1st DIY Oil Change
Discussion in '5th Gen 4Runners (2010-2024)' started by Slopemaster, Aug 26, 2021.
  1. Sep 9, 2021 at 11:56 AM
  2. Sep 21, 2021 at 1:32 PM
    Bald Michelins
    Bald Michelins New Member
    21' SR5P
    Same here. Motivx tools sells it separately. I'm happy with their other stuff.
  3. Sep 21, 2021 at 3:22 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    I have been using the Motivx 2320 filter wrench and filter drain tool for 3 years ony daughters 2016 Camry. They have both worked really well. Only issue is that it fits in exactly one position.
    I did order the new version 2320-US tool today for my first oil change on the T4R. I like that it fits the ridges on the filter housing and will be easier to use than the old version (although old version is not difficult). Worth the $25.
  4. Sep 21, 2021 at 3:51 PM
    I can't believe guys actually use the plastic drain tool.
    I just drain the pan and unscrew the filter. Less mess than trying to shove that plastic POS in there.
  5. Oct 29, 2022 at 8:10 PM
    Just completed an oil change. I always have a hard time getting that plastic push button loose on the skid plate. I finally said the heck with it I applied a short piece of thin black foam tape on the skid plate directly under where the hole is to eliminate rattle if any.
  6. Oct 30, 2022 at 6:23 AM
    KilluFirst
    KilluFirst New Member
    '21 Venture MGM
    KO2, RCI Skid and filler plate, Caliraised ditch lights, seat jacker clones, aluminum oil filter housing and fumoto drain.
    That was the path I took, RCI Skid and bumper filler plate. Makes draining the oil and accessing the filter easier.
