Travel Trailer Questions!
Discussion in 'Towing' started by wendyww, Feb 12, 2024.
  1. Feb 12, 2024 at 6:45 PM
    wendyww
    wendyww [OP] New Member
    2015 4Runner
    Hello fellow 4R's! I have a question or two - we plan on renting a travel trailer and have purchased sway bar/towing hitch. Question - how do we set up the electronic braking system? Is it easy? 2nd How do we really know how much everything weighs? Trailer + stuff in 4R + us!!
    Thanks Wendy
  2. Feb 12, 2024 at 7:05 PM
    1st question:
    2nd question:
    To "know" how much it all weighs, weigh it on a scale before you put it inside the camper or inside your vehicle. Then add that to the "dry weight" of the camper and you'll get your true weight.
    Dry Weight of camper = xxx lbs.
    Weight of passengers = xxxlbs.
    Weight of crap you tossed into the trailer = xxx lbs.
    Total weight: xxxlbs. Make sense?
  3. Feb 13, 2024 at 5:28 AM
    wendyww
    2015 4Runner
    THANK YOU
  4. Feb 13, 2024 at 5:50 AM
    djdaves
    djdaves New Member
    SEPA
    2015 4runner SR5
    lift, wheels, tires, stuff.....
  5. Feb 13, 2024 at 5:51 AM
    djdaves
    djdaves New Member
    SEPA
    2015 4runner SR5
    2nd question what kinda RV are you looking at? We pull a '23 178bhsk. Love it. Counting down as we speak.....
  6. Feb 17, 2024 at 12:59 PM
    wendyww
    2015 4Runner
    We are looking at a Forest River RPOD 190 pretty light
  7. May 9, 2024 at 10:14 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    You may have already set up your rig, but I chose the Hopkins Insite modular controller.
    2 reasons: I wanted clear kneespace under dash, and I wanted the mechanical over ride switch ready at hand.
    The internal proportional braking automatically takes care of normal driving braking needs. In an emergency using trailer only brakes can be a big assist in regaining control of your rig.
    I mounted the brake over ride control sliding switch in front of my right knee for instant usage.IMG_9598.jpg IMG_3918.png
  8. May 9, 2024 at 11:31 AM
    PointmanUSMC
    PointmanUSMC New Member
    Illinois
    2023 Black TRD ORP 4 Runner Bronze Rims
    + 1 on the Red Arc trailer brake system. It's easy to wire up and sync the system. You can plug your numbers in here if you were curious on weight.
    https://www.towing-calculator.com/
  9. May 9, 2024 at 11:46 AM
    PointmanUSMC
    Illinois
    Here we are a couple weeks ago at one of the lakes and my stock ORP sitting on the side. I went down early with the truck and trailer and wife and kids showed up the next night in my 4 runner. We have a 2022 KZ Escape 191BHk. Downsized from a Winnebago 29Ft trailer. I found when I was in the Blue Ridge Mtns and the Rockies there were certain areas where it was more difficult to pull a longer trailer and maneuver around tight corners. Plus adding the length of your truck. I have found this little one is highly maneuverable and I haven’t found a site I can’t fit in. Either travel / RV site or tent camp site.
