2019 horrible gas mileage
Discussion in '5th Gen 4Runners (2010-2024)' started by Celly71, May 28, 2022.
  1. May 31, 2022 at 1:20 PM
    #61
    Celly71
    Celly71 [OP] New Member
    19 runner
    All the bells & whistles
    Yes it does have all that f&r bumpers winch fully armored underneath ladder rack roof rack full spare fridge storage box ,
    mrmike7189 likes this.
  2. May 31, 2022 at 1:21 PM
    #62
    Celly71
    19 runner
    That sounds like a plan!
    4runGirl88 and Thatbassguy like this.
  3. May 31, 2022 at 1:25 PM
    #63
    GenoBluzGtr
    GenoBluzGtr New Member
    Geno
    Maryland
    '22 TRD Pro - Black
    I finally got my first 21 mpg tank today!. You can see from my fuelly app history below that it has been fairly consistently between 18-20, and a few in the 20.x range, the worst dipped into the 17.x range - but today, after putting 385 miles on the tank, I clocked a 21.0.
    Stock TRD Pro, no lift, stock tires, 14.8K miles.
  4. May 31, 2022 at 2:54 PM
    #64
    muddyix
    muddyix New Member
    AZ & TN
    '22 AG ORP
    Just hauled my boat(2000#'s with trailer and gear) on a tiny trip (100 miles roundtrip) and I was able to get 17 mpg. Then again my runner is stock
  5. May 31, 2022 at 3:15 PM
    #65
    afret
    North Idaho
    You guys are giving me some hope. I'm driving from N Idaho to Rapid City, SD in July and going in the ORP which is stock except for Toyo AT3s in stock size. Will drive the almost 900 miles each way non stop except for gas. I know there will be 80 MPH areas on the I90 so it will be interesting what kind mileage I will get. I only have 500 miles on the ORP so far and have been averaging around 17-18 MPG.
    Thatbassguy and Celly71[OP] like this.
  6. May 31, 2022 at 3:36 PM
    #66
    wsu_runner
    wsu_runner Just lurking...
    So you've taken a vehicle that was only rated 16-19 MPG to begin with, lifted it, added bigger/heavier tires, bolted on a whole bunch of stuff that weighs a ton and makes it less aerodynamic, and you're surprised that your gas mileage has dropped?
    mrmike7189, rickystl and BionicRandy like this.
  7. May 31, 2022 at 3:42 PM
    #67
    Celly71
    19 runner
    Don’t be mad at me.. surprised it dropped to 11 yes
  8. May 31, 2022 at 4:00 PM
    #68
    wsu_runner
    I'm not mad at you, it's just physics. The factors mentioned by me and others on this thread all contribute to lower gas mileage, plus driving style. A good experiment is to drive like you have a baby bird under the gas pedal and see if your MPG improves.
  9. May 31, 2022 at 4:08 PM
    #69
    Celly71
    19 runner
    I drive like I have an egg on my dash
  10. May 31, 2022 at 5:43 PM
    #70
    BionicRandy
    BionicRandy New Member
    Randy
    TX Hill Country
    Lots of goodies
  11. May 31, 2022 at 5:58 PM
    #71
    Doughboy
    Doughboy New Member
    19 mpg here with 33's full belly pan and gas tank skid
    mrmike7189 and BionicRandy like this.
  12. May 31, 2022 at 6:07 PM
    #72
    I mean, that is a pretty drastic drop. I belong to a 2500 Suburban group, and there are guys with 8.1Liters that get better mileage than that.
    mrmike7189 and Thatbassguy like this.
  13. May 31, 2022 at 6:08 PM
    #73
    You'll probably do pretty well with all that highway. Pro tip: just because the speed limit is 80 doesn't mean you have to do 80.
    I pretty easily get 21 to 22 on road trips with mine with stock size all-terrains.
    LuLu and afret[QUOTED] like this.
  14. May 31, 2022 at 6:12 PM
    #74
    Celly71
    19 runner
    That’s what I’m thinking
  15. May 31, 2022 at 6:18 PM
    #75
    A regear would probably help you keep that egg balanced on your dashboard. It will be easier for you to be OK with going 55-60mph.
    Still hoping for some pics of your rig to drool over.
  16. May 31, 2022 at 7:22 PM
    #76
    afret
    North Idaho
    It's going to be a long drive so in this case I think I will go at the limit.
    Stoney Ranger and Thatbassguy like this.
  17. May 31, 2022 at 7:35 PM
    #77
    I've seen it become counterproductive if you're too soft on the gas. I try to keep mine between 2000-2500 RPM's when accelerating, as that's around where it seems to have a little torque to get you going.
    As mentioned above, high speed kills mileage. I've gotten 19.9 on 295's with armor, loaded down. But, 55-65 MPH.
    BionicRandy, Singleminded and afret like this.
  18. Jun 1, 2022 at 5:40 AM
    #78
    Chucklehead
    Chucklehead Enjoy the ride! You only get one trip
    Fort Wayne, IN
    2021 4Runner Black TRD ORP
    Stock AF, with subtle personality tweaks
    The fuel economy always a topic on these I’ve seen since being on the forum and becoming an owner of a 4R last August.
    Mine is in stock form. I’m averaging 23mpg on a consistent basis now. It’s my daily driver which is a 90 mile round trip. The drive is conducive to good fuel economy though about 1/2 of it is 60mph highway and other half is town 35-45mph.
    What I’ve learned as the largest contributor to improving my mileage is looking ahead in the road and letting it coast. It’s heavy and coasts a long way and slow to scrub speed. Its a very different driving habit than normal and has taken awhile to figure it out and be consistent. My other car is a Corvette so….
    as for the fuel- the higher octane is a waste of $ . That fuel is for higher compression engines and the higher octane helps with pre-detonation of the fuel - that’s it. The fuel sold is not all equal across stations. You want to buy from stations that have what’s called “Top Tier” gasoline. Otherwise the other stuff is what starts to build up and cause problems—- ask me how i know.
    These run on a factor of Smiles per gallon anyway and Calculating it otherwise isn’t an accurate measure for these mechanical beauties!
    good luck OP!
  19. Jun 1, 2022 at 6:27 AM
    #79
    NEguy
    NEguy New Member
    2018 SR5 Prem
    ^^ This.
    A picture would be worth a thousand words.
    And, I would be willing to bet a lot of the very knowledgeable people here would say "Yep, that mpg makes perfect sense based on what you are lugging around..." Assuming of course the mods are as described...
  20. Jun 1, 2022 at 7:09 AM
    #80
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Am getting 21 - 22.9MPG
    Note that i don't speed past 60 except am running late for an appointment somewhere.
    Or the freeway.
    I developed the habit since my days of driving a V8 Mountaineer premium \
  21. Jun 1, 2022 at 8:30 AM
    #81
    Boy am I happy with the change in MPG with the summer weather. During wisconsin winter, I was getting 16mpg on my usual mixed country road/urban 15-20 mile commute. Now Im getting 19mpg !!! That almost offsets gas price increases!:cool::mad::confused:
  22. Jun 1, 2022 at 8:36 AM
    #82
    Cardork
    Cardork New Member
    Redwood Curtain
    2021 Venture
    The screen that provides a compass, speed limit, and road being driven is where it’s at. That little screen has saved me a few times driving through rural Oregon where the speed limits changes from 55 to 25. Still handy around town too.
  23. Jun 1, 2022 at 8:50 AM
    #83
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    11mpg does seem really low, even with the mods mentioned. But maybe so.
    My 21' ORP in stock form, with 13,000 miles is averaging 19.7-20.3mpg. Combination city/highway driving. Based on what others on this Forum mention, this seems about the norm.
  24. Jun 1, 2022 at 9:15 AM
    #84
    Celly71
    19 runner
    Yeah I guess I’ll just wait for the Tesla to tow around all my gas hogs..
  25. Jun 1, 2022 at 12:04 PM
    #85
    Tmiesowicz
    Tmiesowicz New Member
    The better half of New York
    By being in 2 wheel drive I meant just power to the rear, for a example my 2001 grand Cherokee had Quadra drive, a full time 4 wheel drive system with the option of 4 low and neutral. It had limited slip differentials front and rear, on that vehicle the front didn’t receive any power unless the rear wheels sensed any slip. The second the rear wheels sensed slip the transfer case locked or whatever and sent power to the front differential. I loved that system.
    Celly71[OP] likes this.
  26. Jun 1, 2022 at 12:07 PM
    #86
    Tmiesowicz
    I never reset mine either, almost at 100 hours since Christmas and have a average of 16.7, most of my tanks average 17-18 mpg.
  27. Jun 1, 2022 at 12:17 PM
    #87
    LA260
    LA260 New Member
    I'm still recovering from my last trip from LA to Mammoth back in March with with 5 people + gear....
  28. Jun 2, 2022 at 8:44 PM
    #88
    TeslasBigCarbonFootprint
    Southern California
    '23 TRD ORP Super Ice Cap White
    90% freeway on this trip odometer, Southern California, some hills, rarely hitting 65.
  29. Jun 16, 2022 at 10:45 AM
    #89
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    2020 SR5 stock wheels and Dueler HT tires set at 33psi. No mods at all. The lowest gas mileage I've ever had was 18mpg in the city....so it is possible. I get 23mpg highway. Teslasbigigcarbonfootprint....my hats off to you for being the best at it so far. 27mpg is awesome!20220616_112032_HDR.jpg
  30. Jun 16, 2022 at 11:01 AM
    #90
    Southern California
    That was one series of long freeway drives.
    As Costco gas is now slightly above $6 a gallon, my mileage has sunk badly. I am wondering if I should speculate that the minimum octane rating may have dropped. I remember one gas station, here in Southern California, had state tested at 90 octane for their regular gas. So, they were meeting and exceeding the minimum octane requirements for San Diego County Weights and Measures.
    My combined city, 80% freeway and not speeding, about 19.8 to 20.1 miles per gallon. I have been checking my air pressure a lot. It has also gotten warmer and slightly muggier around here. I understand that fluid dynamics might dictate that I have more to drive through and it's creating more resistance.
