Rear Diff. Breather Routing?
Discussion in '5th Gen 4Runners (2010-2024)' started by Scarif_1, Apr 26, 2024.
  1. Apr 26, 2024 at 10:19 AM
    Scarif_1
    Scarif_1 [OP] New Member
    Oakland
    2020 TRD ORP
    Bilstein 2.5" 6112s w/ 5160s & Dobinsons 1.5" rear springs. SPC UCAs. 285/70R17 BFG KO2s
    Looking to install a ARB rear diff. breather next weekend. Can someone pls. point me to a good step by step that includes a routing diagram or photos? The install is pretty straightforward. I'm more interested in how people are routing the line from the rear diff. to the engine bay. Thanks in advance.
  2. Apr 26, 2024 at 10:34 AM
    Acesandeights
    Acesandeights Newbie - always learning
    So Oregon
    1938 4Runner
    What about routing it into the rear cargo area (although you may smell gear oil as it gets hot) or an external place outside of the engine bay? Seems like a lot of line to run if you can find a space closer to the rear of the vehicle, more near the axle housing.
  3. Apr 26, 2024 at 10:37 AM
    I did a DIY version for quite a bit less cost than the ARB setup, and ran it to the empty area behind the left rear tail light. Didn't require so long a length of tubing.
    Basically duplicated the process used on my 2013 Tacoma.
  4. Apr 26, 2024 at 10:37 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    There’s dozens of videos and write ups on google. It’s a super easy install. Mine is on passenger side next to air box. Just follow a wire and zip tie down the chassis. You can’t really do it wrong.
  5. Apr 26, 2024 at 10:39 AM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I routed along the frame on the driver side, followed existing wire booms and such.
    I am not near it right now but i can send pictures later in the day when I'm home
  6. Apr 26, 2024 at 10:44 AM
    I got the arb kit too. The line is a bit stiff, so you have to be careful not to bend it too tightly so it kinks/collapses. I ended up routing it with sufficient slack to allow for suspension movement, and then zip tied the breather line along the brake lines on the drivers side frame rail all the way to the engine bay. That routing takes it close to the catalytic coverter, but I think the arb line can take some high temps. Regardless make sure it’s secured well to the brake lines when it passes near the cat. Once in the engine bay, I drilled the arb breather filter/ manifold thingy into the sheet steel behind the fuse box.
    (First and only hole I've drilled to the sheet steel, and I still can’t believe I did that lol. I drilled two holes for the manifold, but the spacing was off so it’s only being held by one lol).
    Dont cut the breather line until the routing is done. It’s frustrating when you’re short by an inch.
    I would suggest that you find a way to physically verify the routing and the amount of slack you leave near the diff to make sure there isn’t interference or pulling. Find a rock or a stump somewhere and flex it out all the way, take a bro-photo ;) and and carefully look underneath (don’t get run over).
    semprenissart and Acesandeights like this.
  7. Apr 26, 2024 at 11:05 AM
    I routed mine by the section of the inlet of the gas tank. Not inside where we open to fill in, but behind that section. It was a bit cumbersome but we got a way to stick there. It is as high as possible in that are and seems to be working well. Good luck.
    Stoney Ranger and Acesandeights like this.
  8. Apr 27, 2024 at 12:04 PM
    semprenissart
    semprenissart Mèfi
    Since I installed it by the fuse box everything is routed through the driver side. I kept the slack in case I need to use that space and need to relocate it in the future. I chose the driver side because h the êtes just enough space for it and the passenger side has a lot more space that I want to leave empty if ever set up an additional battery or something else
  9. Apr 27, 2024 at 3:14 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    Yep, I ran my line up the filler neck as far as it would go and zip tied it.
    This vid will show how to do it on the cheap.
    https://www.youtube.com/watch?v=1MFW8YK9dx0&t=219s
    LetsTacoboutit likes this.
  10. Apr 27, 2024 at 10:06 PM
    Ctreg
    Ctreg New Member
    I just routed along existing wires and frame avoiding heat shielded areas as best I could to the air box area. Zip ties from Harbour freight. Done, easy project to do and very effective in preventing water fouling or pressure build up in the rear differential.
  11. Apr 28, 2024 at 5:58 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Empty area behind the left rear tail light? Is that inside the cargo area or some super secret spot I can find on the exterior?
    I'm gonna do mine at some point in the nearish future and still debating running all the way to the front or finding a spot in the back. Keeping it in the back seems easier and a shorter hose seems like less room for cracks/breaks/melted from exhaust pipe in the future. I don't want to vent into the interior though
  12. Apr 28, 2024 at 10:24 AM
    This is the thread I started back in 2020 when I was researching the possibility of extending the breather to the rear tail light area, and completed the extension mod:
    https://www.4runners.com/threads/rear-diff-breather-extension.13816/
    There are links in there to different ways, and the components needed. I followed the process done by @kbp810, where he located the breather end below and behind the tail light cavity. The thread will explain it better than I can here. The kit I bought from BlaisBrosTacos may no longer available, as he hasn't been (or posted) on Tacomaworld since 2022.
    @MI-FL off roader in that thread used a filter (same one as the one in the Wanderlost Overland video, it looks like) from Summit and put the breather/filter in the area where the jack is stored.
    Let me know if you have any more questions.
    There was also this thread recently:
    https://www.4runners.com/threads/diff-breather-options-other-than-arb.36541/
    Spare Parts likes this.
  13. Apr 28, 2024 at 2:26 PM
    Saker New Member
    21 Black T4RORP
    Scuba Mod FWIW: I did this mod on my last two 4Runners and on my previous FJ, never had any smell from the rear diff.
    scottiezilla likes this.
  14. Apr 28, 2024 at 7:51 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Thanks for the photos. I like how you didn't bypass the existing locker line near the diff. and added the "T" where the existing locker breather is. Seems cleaner this way. Can I get part number(s) for the additional part(s) you used in addition to the ARB kit including the "T" that fits both the ARB line and the OE locker line?
  15. Apr 28, 2024 at 8:07 PM
    semprenissart
    semprenissart Mèfi
    I did it a while ago and I don’t remember the exact one that I got but I brought the arb line to ace hardware and looked for a t connector with the right diameter similar to the one below (not sure if these are the correct dimensions though)
    https://www.acehardware.com/departments/plumbing/hoses-and-tubing/hose-connectors/4501409
  16. Apr 28, 2024 at 8:12 PM
    For what it's worth the WO video used this setup for the locker and diff tee:
    Saker and semprenissart like this.
  17. Apr 28, 2024 at 8:18 PM
    scottiezilla
    scottiezilla New Member
    As long as you don’t run it up your exhaust pipe, you’re in good shape…heat, sharp edges, possible pinch areas, overexposure are the enemy
    Preventive strategy, cause i hate saying “wish I thought of that…” AKA over plan
    …if your thinking of running sliders, skids, updating suspension, tires, etc
    Not to run your line in those areas where it may interfere with install/function
    Probably not the end of the world to reroute but…
    also I used colored zip ties to easily identify the breather line since it follows black OEM wiring up to engine(it’s under the truck so get over it)
    n last but not least, if you think you’ll ever get around to the full “scuba mod”(thank you @Saker)
    Foreshadowing for the rest of the breathers to be relocated
    Saker likes this.
  18. Apr 29, 2024 at 4:43 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    Awesome, thanks for the reply. When I get under there I will figure out where I end up leaving it. I already purchased the ARB kit on sale last year so it's just a matter of getting under there and doing it. Need to pull the KDSS skid while I'm under there as well
  19. Apr 29, 2024 at 6:07 AM
    1SilverRunner
    1SilverRunner Long time listener, first time caller
    Earf
    TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar *coming soon Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken AT4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. MinWin End Caps Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Performance: Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Garmin Dash Cam Mini II with Dongar power solution Ram ball mount for Garmin In-Touch Mini II Scosche phone mount Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised 27W Ditch Lights OVS Nomadic Awning 6.5' AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Yotashop sells one for like 25 bucks. Route it up to your gas tank fill cap. Job done.
    Not as clean as the ARB version but easier to install and you save $100.
  20. Apr 29, 2024 at 6:18 AM
    Probably goes without saying, but dropping the spare tire makes the job.so much easier.
  21. Apr 30, 2024 at 9:23 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    Luckily I got a hitch mounted spare carrier from SSO before they went through the regime change so my spare is gone from underneath. Saw they recently put it back on the market
  22. May 5, 2024 at 4:03 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Ran mine to drivers rear shock side going up between frame and body
