0W-20 In The Texas heat??
Discussion in '5th Gen 4Runners (2010-2024)' started by Rick G., Jul 1, 2024.
  1. Jul 1, 2024 at 4:42 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    That's just evidence it doesn't matter. Well built engine will run longer than most users want to keep it.
    icebear and Thatbassguy like this.
  2. Jul 1, 2024 at 5:46 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    exactly, so what’s your point?
    research doesn’t matter. The data is out there.
  3. Jul 1, 2024 at 7:16 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Self awareness recognized and appreciated but your heat is serious. I have lived in Phoenix and currently live in Nevada.
    On my Dad's side the entire family is spread out over TX from Amarillo to Dallas, Hill Country, Brownsville and Houston. Between visiting them and spending time in TX for business over many decades, I can say TX on the whole can be just as brutal all things considered. Houston in particular can be smothering. Summers in Hill Country with grandparents were rough too. High humidity does matter.
    When it's 118-121 in Phoenix or Vegas it's just F'n hot, an oven. I'm in Reno now and it's going to be 106 this weekend. Humidity will start the morning in the low 20% range and be single digits by mid day. At nearly a mile high with no moisture in the air it is very hard to stay hydrated and having the lower mile of dense atmosphere removed between you and the sun makes it seem like it's beating you in to the pavement when you are in direct sunlight.
    I grew up in Sacramento, CA on the other side of the Sierras. It's going to be 110 there this weekend. It's going to be 118 in Redding, CA in the north end of the Central Valley.
    Steely123[QUOTED] and brownersd like this.
  4. Jul 1, 2024 at 8:09 PM
    UncleShorty
    UncleShorty New Member
    Use the oil the Toyota engineers recommend in the manual.
    What makes you think, with a million 4Runners built by Toyota, you know more than than they do?
  5. Jul 1, 2024 at 8:28 PM
    GuamBomb671
    GuamBomb671 New Member
    18’ TRD Off-Road
    You will be just fine with the 0-20w Toyota wouldn’t recommend something bad for you.
  6. Jul 2, 2024 at 5:24 AM
    2021venture
    Todd
    2021 Venture
    Decent test showing cold pour points and wear on limited testing. Makes no sense to me that 1 oil choice is going to be optimized temps from -20 to 120 degrees. But it is adequate and most users don't care or will keep vehicle long enough to matter. The 0w16 sure does stay thin extreme cold.
    The endless trade offs for anyone comparing data and looking to optimize for their specific use case. Heat is more of a concern than cold in my region.
    https://youtu.be/xtSwaF2evTU?si=sM_DxGB2Kww25k13
    When CAFE doesn't matter Toyota/Lexus still recommend 5w30 in 2024. But CAFE is also the reason NA motors and V8's are being eliminated as options. My solution for giving up on 4runner lacking power.
    Sin4R and jgalt like this.
  7. Jul 6, 2024 at 3:19 PM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Wow, tons of replies. I guess I'd better stick with 0W-20. I bought the Toyota extended warranty anyways, which is going to take me way up there in time and mileage coverage. I'll stick to my 6 months or 5,000 miles whichever comes first change interval. And maybe I'll buy my next batch of oil from my Toyota dealer parts counter. Thanks everyone.
    Slopemaster likes this.
  8. Jul 8, 2024 at 12:19 PM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
  9. Jul 8, 2024 at 12:21 PM
    Sin4R
    Mall crawling kit.
    You need to understand that Toyota's #1 priority is compliance with local regulations. So they absolutely going to recommend something that bad for your car IF such recommendation is required to meet regulatory compliance.
    Specifically, if 0w20 is required for staying in compliance in NY winters, it also may be recommended for Texas summer heat. Even if the resulting viscosity is not the same in these use cases.
    When I lived in Texas, I stepped up oil one grade to get through the hot season. Especially as you get stuck in traffic with full AC, it was common to see temp gauge climbing past normal temps.
    jgalt likes this.
  10. Jul 8, 2024 at 12:33 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    5w-30 Full Synthetic.
    Premium fuel.
    oaouda likes this.
