2019 horrible gas mileage
Discussion in '5th Gen 4Runners (2010-2024)' started by Celly71, May 28, 2022.
  1. Aug 3, 2022 at 9:31 AM
    #151
    K-Paul
    Corbin Dallas
    SR5 4WD
    If you went from NY to Ohio you went through a ton of hills and mountains, so yeah that MPG took a Stone Cold Stunner.
  2. Aug 3, 2022 at 9:32 AM
    #152
    Tmiesowicz
    Tmiesowicz New Member
    The better half of New York
    If it’s a high compression engine and would benefit the best from 91 octane to make it run at peak performance why wouldn’t they state only 91+ octane like other vehicles then though…I only use 87 and I feel like the thing drives as it should, being a 270hp 278tq 4600LB blob with a 5 speed.
  3. Aug 3, 2022 at 9:33 AM
    #153
    Tmiesowicz
    Really weren’t any hills and most certainly no mountains, this was a flat stretch on the 90 west for most of the trip. Not southern OH. Or southern PA where the hills start.
    Singleminded likes this.
  4. Aug 3, 2022 at 9:47 AM
    #154
    K-Paul
    Corbin Dallas
    SR5 4WD
    Aahhhh, Buffalo to Cleveland. Im thinking 80 and 70/76
    Tmiesowicz[QUOTED] likes this.
  5. Aug 3, 2022 at 9:59 AM
    #155
    Tmiesowicz
    Yep! Destination was Independence OH
  6. Aug 3, 2022 at 10:00 AM
    #156
    Tmiesowicz
    LuLu and Singleminded like this.
  7. Aug 3, 2022 at 5:24 PM
    #157
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Higher elevation should require lower octane ratings to get the same performance at lower elevation with higher octane gas.
    From
    https://www.carmag.co.za/technical/93-vs-95-unleaded-do-you-really-need-higher-octane-petrol/
    “Atmospheric pressure has a significant impact on the in-cylinder pressures of naturally aspirated engines during WOT. As Johannesburg, for example, is roughly 1700 metres above sea level, the atmospheric pressure is generally 17% lower than at the coast, explaining the drop in engine performance. This fact lowers the tendency of the engine to knock, allowing a lower-octane fuel to be used with no loss in performance compared with a higher-octane fuel because the additional benefit cannot be realised.”
  8. Aug 4, 2022 at 9:44 AM
    #158
    4runGirl88
    4runGirl88 Get a little mud on the tires!
    2018 Black SR5 Premium (AKA Black Betty)
  9. Aug 4, 2022 at 11:41 AM
    #159
    Tmiesowicz
    Ancient is good! Loved the 2000-2010 era of vehicles and before that. One thing Toyota is going right is making there vehicles LOOK BETTER as time goes on, not like smooshed POS like the grand Cherokee, Cherokee, Tahoe, expedition, explorer and such. Love the 5th gen look, the more boxy tundra & sequoia as well for 2023.
  10. Aug 8, 2022 at 7:19 PM
    #160
    I think the 4Runner and Taco used different versions of the 4.0. Sorry I don't know the designations, I don't speak nerd (LMAO)
    I think the 4.0 in the Taco made 230some-odd HP, the 2010+ 4Rs make 270-ish. Supposedly the version in the Tacoma made more low-end torque. I don't know though, I've never seen that verified anywhere. I think the version in the 4Runner has essentially been unchanged since 2010.
  11. Aug 8, 2022 at 8:31 PM
    #161
    Correct. They're both the 1GR-FE. The 5th gen 4Runner got dual VVT-I, But for whatever reason the Taco kept the single VVTI version up until the 3rd gen. Maybe something to do with being made here and Mexico VS made in Japan. :notsure:
  12. Oct 5, 2022 at 6:09 PM
    #162
    Machinebuilder
    Machinebuilder New Member
    2007 4runner Sport Edition V8 2 wd
    I think that Toyota has proven hybrid designs they could use with success on future 4Runners. I think that that is the most likely way to save 4Runners from totally replacement in the future. Its that or a fully electric 4Runner of some type similar to a Rivian.
  13. Oct 5, 2022 at 6:31 PM
    #163
    It sounds like a hybrid, or plug in hybrid will be an option. The base motor is supposed to be a turbo 4 that looks like it could be a huge improvement over the current V6 as far as power and efficiency.
    Welcome to the forum, BTW!
  14. Oct 5, 2022 at 6:37 PM
    #164
    mZiggy
    mZiggy Honey badger
    Marc
    2020 4runner Pro, 2008 4runner v8, 2020 Tundra SR5
    Fwiw, YotaWerx Tuning tune customers routinely report favorable fuel economy, to include when running the premium fuel tunes.
  15. Oct 5, 2022 at 6:51 PM
    #165
    That's good to hear! I've been starting to consider a tune. I run 285's and 295's, and the 295's are really pushing it without a regear. I have to keep it in S4 usually, otherwise it downshifts nonstop.
