2019 TRD Pro Fox Suspension and spacer lift?
Discussion in '5th Gen 4Runners (2010-2024)' started by wwfirefighter, Oct 20, 2018.
  1. Apr 25, 2020 at 9:06 AM
    #91
    miketrdpro4
    miketrdpro4 New Member
    20 runner pro
    because changing the collar is like having an adjustable coil over, and loading from the bottom doesn’t take away from the factory droop or up travel. Think about it all the coil over for aftermarket and the Bilstein 5100’s adjust from the bottom for height.... this kit from westcott does that and uses a small shim up top that’s minimal. To me it makes way more sense then spacing the top of the strut for lift.
  2. Apr 25, 2020 at 9:52 AM
    #92
    I don't understand how a spacer on the bottom of the coil is any different from a spacer on top of the coil. You're still extending the strut either way and by doing that, you're loosing down travel and gaining up travel.
    The adjustable struts like bilsteins 5100s, 6112s, and Eibach's are essentially a spacer lift on the bottom of the coil, but their advantage is that the struts are longer so you're not bottoming out the shock as fast on the down travel.
    A&P likes this.
  3. Apr 25, 2020 at 10:18 AM
    #93
    miketrdpro4
    20 runner pro
    Your not extending the strut dude your pre loading the spring to get the lift like adjusting a coilover and on the 20’s trd pro there already an 1” taller than previous. Extending the strut would be putting a spacer at the top of the strut.
    El General***** likes this.
  4. Apr 25, 2020 at 10:38 AM
    #94
    To preload a spring means you're putting pressure on it to compress it further.
    You're not preloading your coils by using a spacer, top or bottom.
    If you were preloading the coil, you wouldn't be lifting the truck.
    A spacer works by adding space either on the top or bottom of the coil in order to extend its height and thereby lift the vehicle.
    Oldtoyotaguy and El General***** like this.
  5. Apr 27, 2020 at 7:48 AM
    #95
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    The price difference between this spacer lift and the Cornfed spacer lift really like to know is there a difference? Because I have not seen anyone on the forums posting about doing this lift.
  6. Apr 27, 2020 at 9:47 AM
    #96
    miketrdpro4
    20 runner pro
    Can explain maybe as well, but call the guy. It’s not a spacer because there’s nothing going on between the spring and the collar to create space with a third party piece. Replacing the lower collar is like adjusting a coilover to get more lift Guys it’s simple. And it looks completely factory. If you guys don’t see the value that’s ok, I like the design of it there’s nothing like it that I’ve found in the market. Like I said I’ll post pics on here for you guys and give my feed back.
  7. Apr 27, 2020 at 10:26 AM
    #97
    RusPro17
    Don
    Pa.
    I would like to go with this set up. Just like to be sure about it. I just got off the phone with Jeff from Westcott discussing things about it. I suggest anyone interested call him and he can explain everything.
    M4L likes this.
  8. Apr 27, 2020 at 11:08 AM
    #98
    miketrdpro4
    20 runner pro
    Haha nice man! Super cool guy. I’m telling you it makes sense this kit.
  9. Apr 27, 2020 at 6:10 PM
    #99
    ForRun
    ForRun 4Runner
    2020 orp
    Hard to believe if it was that simple eibach, dobbins, toytec etc never figured it out. Good luck but I'll watch from the sidelines.
    Adjusting a coil is ummm, a spacer unless its the new eibach kit
  10. Apr 27, 2020 at 6:14 PM
    #100
    ForRun
    ForRun 4Runner
    2020 orp
    Heres a fully adjustable coil and it eliminates a need for spacers from the 4runner lean from right to left
  11. Apr 28, 2020 at 2:11 PM
    #101
    Jovan
    Jovan New Member
    Jon
    2019 4Runner TRD PRO Midnight black
    I have a 2019 TRD PRO runner and I plan on lifting it with spacer . So from what I understand not going over 2" is "safe" . Now I am looking for the right numbers for balancing de height ( to compensate for the small factory nose dive ) should be correct for something like 1.5" front and 1 rear"?
  12. Apr 28, 2020 at 2:41 PM
    #102
    miketrdpro4
    20 runner pro
    https://westcottdesigns.net/product/fox-trd-pro-lift-kit/
    check that out. And yea 1.5” front and 1.25” rear
  13. May 9, 2020 at 10:42 AM
    #103
    miketrdpro4
    20 runner pro
    B2641C60-294E-4B3C-89DF-2EF6A3F0261B.jpg 40D12E4E-4391-4687-8C4E-F86818036462.jpg
  14. May 9, 2020 at 10:44 AM
    #104
    RusPro17
    Don
    Pa.
    Looks good mike, How’s it sitting from side to side. Is it level? I never got the video from Jeff for the install on the rear. Did you do the install? Also did you do alignment?
  15. May 9, 2020 at 12:04 PM
    #105
    miketrdpro4
    20 runner pro
    yes it’s level side to side, rear is a top spacer real easy to put in. Did alignment at a shop. I had footage and lost the damn memory card meh....
  16. May 9, 2020 at 2:31 PM
    #106
    RusPro17
    Don
    Pa.
    Yeah I like to see how the rear is installed. Thanks.
  17. May 10, 2020 at 10:12 PM
    #107
    miketrdpro4
    20 runner pro
    There it is
  18. May 11, 2020 at 5:07 AM
    #108
    RusPro17
    Don
    Pa.
    Thanks Mike, What was the install time for your installer to do front and rear?
  19. May 11, 2020 at 7:39 AM
    #109
    miketrdpro4
    20 runner pro
    2.5 to 3 hrs.
  20. May 11, 2020 at 10:05 AM
    #110
    flyinhoot
    flyinhoot When in doubt, Throttle out.
    Nor Cal
    2020 TRD Pro 4Runner "Trudy"
    Monochrome everything. LED reverse lights.
    I bought a pro so I didnt have to touch the suspension for awhile. This thread now confirms that I am glad I bought the Pro and Im certainly not adding a spacer or anything now until I redo it all 7-8 years down the road.
    Oldtoyotaguy and 2A4R like this.
  21. May 11, 2020 at 1:20 PM
    #111
    ForRun
    ForRun 4Runner
    2020 orp
    Is your level from right to left in the rear? Mine was 3/4" lower right from the factory. Front was level though
  22. May 11, 2020 at 1:23 PM
    #112
    flyinhoot
    Nor Cal
    hmmm...havn't noticed but then again not something ive checked. I will take a look next time its on a level surface. Ive read on this forum that there is a lean due to the gas tank and driver being on the same side.
  23. May 14, 2020 at 3:43 PM
    #113
    miketrdpro4
    20 runner pro
    so did I, just enhanced with a little firmer ride and more clearance. Less body roll and nose dive. Cheers I’m enjoying it, this is how it should of come from Toyota!
    Oldtoyotaguy and Broncobroke like this.
  24. May 27, 2020 at 4:00 PM
    #114
    Kevin4Runner
    Kevin4Runner New Member
    2019 TRD Pro
    Ironman 4x4 Foam Cell Pro - Stage 3 | Toyo AT3 | Gobi Stealth Rack & Ladder | CVT RTT | Ironman Awning | Victory4x4 Internal MOLLE | ARB Twin Compressor | (Soon to come C4 Front Bumper 'Lo-Pro' w/ Winch and LED Light Bar | Cali Raised Dual Light Bar & Amber Ditch Lights | C4 Rear Bumper w/ Spare Tire Swing Out)
    Selling my 2019 TRD Pro Suspension (Full Kit w/ UCA's and everything else stock that I replaced with what came in my Ironman 4x4 Foam Cell Pro - Stage 3 kit)
    Nitto Terra 265/70R17 Tires (10k Miles)
    Wasn't planning on replacing the suspension which is why I went with the PRO but ended up changing my mind.
    DM with offer
  25. Aug 28, 2020 at 4:59 AM
    #115
    RusPro17
    Don
    Pa.
    Toytec has there new spacer lift for the 2019-2020 Pro fox suspension out now. Just like the westcott design. Looking at Mikestrdpro AG Pic. I have the new Eibach springs waiting to go on but second guessing myself because comparing pics with the Eibach springs Mike AG looks higher. Anyone see difference in comparing?
  26. Aug 28, 2020 at 5:05 AM
    #116
    RusPro17
    Don
    Pa.
    With the Eibach springs. Does not look as high. Anyone thoughts.
    Images
    367813d1597875320-eibach-needs-stock-trd_01d94e0c34d9e5a341151ac16b377777908a5dcb.jpg
  27. Aug 28, 2020 at 6:28 AM
    #117
    ForRun
    ForRun 4Runner
    2020 orp
    The same 4runner can look different at most anytime in a different location. In my driveway alone I've taken 3 different measurements up to a 1/2" difference. for me I marked off with tape a spot in my garage so when I make adjustments I've got a true before and after reference. Even with every day driving, sometimes mine looks lower than others
    nimby and Oldtoyotaguy like this.
  28. Aug 28, 2020 at 6:45 AM
    #118
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Someone will correct me if I'm wrong, but I think you get a slightly higher spring rate with Eibach, but looking at the two springs in the photos, the stock Toyota rear spring looks heavier. When I installed my Elka suspension for my ORP, I ended up cancelling the adjustable Eibach I ordered for the rear because I thought they'd be too high with 1 1/2" lift in front. I wanted basically a TRD Pro look, and I like running stock tire size. So, I used a 1/2" Cornfed spacer on my stock rear springs. Using a small spacer for applications like this is fine as it doesn't affect the travel of the shock. I asked Elka, and they said it was no problem with their 2.5 IFP rear shock. The result is perfect i.e. level.
  29. Aug 28, 2020 at 6:51 AM
    #119
    RusPro17
    Don
    Pa.
    Thanks for the info guys.
  30. Aug 29, 2020 at 1:24 AM
    #120
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    I've watched the Wescott video and it sure seems like the Eibach springs would be a way easier install.
