work for you without any hiccups? As in you just plug into USB and is starts up? Thanks!
  10. Mar 10, 2023 at 11:37 PM
    spyder918
    2019 TRD ORP MGM
    Yep everything worked fine, no hiccups. First few times it would reboot itself but now it’s fine.
    All was fine..just make sure you get a harness/adapter for the unit. I got mine from autoharnesshouse. Got mine from fleebay.
  11. Mar 11, 2023 at 2:42 PM
    snakehn
    snakehn New Member
    With the swap and the right harness does the unit retain the vehicle integration? Like outside of audio I believe the unit also shows some system messages and reads mpg info and such, do all functions work 100%?
  12. Mar 11, 2023 at 10:39 PM
    Emmantik
    Emmantik New Member
    For those that have done the swap, is the trim colour an exact match or is it slightly off?
  13. Mar 13, 2023 at 2:23 PM
    Emmantik
    Emmantik New Member
    I just ordered a headunit and about to place an order for the wiring harness from autoharnesshouse. Will update once installed. Excited to update my headunit!
    spyder918 likes this.
  14. Mar 15, 2023 at 11:41 AM
    spyder918
    2019 TRD ORP MGM
    Yep it does
  15. Mar 15, 2023 at 11:42 AM
    spyder918
    2019 TRD ORP MGM
    Mine does yes
  16. Mar 16, 2023 at 12:53 PM
    DenverCSUMatt
    2019 TRD Pro
    No glitches on my side when doing the conversion. The switch was easy and only took about an hour.
    I found my replacement from LKQ in Utah and had it shipped to CO. With the head unit and adapter I was all in for about $900.
  17. Mar 16, 2023 at 2:20 PM
    snakehn
    snakehn New Member
    And you are completely happy with the upgrade? With such amount spent one can get a really good aftermarket unit, but I for one rather stay with OEM if it offers CarPlay and larger screen and I’m willing to spend as much.
  18. Mar 22, 2023 at 12:26 PM
    DenverCSUMatt
    2019 TRD Pro
    100% happy with the look and performance. I wanted to keep the stock look and feel, but upgrade and this did exactly that. No regrets whatsoever
  19. Mar 29, 2023 at 8:47 AM
    #49
    Emmantik
    Emmantik New Member
    Just received my headunit! Now just waiting for the transplant harness to show up so I can do the install! Any tips/tricks for the install for those who have done it already? I believe this should be a fairly simple plug and play install but open to any advice, thanks!
  20. Mar 29, 2023 at 10:12 AM
    #50
    Thepremier141
    Thepremier141 Member
    Nate
    Northern California
    ‘22 SR5P
    @Emmantik
    Hey while you've go that there, does it look like it would be easy, or even possible to separate that silver trim?
    I want to vinyl wrap mine.
  21. Mar 29, 2023 at 10:18 AM
    #51
    i dipped mine when i first bought my truck, before i swapped out the radio. it a bunch of small screws, if you take your time it's doable to get it apart, but youre taking apart every single component including the screen and digitizer, the screws holding it to the trim are below all that stuff. There are not any screws in view on the back holding to the trim when fully assembled.
    Like i said , doable if you have the patience.
  22. Apr 8, 2023 at 12:40 PM
    #52
    Emmantik
    Emmantik New Member
    Just finished installing the headunit and everything works! The only thing I noticed is the hazard button works but does not stay on. Does anyone know anything about that?
  23. Apr 8, 2023 at 12:57 PM
    #53
    JustATallDude
    This has to be talked about earlier in this thread. I ended up using the stock button and wrapped some cloth tape around it to stuff it back in it's home. You will have to get the stock harness off the old head unit as well.
  24. Apr 9, 2023 at 9:01 AM
    #54
    Emmantik
    Emmantik New Member
    I figured out a fix to the hazard button. May be a bit of work but worth it in my opinion. Or you can do what others have done and just wrap cloth or tape around original hazard button. I didn't want to do it so I thought I'd find a solution I was happy with. I documented in another post for future reference for anyone attempting this in the future. Here's the link;
    https://www.4runners.com/threads/oe...le-carplay-android-auto-into-2014-2019.31018/
  25. Apr 12, 2023 at 7:25 AM
    #55
    Emmantik
    Emmantik New Member
    For those that did the swap, I noticed that I now can't rewind, fast forward (left and right directional buttons on steering wheel) when listening to audios on a USB stick from steering wheel like I did with the original unit. I am able to skip to next and previous track though with up and down buttons. Also, in phone screen, I can't use up and down buttons when scrolling through contacts. Has anyone else experienced this? If yes, did you find a fix? Have also contacted Auto Harness House to see if they have any insights - still waiting for their response. Not a huge deal but was just wondering what others experienced if anything. Thanks!
  26. Apr 12, 2023 at 12:53 PM
    #56
    Emmantik
    Emmantik New Member
    Per my last post above - I did a bit more digging and realized that 2020+ steering wheel controls are not exactly the same as 2014's - 2019's. Some buttons are in different locations with different orientations and 2020+ looks to have more options as well. This is probably the reason I lost those functions. Since it is very minor, it is definitely something I can live with. Something to think about if considering this retrofit.
  27. Apr 12, 2023 at 3:26 PM
    #57
    kcdude
    kcdude New Member
    Good to know. I noticed that the harness maker noted that some functions on the center multi-function display also would not work if the new unit did not have Navigation. I have a unit coming next week that does not have Navi…curious if it will change anything on my 2015 display.
  28. Apr 13, 2023 at 8:34 AM
    #58
    Emmantik
    Emmantik New Member
    Just had a thought regarding navigation. The nav box is a separate box that sits just below the main head unit (at least on the 2020+ headunit). I wonder if it's possible to add nav to a unit without it by just adding the box and related harness. Curious to know if it would be a plug and play install. Just thinking out loud...
  29. Apr 13, 2023 at 4:14 PM
    #59
    kcdude
    kcdude New Member
    I’m guessing it is as simple as adding the module and plugging in the harness to the main box. Actually saw a stand alone Mac unit but they wanted $350+ for it and it is another $60 for the interconnect cable.
  30. May 2, 2023 at 11:38 AM
    #60
    Emmantik
    Emmantik New Member
    Does anyone know who makes an in motion lockout bypass. So the person in passenger seat can change address in nav while in motion. Specifically asking those have done this retrofit. Thanks!
