Passenger Side Mount for ARB Twin Compressor
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, May 9, 2024.
  1. May 9, 2024 at 11:25 AM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar *coming soon Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken AT4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. MinWin End Caps Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Performance: Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Garmin Dash Cam Mini II with Dongar power solution Ram ball mount for Garmin In-Touch Mini II Scosche phone mount Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised 27W Ditch Lights OVS Nomadic Awning 6.5' AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Anyone have a passenger side mount for the ARB twin?
    Not a big fan of covering the fuse box the way the Rago fabrication one seems to.
    A couple considerations:
    -I do not need a tank. This compressor needs to air up tires. That is all.
    -Mounting in the engine bay would be ideal. Under seat mounts are cool but generating that amount of noise in the cabin is not an option
    -I'm out of switches on the dash so I'll likely wire a switch next to the compressor in the engine bay.
    Just getting tired of how long my little VIAR compressor takes to air up. It also takes up space in the cabin which I'm not a fan of.
    Reading this article and trying to figure out what fits my needs best.
    https://trail4runner.com/2022/07/06/arb-air-compressor-mounts-5th-gen-4runner/
    M.O.R.E:
    https://runnin4tacos.com/products/m...r-bundle-5th-gen-4runner?rfsn=6387734.20b9afa
    Hefty Fabworks:
    https://heftyfab.com/products/2010-4runner-arb-compressor-bracket?variant=44156611133694
    LFD:
    (Currently Backordered)
    Anyone have experience with mounting the compressor? Are you happy with your mounting solution/ wiring/ install process.
  2. May 9, 2024 at 11:30 AM
    Google search returned a few results:
    1SilverRunner[OP] likes this.
  3. May 9, 2024 at 11:37 AM
    1SilverRunner
    Tejas
    Thank you.
    I honestly forget google search engine works better to pull up results from this site than this sites own search feature. :laugh:
  4. May 9, 2024 at 11:38 AM
    It works well with this site if you put site:4runners.com/ after your search criteria.
  5. May 9, 2024 at 11:42 AM
    1SilverRunner
    Tejas
    I'm an idiot. Thank you
    MyWyfsRnnr likes this.
  6. May 9, 2024 at 11:45 AM
    No you're not. And, I meant Google search works well with that after the search criteria. I don't tend to use this site's search, as it doesn't work well for me, either.
    Justkelvin likes this.
  7. May 9, 2024 at 11:52 AM
    rageandlove
    rageandlove New Member
    I installed the LFD about 4 years ago. It's been fine - solid, no hassles, stainless steel. I'd use it again.
  8. May 9, 2024 at 11:55 AM
    1SilverRunner
    Tejas
    Gathered that. Works like a charm.
    Not a ton of info on the Hefty Fabworks mount. The M.O.R.E. mount seems to be more popular on this forum.
    I'll likely reach out to LFD to see what their lead time is. I've been impressed with their products in the past.
    rageandlove[QUOTED] likes this.
  9. May 9, 2024 at 12:49 PM
    brodeyo
    brodeyo New Member
    Cincinnati, Ohio
    2024 Black TRD Pro
    RCI Skids Sliders, Wescott Designs Lift
    I'm looking for onboard air compressor. Did you go ARB? Thoughts?
  10. May 9, 2024 at 12:53 PM
    rageandlove
    @MusashiSushi has installed one (see post here) ... maybe he can drop by and give his opinion. It looks like it has 3 bolts into the firewall, which is one more than my LFD.
  11. May 9, 2024 at 1:31 PM
    1SilverRunner
    Tejas
    Very nice thank you!
    The fasterflate hose kit is a nice addition as well.
    My little Viar88 works but holy cow it takes forever and the thing gets smoking hot.
    That said, I think in the manual somewhere it says it should only be used for up to 33" tires and only for a certain time limit.
  12. May 9, 2024 at 1:51 PM
    MTB Chris
    MTB Chris New Member
    San Diego, Ca
    Running the More mount on mine, highly recommend. If you have the extra cash I'd also recommend pairing it with the pressure control unit and you can run the compressor and set parameters via bluetooth on an app:
  13. May 9, 2024 at 2:28 PM
    1SilverRunner
    Tejas
    Man your wiring is super clean! Nice job
  14. May 9, 2024 at 3:25 PM
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    I have the ARB twin (with aftermarket air breathers) and ARB air tank on a M.O.R.E mount. I frabricated a mount for the manifold out scrap metal and using some extra hardware from my junk containers. Used it a handful times and it works well with my set up. Airs up my 34” Nitto MT’s pretty fast.IMG_3239.jpg IMG_3238.jpg IMG_3236.jpg IMG_3235.jpg
  15. May 9, 2024 at 5:45 PM
    nova
    nova New Member
    mike
    Soon Arizona
    slightly modified LE
    I have a Bandiworld mount from a chap on the other board. His price was reasonable, super sturdy and had options for an ARB tank and manifold.
    A couple of years ago he said he was taking a break. For how long? I don’t know. I’d check him out in case he’s back. I happy with the product.
  16. May 10, 2024 at 5:42 AM
    1SilverRunner
    Tejas
    Thanks for the input guys!
  17. May 10, 2024 at 5:45 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    I have the Mountain Offroad mount you linked on my 2023. It fits fine - just will have an empty space underneath without the tank.
  18. May 10, 2024 at 5:59 AM
    1SilverRunner
    Tejas
    Do you recommend wiring a switch into the cabin as appose to a switch on/ near the compressor itself?
    I'm out of those little Toyota OEM button slots and don't want to add a switch pro for the compressor only. Mounting a simple switch next to the compressor makes more sense to me.
  19. May 10, 2024 at 6:11 AM
    I asked him the same question in his build thread. A switch by the compressor seems like a good idea to me.
  20. May 10, 2024 at 6:30 AM
    clt_ah4runner
    clt_ah4runner New Member
    aaron
    blackout emblem, baja designs fogs, yotaled raptor, lasfit exterior LEDs, vled interior LED, treaty oak recovery points
    I have a brand new bandiworld mount I never ended up installing, he dosn't make em anymore if anyone is interested
  21. May 10, 2024 at 6:38 AM
    Any photos? I'd like to see what this looks like.
  22. May 10, 2024 at 2:21 PM
    mcat707
    I was interested in Brandi’s mount when I was looking for my ARB compressor set up a while back but it’s been discontinued.
    Here is the thread with info…
  23. May 10, 2024 at 6:43 PM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: LFD and Bud Built. Tires: KM3. Switchpro.
    I've been using the 4X4Labs mount for two years. It works well for just the ARB Twin - no tank. My one complaint is that one of the bolts can't be installed with the compressor mounted, and the compressor has to bolted to the plate first. So i end up running with one less bolt.
    The Hefty mount shouldn't have that issue because the compressor sits further from the fender. I'll switch to that one as soon as it ships. The main reason for the switch is to add a manifold to support a front air locker.
  24. May 10, 2024 at 10:11 PM
    Thanks, but that forum is inaccessible on a mobile device with all the ad popups. I had to get out of it before I went batty.
  25. May 11, 2024 at 10:02 AM
    MusashiSushi
    MusashiSushi New Member
    Colorado Springs, CO
    2023 4Runner SR5 Premium Black/Black
    Elka 2.5 DC 3" lift, SPC UCA's, Toytech rear springs, ARB Diff Breather, RSG Rock Sliders & front Skid. C4 front bumper with High Clearance sides and Warn Winch.
    I've been quite happy with the Hefty mount. Since you don't need a tank, neither did I, it will work just fine. It has two mounts on the firewall and one arm that extends below that adds support. It's been rock solid and I like having the rocker switch mounted right next to it. It comes with an optional plate for mounting the ARB manifold in the event you do go with lockers.
  26. May 11, 2024 at 10:56 AM
    Do you know if the Hefty mount will work with the ARB single compressor?
