2013 4Runner oil leak
Discussion in '5th Gen 4Runners (2010-2024)' started by DAD004, Aug 21, 2024.
  1. Aug 23, 2024 at 7:03 AM
    #91
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. Custom High Clearance Fender Liners *Coming soon Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Needle bearings have entered the chat.
    icebear, Maximumdarkside and 3JOH22A like this.
  2. Aug 23, 2024 at 7:12 AM
    #92
    Oakboro, N.C
    After reading through this, welcome this comment to break the tension!
  3. Aug 23, 2024 at 7:20 AM
    #93
    1SilverRunner
    Tejas
    It's getting heated for sure :anonymous:
    I still cant believe the dealer did an oil change for OP and didn't just ask if he wanted to replace the housing with an OE one since the tube was missing! Wild.
    Now its a aluminum vs plastic housing debate. Cause this forum really needed another one of those ;)
    Not complaining for the record, just found it funny.
  4. Aug 23, 2024 at 7:29 AM
    #94
    kouack
    kouack New Member
    4Runner Limited 2024
    Bone stock
    Touché, good one! people that have installed lift kit, larger tires have more problem with the needle bearing :devil:? asking for a friend, leaving the chat now :deadhorse:
  5. Aug 23, 2024 at 7:35 AM
    #95
    Oakboro, N.C
    After over a decade at a Dealership, One thing is for certain, Never get accustomed to not being surprised to how things can be assembled or reassembled with any type of factory accuracy.
  6. Aug 23, 2024 at 7:36 AM
    #96
    1SilverRunner
    Tejas
    Maybe. I've heard of stock 4Rs having needle bearing issues as well though. Just pointing out that Toyota may be aware of certain issues but do not always correct them.
    Personally, I don't think the plastic housing is an issue really. I went to aluminum after a cheap filter wrench cracked the plastic housing. 100% using the motivx filter wrench would have avoided this.
    Saker and kouack[QUOTED] like this.
  7. Aug 23, 2024 at 8:02 AM
    #97
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    From what ive seen, i bet the dealer didnt notice..because the lying cheating son of a whore dealer
    NEVER CHANGED THE FILTER AND BILLED FOR IT ANYWAYS!
    I have seen this first hand on my wifes Runner. Free oil changes just arent worth it.
    5thToy and McSpazatron like this.
  8. Aug 23, 2024 at 8:07 AM
    #98
    2014 pepe
    2014 pepe New Member
    So you found out some of the same stuff I did. Don't mess with the housing. Funny you mentioned the crappy mazda with 250k plus. My wife's first car was a 72 Datsun B210. I had to replace the timing chain after some grease monkey screwed it up while I was on cruise. Since the car had over 220,000 miles on it I figured I might as well rebuild the engine. Just doing regular oil changes every 3000 miles using Castrol 20w-50 conventional oil & Nissan filters. That engine was pretty much in new condition. The original honing marks were still on the cylinder walls. So I'll stick to what the manufacture put on that car, especially Toyota. On the yota I change the oil every 5000 miles using Mobil One 0W-20 and use Toyota filters. I know I know with synthetic oil etc etc etc...To my way of thinking it's a cheap insurance policy for that engine. I get the oil at wally world and the filters at the Toyota dealership, they are cheaper there. Now if I'm on the road and go over 5000 no worries since it mostly highway driving. Again my two cents. What's WWW?
    Saker likes this.
  9. Aug 23, 2024 at 8:09 AM
    #99
    2014 pepe
    Yep, I should have found this site prior to the oil changes. Again that's what I get for being cheap & lazy.
  10. Aug 23, 2024 at 8:11 AM
    #100
    Saker New Member
    21 Black T4RORP
    Thanks for your response @2014 pepe
    First off thank you for trying to find the data.
    This is for information only. No harm intended in this response. Some are calling this thread heated.
    Clarification, the tube in the plastic one is longer than the one that comes in the aluminum one. Each tube is made the same and is held in place with a tab. I understand one may view this as maybe risky to replace this tube and not comfortable with bending the tab to secure the replacement tube.
    If the tube comes loose on a canister it is because the tab was not bent enough to secure the tube. That goes with a new plastic can or a modified aluminum can.
    Thanks again for information.
    I am comfortable enough to change over to a stronger canister modded with the original tube from the plastic canister.
    I still have my OEM plastic canister with the tube. If you need photos of exactly how they are fastened, I would be more than happy to supply any pics.
    BTW, I only use OEM filters on any of my vehicles.
    2Toys likes this.
  11. Aug 23, 2024 at 8:16 AM
    #101
    2014 pepe
    I thought the tube in the aluminum housing was longer?
    Thanks, never got that far as to how the tube is secured to the base. I'll look at it the next oil change, pictures will help.
    That's what I like about this site/forum. It provides a lot of good information and a avenue for discussion.
    Saker[QUOTED] likes this.
  12. Aug 23, 2024 at 8:28 AM
    #102
    1SilverRunner
    Tejas
    The tube in the aluminum housing is shorter. (Suitable for camry filters)
    If swapping to the aluminum housing be sure to use the spring and tube from the original plastic housing.
    2Toys and 5thToy like this.
  13. Aug 23, 2024 at 9:20 AM
    #103
    kouack
    kouack New Member
    Bone stock
    Internet, world wide web!
  14. Aug 23, 2024 at 9:26 AM
    #104
    2014 pepe
    Thanks
  15. Aug 23, 2024 at 9:32 AM
    #105
    2014 pepe
    Now for the question. Camrys, Lexus and 4 runners are three of the top selling vehicles of the Toyota line. Why would Camry & Lexus take a metal housing and 4 runners plastic. In this world of bean counters using one or the other with just a different tube and Toyota number would seem to be more cost efficient. I'll be curious to see the reason behind this.
    On another note when I was looking for a oil filter wrench the Motivx never popped up during my research, only the Tool Guy wrench showed up. So I got the Tool Guy wrench which cost a little more.
  16. Aug 23, 2024 at 9:51 AM
    #106
    kouack
    kouack New Member
    Bone stock
    I do not know for you but the tool appears in an Amazon advertisement right at the bottom of the page
  17. Aug 23, 2024 at 9:58 AM
    #107
    Saker New Member
    21 Black T4RORP
    Here are the photos.
    Both tabs bent up so tube can be rotated.
    Released and rotated 90 degrees
    Removed, cleaned and tube inserted and tabs bent down slightly to lock back in place.
    Maximumdarkside likes this.
  18. Aug 23, 2024 at 9:59 AM
    #108
    Grug556
    Grug556 New Member
    People think plastic/composite is weaker than metal. This isnt always the case. Aluminum can also crack and deform when dropped or miss handled.
    McSpazatron likes this.
  19. Aug 23, 2024 at 10:06 AM
    #109
    In for what the dealer says to @DAD004.
  20. Aug 23, 2024 at 10:07 AM
    #110
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Unless you're very un capable to R&R the tube from OEM Plastic bowl Don't. I have done it before & will <1k when I hit 5k. It's spring loaded, I just went & removed it from the OEM plastic 1 I have from 2018 4Runner. Just finesse the two tabs on 1 side & pop it out. No big whoo. BTW they are assembled meaning they can be dis-assembled too.
  21. Aug 23, 2024 at 10:12 AM
    #111
    Plastic/composite housings may not necessarily be cheaper to manufacture either.
    Grug556[QUOTED] likes this.
  22. Aug 23, 2024 at 10:13 AM
    #112
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I just did it W/out bending tabs. 3 to 4 times no issues
    Saker[QUOTED] and 2Toys like this.
  23. Aug 23, 2024 at 10:15 AM
    #113
    My guess is that dealer will say the tube must have been sucked up into the engine, so it’s gonna need a new engine. Lol.
    Saker and glwood54[QUOTED] like this.
  24. Aug 23, 2024 at 10:17 AM
    #114
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    LCJ77 likes this.
  25. Aug 23, 2024 at 10:19 AM
    #115
    Grug556
    Grug556 New Member
    I predict, the dealer will say that the can is metal not an OEM toyota part and likely it was broken or missing the tube because its not OEM and they have no idea about any of this.. the fact they serviced the oil and claimed to change a filter, will of course...not be discussed.
    LCJ77 and McSpazatron like this.
  26. Aug 23, 2024 at 10:45 AM
    #116
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    They don't want to hassle with the skid plate and canister setup on the bottom of the motor so they skip it and tell you it was changed.
    2Toys, TrailSpecial22 and McSpazatron like this.
  27. Aug 23, 2024 at 11:22 AM
    #117
    2014 pepe
    Way back when I was looking for one the Motivx didn't appear???
    Just like now I've been pricing plastic oil housing units. Called up several dealerships cheapest one I could find this time around was $165.70 high was $206.04. When I google it up with the part number cheapest is $42-->$112. The 42 is from EBAY. There are several on EBAY from 42-->112. Yet when you hit on the reviews it's the same people reviewing on all the different prices. So I guess it's to the dealer I go.
    I'm the one that posted the Tool Guy wrench...
  28. Aug 23, 2024 at 11:27 AM
    #118
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I'll soon have 2 Plastic bowl, but they'll have the stand pipe from Metal bowl. I guess I could sell them & let buyer know the stand pipe isn't for the 4Runner??
    Saker likes this.
  29. Aug 23, 2024 at 11:31 AM
    #119
    2014 pepe
    So I gather you do not have a OEM Toyota part?
  30. Aug 23, 2024 at 11:37 AM
    #120
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I have the original plastic from my 2018 4Runner & when I change the oil & filter @5 k on my current 4Runner I will be installing the Toyota Metal bowl, hence 2 Plastic OEM bowls .I have the Motivx filter bowl wrench from spring of 2018. Works great.
    Saker and 2Toys like this.
