0mm offset won't fit
Discussion in 'Wheels & Tires' started by kurtis2244, Jan 14, 2024.
  1. Jan 14, 2024 at 10:53 AM
    Those calipers seem fine from a distance. But the wheel certainly looks odd. Never seen anything like that. In any event, hope you get this sorted it out with the new set.
  2. Jan 14, 2024 at 10:55 AM
    kurtis2244
    kurtis2244 [OP] New Member
    Kurt
    2014 4runner SR5
    3 inch lift
    Well the cover of that wheel is actually black plastic. That's not the wheel itself. I don't even know what the actual wheel looks like. Only from the back
  3. Jan 14, 2024 at 11:06 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Is it a hub-centric wheel? Is it hitting the caliper because it's not getting precisely centered?
  4. Jan 14, 2024 at 11:09 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    No. The lugs were aligned perfectly. Just was hitting brake caliper and the wheel was not going in all the way and the lugs could only go through very little due to that. My stock wheels are ok. Just the aftermarket wouldn't go. Not sure what you mean but a "hub centric wheel.
  5. Jan 14, 2024 at 11:12 AM
    backpacker
    2023 TRD ORP
    Check out the distinction between hub centric and lug centric - https://www.discounttire.com/learn/hub-centric-vs-lug-centric
    djwantke likes this.
  6. Jan 14, 2024 at 11:16 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
  7. Jan 14, 2024 at 11:16 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    Stock...or at least what came with the truck. May not tell anything.
  8. Jan 14, 2024 at 11:20 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
  9. Jan 14, 2024 at 11:24 AM
    HazOpRed
    HazOpRed 22' TRDOR
    Stock 4runner rims have an offset of +15mm, trd wheels have an offset of +4mm. So the offset isn't the problem. Good luck on the 3in lift and all the suspension geometry
  10. Jan 14, 2024 at 11:25 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
  11. Jan 14, 2024 at 11:26 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    New wheel hitting caliper. Would still need at least an inch to bolt to rotor.
  12. Jan 14, 2024 at 11:27 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    Thanks all. 3 inch lift has been installed. Haven't been able to drive my new truck for 2 weeks until I get it aligned. And get wheels that fit.
  13. Jan 14, 2024 at 11:28 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    Well if there's that offset. Than the 0mm offset they sent me will not work correct?
  14. Jan 14, 2024 at 11:29 AM
    kurtis2244
    Kurt
    2014 4runner SR5
    3 inch lift
    And it's a plus offset...not a minus offset?
  15. Jan 14, 2024 at 12:49 PM
    backpacker
    2023 TRD ORP
    Is this after lift? It looks like the reduced clearance on the stock wheel might be due to a change in caster angle.
  16. Jan 14, 2024 at 1:41 PM
    Backspacing and the spokes are probably the issue. Those wheels you showed up above first don't seem well known for 4R. Best to stick with tried and tested products. Hang in there though.
  17. Feb 22, 2024 at 4:51 PM
    HuskyMike
    HuskyMike New Member
    Ever get this figured out?
  18. Feb 22, 2024 at 6:41 PM
    HuskerRunner
    HuskerRunner I joined 2.5 years after Rick G
    O,NE
    2023 SR5P
    Taco to 4R Mod
    Is this the stock wheel, or the set that hit on something?
  19. Feb 22, 2024 at 6:59 PM
    #49
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    The OP needs to post a picture of the wheel that's hitting the caliper, with the stamped wheel specs. The picture that he took of the "stock" wheel shows it being 17x7, with what looks to be a +11mm offset (see yellow arrow). A 17x9 wheel with a -12mm offset, even a 0 offset, should still fit and clear the suspension and caliper. So the new wheels have the right bolt pattern and the correct hub diameter? The reason I ask is the Dirty Life website also shows a 17x9 with a 6x135 bolt pattern and an 87mm hub, which won't fit. That's gotta be frustrating, to say the least!
  20. Feb 22, 2024 at 7:17 PM
    #50
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    :popcorn:
    Read the whole thread, eager to know more
    Hell, I have a 3" lift and 0 offset wheels, and they're frickin 9" wide, and I didn't rub anything
    ALSO I did not require an BMC for that setup like some have said above..perhaps that's cuz I have aftermarket UCA's and not OE.
  21. Feb 22, 2024 at 7:21 PM
    #51
    If its these wheels doesn't look like they fit.
    Enter 4Runner info here.
    https://www.customwheeloffset.com/buy-wheel-offset/9315-7973MB12/dirty-life-compound-17x9-12
    It also looks like TireRack doesn't sell this brand so how you got it from them beats me. Or I can't find it yet.
    It says hub bore too small. I'm thinking you are hitting the hub somehow and not the caliper.
  22. Feb 22, 2024 at 7:30 PM
    #52
    Well looks like they do make those wheels with the right hub size. Make sure you indeed get the 106mm ones.
    SKU
    9315-7983MB12
