Sherpa Crestone Silicone Anyway?
Discussion in '5th Gen 4Runners (2010-2024)' started by BoiseG, Apr 26, 2024.
  1. Apr 26, 2024 at 1:56 PM
    BoiseG
    BoiseG [OP] New Member
    2024 Off-Road Premium
    I’ll be installing a Sherpa Crestone roof rack on my 5th gen rig this weekend. Viewing their install video on YouTube doesn’t show them sealing the mounting bolts with anything other than the rubber block and their washer with the rubber seal. I was wondering if any of you who have this rack, applied silicone anyway, or just relied on their mounting material? I tend to over kill with things like this. Thanks.
  2. Apr 26, 2024 at 2:05 PM
    wax poetic
    wax poetic New Member
    21 Super White TRD OR
    OEM+ Trail Edition rims w/ Toyo AT3 in stock size OEM Heritage Grill OEM Black Valences (f + r) Westcott Sliders/Modular Roof Rack Roam 95L case DIY sleeping platform
    I didn't use any sealant when using their blocks with my Westcott Rack, I'm also in the desert and not super concerned. If you're somewhere with lots of rain, maybe, but I don't think it's necessary
  3. Apr 26, 2024 at 2:22 PM
    Lost Woods
    Lost Woods New Member
    2024 SR5P
    If anything the desert is as bad as anywhere else because we get crazy hard and heavy storms. I just did a little marine urethane adhesive sealant (it doesn't dry out over time or shrink nearly as much as silicone) around the hole before I added the spacers for peace of mind. The most common leak is from pooled water in the drip rails so that should take care of what little risk is left.
  4. Apr 26, 2024 at 2:28 PM
    BoiseG
    Thanks guys, I live in a desert too, but we do get our share of snow in the winter. I’ll probably add a little. Thanks for the tip on the marine sealant, that makes a lot of sense.
  5. Apr 26, 2024 at 2:55 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    No. I live in the PNW and have had my sherpa for 4 years. I have had zero leaks and it lives outsides 24/7. Silicone sealant on paint can trap water and cause corrosion. No sealant needed with the rubber blocks
    Fu3lC3ll likes this.
  6. Apr 26, 2024 at 3:50 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Nope, followed the directions and I’m going on 3 years here in Maine.
  7. Apr 26, 2024 at 6:49 PM
    blksubykid
    blksubykid New Member
    Over 4 years with mine, no issues
  8. Apr 26, 2024 at 6:54 PM
    BoiseG
    Ok, I'm convinced, no sealant. Thanks guys!
  9. Apr 27, 2024 at 6:59 AM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: LFD and Bud Built. Tires: KM3. Switchpro.
    Virginia, three years, several hurricanes, tropical storms, and noreasters. No silicone, no leaks. Just do NOT overtorque the bolts. The spec was in inch-pounds, not foot-pounds.
  10. Apr 27, 2024 at 10:09 AM
    wax poetic
    The rubber blocks are legit! Again, I'm using them not even on a Sherpa rack and I really felt safe with nothing else on there. And felt they'd hold up to the heat better.
