Plastic trim rubbing off paint
Discussion in '5th Gen 4Runners (2010-2024)' started by Juuba, Sep 24, 2023.
  1. Sep 24, 2023 at 10:03 PM
    Juuba
    Juuba [OP] New Member
    Anyone know how to remove this piece off the rear door? Don't know if it's attached with adhesives, clips or screws. I need to remove it and fix the paint being rubbed off
  2. Sep 24, 2023 at 11:14 PM
    gomiami
    gomiami I Bought a Luxury Station Wagon
    Jay
    SE of Kansas City
    2023 Lexus GX460 Nightfall Mica
    Husky front mudflaps, Canvasback full cargo and bench seat liners, "Not legal in California" patch.
    Firesq14 likes this.
  3. Sep 25, 2023 at 12:27 AM
    Juuba
  4. Sep 25, 2023 at 11:01 AM
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Do you push on that plastic trim piece to close the hatch? Just curious how yours has developed . . . from rattling or pushing or whatev
  5. Sep 25, 2023 at 11:19 AM
    ipnpulz
    ipnpulz New Member
    2023 TRDOR premium T4R
    It’s a HUGE pian in the ass…..
  6. Sep 25, 2023 at 1:49 PM
    3JOH22A Toyota Gigolo
    Is that paint rubbed off or residue from polishing compound or wax?
    kolter45 likes this.
  7. Sep 25, 2023 at 8:49 PM
    Juuba
    Don't think I have done it recently, but maybe I did at one point. It's a 21. bought it at 48,000 miles and put about 5000 miles so far. Pretty sure vibrations when driving, causes the edges to make contact with the paint.
  8. Sep 25, 2023 at 8:50 PM
    Juuba
    I haven't waxed or polished it since ownership. On the other corner, surface rust is starting to appear.
  9. Sep 26, 2023 at 5:50 AM
    Then you probably don't want to look under the license plate :devil:
    Jokes aside, the guide posted on Trail4Runner looks pretty doable, easier than replacing speakers. While you're there, spray some cosmoline inside the hatch shell at the bottom - the area can collect water and rust away.
  10. Sep 26, 2023 at 5:57 AM
    ReveMoto
    ReveMoto New Member
    11515 Tanner Road Houston, TX 77041
    Lots of steps but yeah exactly what that write up showed step by step very precise and don't let it scare you its very simple to do. It doesn't look like paint coming off but residue of some sort. If you don't want to take the trim off. Get like compound and get a microfiber towel. Put the compound on the microfiber towel and rub that area. If it comes off then with the same towel get polish/wax and do the same thing to get protection on that area from having it happen again. Any questions let me know.
  11. Sep 26, 2023 at 7:27 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    As far as what's causing the issue, your second picture shows vertical scratches on the plastic piece. Either somebody's using the plastic to push the hatch closed or something else is up against it on occasion. This could cause the piece to rock back and forth and cause abrasion. Of all of the 4Runners I detailed at the dealership I work at though, I've never seen paint removed where you're seeing it on yours.
    Just out of curiosity, was the hatch possibly repainted at any time?
  12. Sep 26, 2023 at 8:25 AM
    Maybe it’s had some rubbing from being opened into a garage door? I could imaging after a while it could shift the trim piece and rub on the paint.
  13. Sep 26, 2023 at 11:52 AM
    TheSponge
    TheSponge New Member
    Yes, simple job when those self retaining studs dont spin. If they do, have fun. Just went through it last week. I pulled mine off, sprayed inside the door cavity (used Rust Check (red) bit more runny than fluid film) and installed 3M film where the valance sits against the paint. Also, added rubber washes to offset the entire thing a bit off the body to prevent rubbing. Mine started to rub up around the oval where the Toyota embleem is.
    Also, a good time to remove the license plate and check behind it, install a silicone plate holder from Amazon $10.
  14. Sep 26, 2023 at 3:09 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Common problem. Mine has done it since new
  15. Sep 26, 2023 at 3:55 PM
    beedee
    beedee Member
    While you are in there, I highly recommend after removing the nuts in step 7 of that link, adding some blue thread locker to them before your reinstall them. They are pretty notorious for coming loose and falling off and rattling around in the lift gate when opening and closing it. I had one that did that (2018 4R) and some of the other ones were loose.
  16. Sep 26, 2023 at 4:21 PM
    TheSponge
    If he ever has to take it off again he’s going to break the studs and their going to spin..
  17. Sep 27, 2023 at 4:00 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    2021 4Runner ORP
    It's a know issue. I had my 2021 4R repair covered under warranty. The bodyshop that did it has done several of these repairs. Mine was actually starting to rust.
    Another area to check is the hood scoop. Paint was rubbing off there too.
  18. Sep 27, 2023 at 6:01 PM
    Startrek
    Startrek New Member
    carwash brush
  19. Sep 28, 2023 at 8:23 AM
    rrprouty
    rrprouty New Member
    Ryan
    2019 SR5P, 2016 Limited
    my 2016 on the right side of that garnish is rubbing and I have some rust going UNDER the paint. I have a limited so I was planning on replacing that garnish with a nightshade one. Probably have to address that shit while Im at it.
  20. Jan 31, 2024 at 3:03 PM
    Wawa 4runner
    Wawa 4runner New Member
    2024 4Runner ORP
    Thank you for this!! I never thought about that. Ordered one.
  21. Feb 1, 2024 at 8:22 AM
    medium.rare.pepe
    medium.rare.pepe New Member
    Just had this fixed 2nd time under warranty.
    First fix was touch up paint done by the dealer - lasted about 6 months until issue came back.
    2nd fix was repaint at the body shop, and they added PPF around the trim piece. Dealer refused to fix it a 2nd time stating that Toyota declined the warranty work.
    I had to open a case with Toyota brand engagement team, they pushed the issue and it was approved.
  22. Feb 13, 2024 at 8:34 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    God damn it. Another annoying issue to fix
    Wawa 4runner and icebear like this.
  23. Feb 14, 2024 at 6:18 AM
    Hans
    Hans New Member
    Placed my order.
  24. Feb 14, 2024 at 8:10 AM
    Yobruhitsme
    Denver
    People with this issue? What’s the symptom? No gap between the garnish plastic and metal body?,
  25. Feb 14, 2024 at 8:56 AM
    laxman09
    laxman09 New Member
    Mahoning Valley, OHIO
    I have rust under the door sill trim I just found on my 2020. It's a CPO and runs until the end of the year. Might take it to the dealer to see if they will fix it under the warranty
  26. Feb 14, 2024 at 9:34 AM
    steelevo
    Utah
    This is what I use on all of my vehicles with stainless steel hardware.
  27. Feb 14, 2024 at 10:13 AM
    icebear Recovering Kia Owner
    Took a closer look at mine earlier, my hatch plastic bit isn’t rubbing around the edges so paint looks fine. So far only paint issue is edge of hood rock chips and I’m just throwing touch-up paint at that.
  28. Mar 23, 2024 at 10:31 PM
    pullingin
    pullingin New Member
    I have a 2022 and just noticed the paint rubbing off on either side of the garnash. Does anyone know if this is caused by a change in gasket or garnash? I have been looking at every 4runner now and notice some older years that are perfectly fine.
    @medium.rare.pepe , @Tooly and others who have had it covered under warranty, does toyota take any measures to make sure it does not happen again like replacing the gasket with updated version or add spacers? There is one person on youtube who had it fixed and the same thing happened a year later and he was out of warranty at that time.
    All the best.
  29. Mar 24, 2024 at 6:43 AM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    2021 4Runner ORP
    If you look at the part number history of the gasket for the handle, there have been no part number revisions so no change in the 14 year model run. My sister's 2015 4R does not have this issue but there is a visible gap between the handle and body that mine did not have until it was fixed. Something changed at the factory with how the handles were installed and Toyota just didn't care to fix it or I guess hopes the owner doesn't notice until after the warranty has expired.
  30. Mar 24, 2024 at 7:29 AM
    Nick4RNR
    Nick4RNR New Member
    Planning to remove trim and PPF that area.
    toy33 likes this.
