2019 TRD Pro Fox Suspension and spacer lift?
Discussion in '5th Gen 4Runners (2010-2024)' started by wwfirefighter, Oct 20, 2018.
  1. Jan 25, 2022 at 5:38 PM
    #151
    smatson
    smatson New Member
    Scott
    2019 TRD PRO
    Westcott lift / Mickey Thompson Baja Boss AT’s / S&B CAI/ Sprint Booster / DDS3 Max PODS / TRD Exhaust
    I have a 2019 PRO and wanted to fit 285/70/17 while avoiding trimming, mud-flap removal and keeping all the Fox setup intact.
    I went with Westcott Designs and couldn’t be happier - my wife drives a 2020 Pro (she loved mine) and have the same setup on both rigs.
    Good luck!
  2. Jan 25, 2022 at 5:41 PM
    #152
    smatson
    smatson New Member
    Scott
    2019 TRD PRO
    If you go with the Westcott, any lift for that matter, you’ll want to do an alignment…
    K-Paul likes this.
  3. Jan 27, 2022 at 7:20 AM
    #153
    phxrunnr
    phxrunnr New Member
    Phoenix, AZ
    2020 TRD Off-Road
    I'd be careful about using the remaining exposed shock shaft as the guide, that doesn't mean the piston inside won't bottom out first or the shaft itself won't displace enough additional fluid inside the shock to cause a problem if compressed farther. I'd want manufacturer specs for max safe travel.
