2019 TRD Pro roof rack dimensions
Discussion in '5th Gen 4Runners (2010-2024)' started by rokunator, Sep 26, 2018.
  1. Aug 22, 2019 at 8:41 AM
    #181
    djmoore914
    djmoore914 New Member
    2019 TRD Off-Road Premium - White
    TRD Pro tires/wheels and predator bars
    This parts company said it's not even for dealers. I just placed an order with another toyota parts dealer and they asked for vin. I pulled one from a dealer website for a TRD PRO. We will see what they do. Ha!
  2. Oct 17, 2019 at 6:17 AM
    #182
    exnayr808
    exnayr808 New Member
    2019 waialua 4Runner
    I’m selling my TRD PRO roof rack let me know you pay shipping (from Hawaii). The price for the rack is $550
  3. Oct 19, 2019 at 2:30 PM
    #183
    oldtimer
    oldtimer New Member
    Robin
    Edmonton, Canada
    2020 TRD Pro 4Runner Army Green
    4 x 4 Innovations sliders Greenlane Rear hatch ladder
    What is the inside width of the rack, from tube to tube? Thanks.
  4. Oct 28, 2019 at 6:38 AM
    #184
    oldtimer
    oldtimer New Member
    Robin
    Edmonton, Canada
    What is the length of the cross bars on the TRD Pro roof rack (inside width)? Thanks.
    Daytonaviolet likes this.
  5. Oct 28, 2019 at 6:40 AM
    #185
    DoubleRGirl
    DoubleRGirl New Member
    Rebecca
    2019 TRD Pro
    working on it
    i have my trd pro rack for sale too, i'm located in new england. just bought the car so it's pretty much brand new
  6. Jan 12, 2020 at 8:23 AM
    #186
    Stevegood1
    Stevegood1 New Member
    Walnut Creek, CA
    Putting a 2019 TRD pro roof rack on a 2019 TRD off road. Where can I get the “ paper washers” to prevent leaking? I have all other mounting hardware. Also has anyone uploaded a video of installation?
  7. Jan 12, 2020 at 10:53 AM
    #187
    TimC
    TimC New Member
    Tim
    19 OR
    They’re fiber washers. No P/N on installation instructions. You will need brackets mentioned on instructions, part number #6318542020 qty 4.
    NJCAVBLUE and Stevegood1[QUOTED] like this.
  8. Jan 12, 2020 at 12:36 PM
    #188
    ForRun
    ForRun 4Runner
    2020 orp
    Sorry off topic....So I asked on another forum and no answer. 2020 pro going to stock rails. Does anyone have a part number for the 8 10mm bolts and washers needed. Also are there any other parts I may have missed and do we need any sealant on the stock rails other than the bolt gaskets? Thank you!
  9. Jan 12, 2020 at 12:50 PM
    #189
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    Search Results
    Featured snippet from the web
    According to Silicones: Chemistry and Corrosion, “Single part silicone sealers generally contain a cross-linking catalyst (such as a tin compound) that is activated upon exposure to moisture in the air.” When acetic acid is released, it attacks and corrodes metals such as copper, zinc, brass, and galvanized steel.
  10. Jan 12, 2020 at 1:22 PM
    #190
    ForRun
    ForRun 4Runner
    2020 orp
    Thanks, I'll take that as no other sealant needed. I asked because across forums many used it saying washers were not enough.
    Any idea on part # for the stock rail bolts and washers? Thank you
  11. Jan 12, 2020 at 1:49 PM
    #191
    Daytonaviolet
    Bay Area, CA
    This is the kit I used. But seems like the part number changed ? As far as I know the washers are not sold outside of this install kit.
    https://parts.toyota.com/p/69523295/PT27835130HW.html
    ForRun[QUOTED] likes this.
  12. Jan 12, 2020 at 8:17 PM
    #192
    ForRun
    ForRun 4Runner
    2020 orp
  13. Jan 12, 2020 at 11:25 PM
    #193
    Stevegood1
    Walnut Creek, CA
    Thanks! The instructions are exactly what I was looking for. Just need to get some fiber and foam washers and I will be good.
  14. Feb 8, 2020 at 12:58 PM
    #194
    johnrygg
    johnrygg New Member
    john
    Hello can someone tell me the dimentions of where the pad are ? width and length apart ?
    I would like to see If I can modify this to fit my 1 gen Sequoia .
    thank you for your help
    john
  15. Feb 8, 2020 at 1:07 PM
    #195
    Daytonaviolet
    Bay Area, CA
    or just get this kit PT27835130HW from the dealer for ~$15. Contains all the composite, foam washers and bolts needed for the install. But you’ll also need 4 of these brackets which is not part of the kit.
    Bracket - Toyota 63185-0R010 Qyt 4
  16. Mar 3, 2020 at 9:12 AM
    #196
    NJCAVBLUE
    NJCAVBLUE New Member
    Thanks for these instructions!
    TimC[QUOTED] likes this.
  17. Mar 12, 2020 at 6:06 PM
    #197
    Daytonaviolet
    Bay Area, CA
    in case someone is looking for any additional cross bars for there TRD Pro Rack, here's the part number. it's actually the same part number for the FJ :) PT278-35180-AA ~ $55 ymmv
    edgesalon and ForRun like this.
  18. Mar 12, 2020 at 6:24 PM
    #198
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    Thanks for the info, I am actually looking for one extra cross bar
  19. Mar 12, 2020 at 9:01 PM
    #199
    Daytonaviolet
    Bay Area, CA
    Attaching Toyota install procedure for TRD Pro Roof Rack
  20. Mar 13, 2020 at 7:13 AM
    #200
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Hey Dave, I removed my Pro rack and added the black rails. I used clear permatex around the holes to be safe. No issues with leaks.
  21. Mar 13, 2020 at 9:13 AM
    #201
    edgesalon
    Te
    18 FunRunner :-)
    the roof rails are self sealing to the roof you do not need any thing else just clean the area before installing and make sure you use the washers and torq down the bolts to 14lb.
    ForRun and Daytonaviolet like this.
  22. Mar 13, 2020 at 12:47 PM
    #202
    Daytonaviolet
    Bay Area, CA
    the Oem stock rails has a cover to protect the Bolts and rubber washers below them. All that is needed is the stock bolts and rubber washers.
    ForRun likes this.
  23. Mar 13, 2020 at 4:38 PM
    #203
    ForRun
    ForRun 4Runner
    2020 orp
    Unfortunately the the rails I bought the dude wore off the pads that surround the white tubes at the roof line. When I asked about it I was everyone suggested I was stupid to assume anyone could remove stock rails without damaging the pads. Toyota said I would need to purchase the (4) bolt down assemblies to get a good seal.
    RusPro, thanks for the suggestion. I ended up using permatex black rubber but don't know if it worked. The ex took off with the rig(hope it leaks like heck! :D)
  24. Mar 13, 2020 at 4:45 PM
    #204
    ForRun
    ForRun 4Runner
    2020 orp
    I had the rubber washers. There's another seal at the bottom of where the mount sits on the roof. It's built into the mount and only way to fix it is seal it or replace the mount. I used butyl, 3M marine sealant and they both leaked. Everything was cleaned and prepped, water gets under the mounts.
    I like the trail and pro set up better, buy the FJ kit dirt cheap and get new bolts gaskets and coated retainers that all seal er up
  25. Mar 13, 2020 at 4:47 PM
    #205
    RusPro17
    Don
    Pa.
    No problem, I know some guys say you don’t need the silicone or anything. I did not want to take a chance of any leaks. Because if there is a leak it will stain the hell out of the interior roof.
  26. Mar 13, 2020 at 4:50 PM
    #206
    RusPro17
    Don
    Pa.
    0103F80B-38ED-4944-A06C-C2C0B001299F.jpg I figure it would not hurt to add a little extra seal.
  27. Mar 13, 2020 at 6:03 PM
    #207
    ForRun
    ForRun 4Runner
    2020 orp
    I cant spot them in your pic but this is this pic the bottom part of the mount bracket shows it has holes open through into the cap area that takes in water. maybe they were defective or just downright screwed up by the dude that sold them to me. looking at the bolt hole on the mount, the rubber gasket was torn or worn off. I was told that needs to be sealed to keep water going through the outside of the white tubes/ through the roof. This pic was taken the day they were delivered after purchasing
  28. Mar 13, 2020 at 10:26 PM
    #208
    Daytonaviolet
    Bay Area, CA
    the bottom of rubber rack feet looks like it had the same foam style washers as the TRD pro roof rack. The extra holes is probably for drainage as those two holes line up with the rails. Here’s a pic of my old rack.
  29. Mar 13, 2020 at 10:37 PM
    #209
    Daytonaviolet
    Bay Area, CA
    ~38” is the distance from bar to bar where the cross bars attach to. the cross bars are identical to the ones used on the fj
  30. Mar 14, 2020 at 3:55 AM
    #210
    RusPro17
    Don
    Pa.
    Hey Dave,
    Mine were much better. My black rails were brand new from another off road 4runner. I got them right from the dealer where they remove them and do all these extra upgrades to sell 4runner. They add lifts and roof racks. Mine was a set just taken off and put back in the parts department. The parts guy hooked me up. But even when I got them you can see from factory there was some kind of silicone that is added because I peeled mine off and it was almost like rubbery. So I think Toyota adds just a little seal on the bottom part there like i did.
