2024 TRD Pro Roof Racks
Discussion in '5th Gen 4Runners (2010-2024)' started by achildr, Apr 28, 2024.
  1. Apr 28, 2024 at 10:04 AM
    achildr
    achildr [OP] New Member
    Looking to purchase a new 2024 4Runner TRD Pro. Unfortunately, I will need to replace the roof rack due to the low ceiling in our underground garage. Does the roof rack from the TRD Off Road fit onto the TRD Pro. I was told at the dealership they would not but wanted to confirm.
  2. Apr 28, 2024 at 10:30 AM
    steelevo
    Utah
    Welcome. It should be a direct fit either way. You can also do a roof rack delete.
  3. Apr 28, 2024 at 10:43 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Yes the regular rails fit. As usual the dealer has no idea what they are talking about
  4. Apr 28, 2024 at 10:46 AM
    kmeeg LionRunner
    I'm in a similar situation where if I lift my TRD Pro the roof rack may not clear my garage door. I'm thinking aftermarket low profile roof rack so it not only clears my garage it would be more practical to mount traction boards, storage boxes or any other accessories when needed. (No I will not keep all that junk when I go for groceries or school runs:p)
  5. Apr 28, 2024 at 10:56 AM
    achildr
    Thank you. Do you mind me asking what is a roof rack delete?
  6. Apr 28, 2024 at 1:37 PM
    Grandpawmoses
    Grandpawmoses New Member
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Covers the threaded holes
  7. Apr 28, 2024 at 1:44 PM
    steelevo
    Utah
    It’s a kit that has covers for when you remove the rack. There is a thread somewhere here in the forums.
  8. Apr 28, 2024 at 2:12 PM
    achtung6
    achtung6 New Member
    The 5th gen TRD Pros came from Japan w/ no roof rack. Instead, there are some blank panels that cover the roof rack mounting points. When these trucks arrived in port, the covers were removed so the TRD Pro Rack could be installed. You could get these from a Toyota dealer (which is a shame as I'm sure there are hundreds of these sitting in a box at the port facility).
  9. Apr 28, 2024 at 4:05 PM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    I have done it 3 ways on my Pro. In my 20 Pro removed the roof rack and added the black rails then decided to go smooth top. Removed it and did the delete kit.
  10. Apr 28, 2024 at 8:31 PM
    I don't suppose there's any way to have them leave off the Pro rack at the port...?
    MooreKen likes this.
  11. Apr 28, 2024 at 9:42 PM
    java
    java fauxrunner
    2023 ORP ice cap
    can use unistruts, very low profile, lots of attachment options as well. Thinking of replacing my orp rails. I am actually running ss unistrut crossbars, 100$ for a pair at grainger.
    https://youtu.be/VIvTgmZndps?feature=shared
  12. Apr 29, 2024 at 2:57 AM
    MooreKen
    MooreKen 2023 TRD PRO “Solar Octane”
    Just make sure whoever removes the Pro rack knows what they are doing or you will have to drop the interior liner to fix and that’s a pain in the ass. Plus you have to use heat (propane torch) to remove the factory installed bolts (they use red locktite) to loosen w/o stripping or breaking bolt head.
  13. Apr 29, 2024 at 2:57 AM
    MooreKen
    This would be optimal.
  14. Apr 29, 2024 at 4:24 AM
    achildr
    Thank you for the comments. Seemed odd to me that roof racks would not be interchangeable. This would be my first 4Runner so getting up to speed. On the fence between Terra and White. Both look extremely sharp.
  15. Apr 29, 2024 at 10:03 AM
    SolarOctane
    SolarOctane New Member
    Long Island, NY
    2023 4Runner TRD Pro
    I easily removed my OEM Pro rack without any heat required. A standard length ratchet handle had plenty of leverage and they broke free pretty smoothly. I guess it all depends on how much loc-tite was used, but once I fully removed all the bolts, they seemed to have a decent amount of it on them and I still had no issue getting them off. I was prepared for a challenge but they were easy and the entire rack removal took 15 minutes.
    I'd suggest giving a try without the torch first, just don't go crazy with a long breaker bar or anything where you'll break something before it loosens. Also loosen both bolts at each attachment points before removing either one to keep the clip from shifting and needing to drop the head liner.
    MooreKen[QUOTED] and glwood54 like this.
  16. Apr 29, 2024 at 10:10 AM
    ^^ Agreed. I can't imagine roof rack bolts having been installed within a few days or weeks prior would be all that much of a challenge to remove.
  17. Apr 29, 2024 at 10:14 AM
  18. Apr 29, 2024 at 10:35 AM
    brodeyo
    brodeyo New Member
    Cincinnati, Ohio
    2024 Black TRD Pro
    RCI Skids Sliders, Wescott Designs Lift
    I’ll be replacing mine in the next few months. Everything I’ve seen says give it a try…If it doesn’t budge with moderate pressure, heat it up with a torch. Westcott designs has a video on this if it comes to this point.
  19. Apr 29, 2024 at 1:01 PM
    MooreKen
    and I think the other thing I was trying to emphasize was don’t allow the little white plastic tubes spin and fall off into your roof liner as you remove the bolts. That was the other issue folks encountered which required dropping the liner to fish them out.
